Old Jan 24, 2013, 03:28 PM
motorrc is offline
Find More Posts by motorrc
United States, OH, Canton
Joined Nov 2010
Question
straightening aluminum pipe
I bent some boom supports on my heli and tried to straighten them by hand and now they resemble a couple of snakes. They are made of aluminum With an outside diameter of 6mm and inside diameter of 4mm. Any tips on an easy way to get them straight again would be greatly appreciated!
motorrc is offline Find More Posts by motorrc
Old Jan 24, 2013, 08:24 PM
kenh3497 is online now
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Does that bring back memories.... Is the boom support open so you can slide a wire inside of it? If so find a wire that is just a tad smaller than the ID of the support. Round the end as best as possible. You don't want any sharp edges. Lots of lubricant is your friend now. Force the wire to the first kink and VERY lightly tap the outside with a hammer. If you have a soft face hammer all the better. Tap all around the outside at the kink until it is removed. Keep pushing the wire in and tapping the outside of the support.
I used to do this with tail booms and a wood dowel after a boom strike. The booms were never perfect, but good enough.
It is probably not worth the effort to straiten the supports for the cost of replacements but if you have to order parts it will get you buy for the time being.
Good luck!
Ken
kenh3497 is online now Find More Posts by kenh3497
Latest blog entry: A letter from my Senator.....
Old Jan 24, 2013, 09:25 PM
motorrc is offline
Joined Nov 2010
aluminum supports
thanks for the tip Ken!
Old Jan 25, 2013, 10:27 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
A couple of carbon fiber arrows the right size might replace them. You could straighten them by taking a very straight 3/4" x 4" board the right length and on a hard surface use the board to press the worst of the bends out and then roll the boom under the board with pressure and it will straighten out pretty good.
Leroy
Leroy G is offline Find More Posts by Leroy G
Old Jan 27, 2013, 09:21 AM
motorrc is offline
Joined Nov 2010
ok, thanks!
mark
Discussion How to straighten an aluminum wing tube? jrb Electric Plane Talk 12 Oct 06, 2012 11:36 AM
Discussion Straightening Aluminum LG shootnstarz The Builders Workshop 7 Sep 30, 2011 09:31 AM
For Sale KME Diamond .60 Aluminum Billet Engine & Pipe $380.00 KingJoe Aircraft - Fuel - Helis (FS/W) 0 Sep 24, 2011 06:41 AM
Sold T-Maxx 3.3 with lots of aluminum & cabon fiber pipe - trades welcome!!! habitforming Cars - Trucks and Parts (FS/W) 2 Dec 09, 2009 11:25 PM
Sold T-Maxx 3.3 with lots of aluminum & cabon fiber pipe habitforming Cars - Trucks and Parts (FS/W) 4 Nov 22, 2009 08:25 AM
