Old Jan 31, 2013, 10:33 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
If you wind your coils by hand, try to keep each layer of wire smooth and flat. Don't get in a hurry and end up with "scramble wound" coils - they'll turn out larger than smooth, easy layers.
One suggestion would be to put the section of drinking straw onto a wooden dowel with a hand crank attached to one end. Fashion a stand of some sort to support the dowel. Turn the crank with one hand as you feed the wire with the other.
Just give it a go and practice on a couple of "test" coils, not using any glue. Then you can rewind onto a nicely finished coil after you've had some practice.
356Jim is offline Find More Posts by 356Jim
Old Feb 01, 2013, 01:24 AM
rogenstein1983 is offline
Find More Posts by rogenstein1983
rogenstein1983's Avatar
Joined Feb 2012
Originally Posted by epilot View Post
I'm sorry, I don't understand what you are asking.
You wind the 17m length of wire onto a spool. Each end of the wire connects to the receiver.
Hiya, I was asking is it one strand with just two ends for the reciver or 2 strands of wire with four ends two end in the coil and two ends for the reciver
rogenstein1983 is offline Find More Posts by rogenstein1983
Old Feb 01, 2013, 02:10 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
It should be one continuous winding with 2 ends. All windings must be wound in the same direction (eg: clockwise).
I use thin cyno for bonding. I put a small piece of furry velcro on a balsa stick and saturate it with cyno. I then wipe the wire through that to wet the wire before winding it over the straw.
dt.
David T is offline Find More Posts by David T
Old Feb 01, 2013, 03:22 AM
Joined Feb 2012
dt.
Thanks for that very helpful answer David thats exactly what I thought, I've managed to modify a black and decker screwdriver so I'll try that for winding to although maybe to fast, will have to try it a later today when I finish
Just gotta make some spacers for the coil ,would love to use some home made coils for my next few lrf
Old Feb 01, 2013, 04:01 AM
David T is offline
UK
Joined Aug 2000
I power my winder with a variable power supply. It has a knob for voltage control. I actually put that on the floor and rotate the voltage knob with a toe leave both hands free for winding and the ability to speed up or slow down depending on how well its going. I have a sensor on the shaft and a counter to keep track of turns.
dt.
Old Feb 01, 2013, 05:38 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
for bonding
I use gratplanes aliphatic glue on my finger that leads the lead onto the coil. this sets pretty good and if i get it on light enough i can actually unwind it if i need to resolder an end.
methuso is offline Find More Posts by methuso
Old Feb 02, 2013, 11:19 AM
David T is offline
UK
Joined Aug 2000
By the way I have some very small solder pads for terminating/connecting stronger wires. Let me know if interested. Photo shows flex PCB. I have 0.2mm rigid as well.
dt.
Old Feb 02, 2013, 06:34 PM
Joined Feb 2012
dt.
Ohh that looks like it could come in handy, I'll be getting another rx52m of you soon so will see if I have got good enough with coils for that, had long shifts last few days and time has been a rarity, hopefully get time to crack on with this in next day or two ,the possibility of not haveing to fork out for coils anymore is so close haha
Old Feb 06, 2013, 07:02 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
a little late, but i have tried nail polish as a wire bonding and while it worked okay, i think an actual glue is much stronger than it was. keeping the winds together when removing from a model can be difficult if they are not held tightly by the glue.
the 2 wall timers i have torn apart were around $4 each and have a good amount of 44 gauge wire in them. i have made numerous coils and have yet to run out from the first 2 i bought
speaking of which, i have to wind up some more coils tonight for my current project, look in the micro boats section for that one
derk is offline Find More Posts by derk
Old Apr 25, 2013, 06:56 AM
Joined Feb 2012
So I finally got round to winding some coils actually very easy I used a spare thin point solder tip dipped in wax so the coils wouldent stick and some bits from the tool box to make my spacers ended up with something very simular to Plantracos 200 mg coil, so I'll be able to finish my deltang lrf biplane later this week oh and used thin ca to bond coils
Discussion Uberlite 2-1 plane actuator rcnutt Scratchbuilt Indoor and Micro Models 7 Jan 22, 2013 08:33 AM
Wanted Plantraco HingeACt actuator or coil The Don Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jan 19, 2013 08:52 AM
Discussion Poor Mans Micro Brushed ESC/Actuator Driver/LED Proportional with trim elvill Micro Ready-to-Fly 5 Jan 18, 2013 01:12 AM
Discussion GWS IQ-200MG Servo karmann Slope 0 Jan 03, 2007 01:48 PM
Wanted Wanted: Actuators (pager motor actuators & homemade fine), or actuator wire. Cheesehead Aircraft - General - Radio Equipment (FS/W) 0 Aug 11, 2006 10:32 PM
