Old Jan 24, 2013, 02:35 PM
rogenstein1983's Avatar
Joined Feb 2012
70mg and 200mg actuators
I've got to the point where I'm useing enough actuator coils that I really should start makeing them, and I want to end up with coils very simular to the lightest versions Plantraco stock ,anyone have good advice for a source for the magnetic wire I'll need and a source thats in UK, and as I say at the top im wanting to end up with sone 70 mg coils and some 200 mg coils none bigger really needed for me, any help and advice of whats needed would be great, ciaran
rogenstein1983 is offline Find More Posts by rogenstein1983
Last edited by rogenstein1983; Jan 24, 2013 at 02:37 PM. Reason: terrible at my own language!!!!
Old Jan 24, 2013, 03:31 PM
Marmite.......
epilot's Avatar
United Kingdom, England, Harpenden
Joined Nov 2000
I've got a very big spool of high quality 0.05mm heat bondable wire available if you are interested. It's it perfect for the size of coils you want to make. A 65ohm coil weighs around 0.1gram. I have some PTFE tubing suitable for making formers as well (it will stand the temp of the bonding process). There is 1.3kg wire on the spool so you could make thousands of coils from it. Might be more than you need and although I'm willing to sell it for much less than I paid, it is still a fair bit of money to invest.
epilot is offline Find More Posts by epilot
Old Jan 24, 2013, 03:47 PM
Marmite.......
epilot's Avatar
Joined Nov 2000
FYI, for the 70mg coils you will need 0.035mm wire. It is very difficult to get a hold of heat bond wire in small quantities. MOQ is usually 1kg. I used to have some that I bought from Elektrisola. Expect to pay around £100+.
Old Jan 24, 2013, 05:04 PM
Joined Feb 2012
Thanks for that information, and I'll keep your offer to mind, I'd hoped to find suitable wire from a site I found from RCGroupes called Oemwire.com am I wroung, it's confusing me ha, I'm sure I can do these though, I'll be able to source suitable magnets from Plantraco, I'm sure there proberly not the cheapest but I've found them reliable with postage
Old Jan 24, 2013, 05:17 PM
Marmite.......
epilot's Avatar
Joined Nov 2000
Magnets can be had at very good prices from here: http://www.supermagnetman.net/
Good, friendly service and low prices.
The wire from the site you mention is not heat bondable so you will be adding a bit of weight to your coils in the form of glue or lacquer to hold them together. No need to buy from the US, we have a good supplier of wire in the UK: http://www.wires.co.uk/acatalog/SX_0032_0090.html
The thinnest heat bondable they do is 0.08mm which is too thick for the coils you want to make.
Old Jan 24, 2013, 07:07 PM
Joined Feb 2012
I think if I was ever so light with the glue I may find that easier for me but only as I haven't used heat bondable wire
Old Jan 24, 2013, 07:21 PM
Joined Feb 2012
Some very helpful links thanks epilot ,am I right in thinking the 0.040mm and 0.045mm could be a good match for makeing something similar to the 200mg one from Plantraco?,right I need to check out the how twos section again and I think I'll have this done ,maybe
Last edited by rogenstein1983; Jan 24, 2013 at 07:37 PM. Reason: ribbings from the general public!!
Old Jan 24, 2013, 07:25 PM
Marmite.......
epilot's Avatar
Joined Nov 2000
I think you mean 0.045mm??
The 0.2g coils probably use 0.05-0.06mm wire.
Old Jan 24, 2013, 07:32 PM
Joined Feb 2012
Yes indeed thats what I ment, as we have learnt before my wording is awful and this time even worse I think 40mm would be massive haha thanks for stopping me building the heaviest micro rc plane ever
Old Jan 24, 2013, 08:00 PM
Centerville, In. USA
Joined Jul 2001
I read somewhere that those super cheap clocks at the dollar stores use a very fine wire in their motors that drive the dial hands. Maybe you could try one. I have a question. I was given some uberlite planes. The actuators were mostly bad. I ordered a couple from Micron out of Austrailia. But I would like to try making my own if these go bad. I have some very small magnets that are quite strong. I used some building brushless motors quite while back. These magnets are less than !/4" long and about 1/16" square. I would really like to find some good intructions to see exactly how actuators are made. I especially would like to make the proportional type. Are there any good directions out there for making actuators? RCNutt
rcnutt is offline Find More Posts by rcnutt
Old Jan 25, 2013, 02:24 AM
UK
Joined Aug 2000
The 1.5v quartz clocks do have fine wire. But in the UK the old mains timer switches have thinner wire. The mechanical types with the lugs for each 30minute period.
dt.
David T is offline Find More Posts by David T
Old Jan 25, 2013, 03:19 AM
Joined Feb 2012
Thats some good info thanks David, I actually have a few of them lying around and there relatively cheap depending how much wires inside
Old Jan 25, 2013, 04:57 AM
Marmite.......
epilot's Avatar
Joined Nov 2000
I honestly don't think messing around with timers where you don't know what diameter wire you are going to find is worth the trouble. It is often not solderable wire anyway. A 250gram spool of solderable 0.05mm wire from wires.co.uk is only £16 plus VAT.
Old Jan 26, 2013, 06:41 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
I honestly don't think messing around with timers where you don't know what diameter wire you are going to find is worth the trouble. It is often not solderable wire anyway. ..............
epilot is right. I have tried some wires that I swear the insulation would survive a nuclear blast without the insulation coming off.
One of the vexing problems with actuators is breaking one or both wires right at the coil. If the wire was heat-bonded, you're s*&ewed. To avoid fits of apoplexy, wrap a couple of turns of the free wire around the outside of the coil and tack in place with either a water soluble glue (PVA) or a nitrocellulose kind (balsa cement like Ambroid or Sig-Ment) and use a drop of acetone to loosen if needed.
356Jim is offline Find More Posts by 356Jim
Old Jan 26, 2013, 07:46 PM
Joined Feb 2012
Thanks this is all good advice I will crack on and get back to everyone when I've started makeing these coils
Discussion Uberlite 2-1 plane actuator rcnutt Indoor and Micro Models 7 Jan 22, 2013 08:33 AM
Wanted Plantraco HingeACt actuator or coil The Don Aircraft - Electric - Micro & Indoor Airplanes 1 Jan 19, 2013 08:52 AM
Discussion Poor Mans Micro Brushed ESC/Actuator Driver/LED Proportional with trim elvill Micro RTF 5 Jan 18, 2013 01:12 AM
Discussion GWS IQ-200MG Servo karmann Slope 0 Jan 03, 2007 01:48 PM
Wanted Wanted: Actuators (pager motor actuators & homemade fine), or actuator wire. Cheesehead Aircraft - General - Radio Equipment (FS/W) 0 Aug 11, 2006 10:32 PM
