Old Jan 24, 2013, 01:50 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Realized my mistakes, on the the next Tilt-Rotor build
I was just sitting here and thinking about the failures of my custom autopilot that I used for my Tri and Bi-copter tiltrotor. I was calculating my angles wrong. Perhaps I'll switch to quats. Anywho, with the realization that my autopilot wasn't having hardware issues, I feel motivated to actually get together my next aircraft together without having to redo my autopilot board. I already have most of the parts sitting in my garage.
Parts list:
http://pinterest.com/ilektron/mini-m...or-components/
And yes. I use pinterest and it is awesome for hobby stuff. I plan on making this a complete tiltrotor with full transition capabilities.
Also, I recently verified that the HobbyKing 6Channel RX V2 outputs a combination of all the other channels on the 7th pin block (not quite PPM), as described here
http://blog.ilektronx.com/2013/01/ha...6-channel.html
I plan on using this fact to reduce my wiring.
ilektron is offline Find More Posts by ilektron
Old Jan 24, 2013, 02:41 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I think this has been removed.
Just purchased one a few days ago hoping to find the PPM on on the Battery port but it was not there. Purchased a few about a year back and it has been removed. I have some with PPM on the Battery port, is there a secret to getting it back? Sure would like to know.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jan 24, 2013, 02:51 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
I hadn't even thought that there would be a difference. The RXs I have are about a year old. If you can take a hi-res post of the PCB, front and back, I'll take a look and see if I can figure it out.
I wish this were a standard.
Old Jan 24, 2013, 02:54 PM
Joined Aug 2009
The older ones as well as the newer ones I have all have the A7105 chip, so my best guess is, they changed the firmware.
Old Jan 24, 2013, 03:07 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
That is entirely possible. Can you confirm that the hardware didn't change?
Old Jan 24, 2013, 03:15 PM
Joined Aug 2009
I had some pictures but I will open a couple up and take pictures however, to the best of my recall, nothing changed.
Old Jan 24, 2013, 03:21 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
I think I need to go home and crack open and reverse engineer the HK 6ch RX tonight... Or perhaps this weekend when I have time.
Discussion Chimera VTOL (tricopter tilt rotor) foam and tape VTOLs 154 Aug 02, 2015 08:59 AM
Discussion Seeking suggestions for next scratch build dglo Scale Kit/Scratch Built 29 Oct 29, 2013 08:12 PM
Discussion Thoughts about transitioning a tilt-rotor ilektron VTOLs 23 Jul 16, 2013 02:51 PM
Discussion Not liking wing the joiners on my Custom Mirage build.....any tips hog2soar Thermal 7 Jan 07, 2013 10:35 AM
Discussion Swift tail blade grip screws M3X14 into rotor hub too long? Nevermind, my mistake... EddieNewYork Electric Heli Talk 2 Sep 11, 2006 11:10 PM
