This thread is privately moderated by uptime4downtime, who may elect to delete unwanted replies.
Old Jan 24, 2013, 02:02 PM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Power Plant Options & Prop Balancing
CYak:
2205C 1400Kv
http://www.hobbyking.com/hobbyking/s...dproduct=28166
SUNNYSKY X2204 1480KV
http://www.hobbydream.com/sunnysky-x...or_p13744.html
Sbach:
AXi 2814/16 12x3.8 SF
Prop Balancing
I get the blades to balance. then turn the prop vertical. If it falls to one side I note which side of the hub goes down. Then turn back to vertical with the opposite blade up and if the same side of the hub goes down noted previously then that's the heavy side of the hub. I've added as little as a few hardened drops of CA up to some very small steel washers CA'd to the light side of the hub. When fully balanced you should be able to move the prop into any position and it will stay there. Then balance spinner
uptime4downtime is offline Find More Posts by uptime4downtime
Discussion Planting Pelosi Seeds... Broken Wings Life, The Universe, and Politics 6 Jan 03, 2013 08:59 PM
Question Bombshell power plant options. Twmaster Vintage & Old-Timer Designs 8 Dec 04, 2006 11:35 AM
RBC Microbipe power Plants? kepople Parkflyers 4 Nov 15, 2001 10:47 AM
twinstar power plant tc99 Foamies (Kits) 1 Jul 23, 2001 11:24 PM
Amptique Power Plant Dick Oglesbee Electric Plane Talk 7 Jun 13, 2001 07:58 AM
