Old Jan 27, 2013, 04:49 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
I cant wait TOO !
Slow going.
Ordered struts, rudders/tubes, props/shafts/tubes and couplings today from MACK, dont know of Any other outfit that will take your order ...
On a Sunday !
Tim B. is offline Find More Posts by Tim B.
Old Jan 27, 2013, 05:50 PM
H.Lauer is offline
Find More Posts by H.Lauer
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
That's pretty cool !
H.Lauer is offline Find More Posts by H.Lauer
Old Jan 30, 2013, 04:37 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
More done..
WELL !
I ordered the struts and shafts ( etc. ) last Sunday, and to my amazement, they arrived TODAY !
Now I can move forward with tryin to figure out how/where to mount the rudder and stuffing tubes.
Ordered some wide sheets of Balsa on Monday, doesnt look like I'll be gettin that material as fast as MACK can do it.
Frame felt flimsy and it seemed like a good idea to add some more "stringers" and other supports for the planking to get a hold of when its time, its strong enough now to be inverted while mounted to the building board.
Found ideas on where to put additional framework from other big-boat builds ( thanks all ! )
Old Jan 30, 2013, 06:21 PM
Browndog is offline
Find More Posts by Browndog
Browndog's Avatar
United States, CT, Wethersfield
Joined Mar 2006
The frame looks great.That nose is fun ,the 28 is giving me fits
Browndog is offline Find More Posts by Browndog
Old Jan 30, 2013, 06:45 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
A challenge to be sure ...
Old Jan 30, 2013, 10:11 PM
Band1 is offline
Find More Posts by Band1
Band1's Avatar
United States, NY, Queens County
Joined Oct 2011
Nice frame.
Band1 is offline Find More Posts by Band1
Old Jan 31, 2013, 07:39 AM
oldbilgewater is offline
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
Don't concern yourself about a seemingly flimsy frame. Once the sheeting is on you will be surprised how strong it is.Suggest running a second bead of glue over both sides of the former/sheet joint. That should be done only after the initial application is completely dry.
This is really looking good.
oldbilgewater is offline Find More Posts by oldbilgewater
Old Jan 31, 2013, 08:56 AM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Spent some time last night trying to figure out just where to put the stuffing tubes in the framework, a critical step.
The plans ( turning out to be more guideline than plans ) show No indication of placement.
The side view of the hull shows the location of the rudder, shaft and prop on the Real boat and thats not necessarily how it's going to work out.
MACK is out of the smaller/shorter height struts ( ST-11 ), got the intermediate height ( ST-21 ) and I am concerned they are Too tall but wont know till I get the frames notched to accept the stuffing tubes ...
The ST-21's may turn out to be the best choice !
ST-11 Diameter: 1/8" Prop Size: 1-3/8" Dia.
ST-21 Diameter: 1/8" Prop Size: 2" Dia.
ST-31 Diameter: 1/8" Prop Size: 3" Dia.
Old Jan 31, 2013, 11:07 AM
oldtribefan is offline
Find More Posts by oldtribefan
oldtribefan
oldtribefan's Avatar
United States, GA, Kennesaw
Joined May 2007
Nice progress on the framing, Tim. The Mack products look great!
oldtribefan is offline Find More Posts by oldtribefan
Old Jan 31, 2013, 03:47 PM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Looks very well done. Just like a kit out of the box.
Gravman is online now Find More Posts by Gravman
Old Jan 31, 2013, 03:53 PM
the goon is online now
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Tim,
Very nice .
Mark
the goon is online now Find More Posts by the goon
Old Feb 01, 2013, 09:46 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Tim- remember that struts cannot be symmetrical, when used with parallel shafts and a non-flat bottom... Unless you want to set their bases into cutouts in the bottom...
patmat2350 is offline Find More Posts by patmat2350
Old Feb 01, 2013, 10:14 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Dumas offers one cast strut. For a 3/16 shaft, 1-1/4 drop.
woodybob is offline Find More Posts by woodybob
Old Feb 01, 2013, 10:45 AM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Strut height
Looked at Dumas, but the stuffing tubes, props, dogs and shafts I have are all 1/8 so its 1/8 struts we need ..
The Dumas 1/8 struts are plastic, didnt want to go with that this time.
A fellow member ( Gravman ) has sent some of the next size down MACK struts to me, when they arrive I'll put them on and we'll see if it looks better ( reduces the distance from the prop tips to the hull bottom ).
Right now the tips would be pretty low in the water, a strike could be a real possibility ( )
Please see pic, there is fully 1/2 inch from the prop tip to where the hull planking will be, seems like that should be reduced..
Old Feb 01, 2013, 11:38 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Tim- What I mean is that the shafts will need to be splayed in the plan view if using these symmetrical struts... or the shaft will have to fit the strut bearings like a hotdog in a hallway, to avoid binding.
In the real world, the shafts will (usually) be parallel in the plan view, and the struts will be handed.
This is true for any hull having deadrise ("dihedral", looking forward).
All that said... it'll be fine! You'll have to rotate each strut about the vertical axis... the angle in the profile view will now be slightly off 10, and the strut itself will be slightly angled to the flow of the water... small issue on a model, if you're not a perfectionist.
How much? I drew up an example in CAD... 10 strut, 10 per side deadrise, and the bottom at 10 going deeper forward. The struts had to be rotated about 1 to bring the shafts parallel... you'll never see it!
OK, I'll go back to sleep now...
Discussion Lindberg Chris Craft Sport Fisherman lyman135 Scale Boats 75 Feb 15, 2013 07:46 AM
Video Dumas Chris Craft Commander Tim B. Dock Talk 0 Jan 19, 2013 09:27 AM
Video Chris Craft Monterey model built in 1954 Tim B. Dock Talk 0 Jan 09, 2013 02:35 PM
Wanted Lindberg Chris Craft Sport Fisherman Plans englishjw Boats (FS/W) 2 Aug 12, 2012 09:17 AM
Scratch built Sport craft flies Bob Baker Sport Planes 8 Feb 21, 2003 02:59 PM
