Old Jan 24, 2013, 01:26 PM
GaryX1001 is offline
Find More Posts by GaryX1001
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
using 2 lipos in parallel
hi guys,
i really have a noobish question.
i might have to use 2x 6s lipo batteries (2x the same battery) in parallel to have the double capacity.
is there anything important i have to look at?
do i have to balance-charge both together as one big battery or is it ok to balance charge each and then simply connect to the Y-wire?
is there a need to do anything with the balancer wires? i saw pictures where people connected these wires for some reason i dont know.
if i forgot anything please let me know, this is the first time i'm gonna try that
GaryX1001 is offline Find More Posts by GaryX1001
Old Jan 24, 2013, 02:22 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Running batteries in parallel is fine if they're the same voltage (i.e. same cell-count), and is best if they're same spec. with the same usage history. You don't do anything with the balance wires. But you need to check that your model can handle the extra weight, and make sure the c of g is still correct.
Charging in parallel is okay if you have the right balance board that'll take your balance leads and main leads together. But you don't have to parallel charge just because you've used them in parallel. Whether you do or not probably depends on whether your charger can handle the double load, and whether you want to save time and hassle compared with two separate charges.
abenn is offline Find More Posts by abenn
Old Jan 24, 2013, 02:55 PM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
thanks alot, thats all i wanted to know!
Old Jan 28, 2013, 03:34 PM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
ok, i'm having a question:
when i use parallel setup with 2 batteries, powering 2 EDF units, when both motors together go around 120amps, are the amps split on the parallel battery setup, so every battery draws 60A?
i thought about connecting single batteries to each EDF unit but didnt know how to solder the BEC power wire to both..
i never had a dual battery setup, thats why it confuses me
Old Jan 28, 2013, 03:40 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
normally for 2 motors, if you use 2 Lipos, you want to use parallel so both motors see 1 battery. It's better in terms of synching up the rpm on the motors.
anyways, if the draw is 120amps...yes each Lipo would see around 60amps- also to that, you've also doubled up on the mah, so you can pull more.
for example if you have a 1000mah 20c, you can safely full 20amps
if you put 2x 1000mah 20c, you can now safely pull 40amps.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Jan 28, 2013, 04:07 PM
Builder & Pilot
GaryX1001's Avatar
Germany
Joined May 2009
cool, thanks!
Question Can you charge 2 6S Lipo in parallel if both 6S are 2S+4S wired in series? os2 Batteries and Chargers 7 Dec 03, 2012 09:55 PM
Discussion Using 2 lipo packs in parallel Absolut Beginner Training Area (Aircraft-Electric) 11 Mar 17, 2009 10:06 PM
Benefits or Downfalls to using two lipos in parallel? mrbaseballny Electric Ducted Fan Jet Talk 6 Sep 24, 2005 08:19 PM
Using 2s Lipos in Parallel Battfly Batteries and Chargers 2 Jan 11, 2005 07:52 PM
LiPo Charging of packs used in series/parallel and multi cell pack Ignition Video hoppy Batteries and Chargers 0 Apr 05, 2004 11:57 PM
