Old Jan 24, 2013, 10:51 AM
dk31 is offline
Find More Posts by dk31
dk31's Avatar
Athens
Joined Oct 2009
Question
How to make a Fiberglass slip tube
Hi everyone. I am completely inexperianced with fiberglassing and I thought I could start gaining some experiance by making a slip tube for a wing joiner (I will probably need one in the near future).
So, what materials do I need and is there any guide or video link to help me?
dk31 is offline Find More Posts by dk31
Old Jan 24, 2013, 11:31 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Alot of these are made with molds that are metal or composite on the outside (perhaps made with a piece of brass tubing and splitter plate) and often times silicone is used to press the inside of the layup.
Search here for "Silicone Press" molding, try the F3X forum looking for "joiner construction" and you'll likely find something. "Bladder molding" will net you alot of hits but many of the joiners are built this way as well.
Here's a brief example of a search output...
http://www.rcgroups.com/forums/showthread.php?t=1151471
tom43004 is offline Find More Posts by tom43004
Old Jan 24, 2013, 12:12 PM
kcaldwel is offline
Find More Posts by kcaldwel
The post-truth world
kcaldwel's Avatar
Joined Jan 2007
I just made some using Dr. Drela's instructions. I used either thin painter's polyethylene drop cloth or waxed paper (both about 0.013mm or 0.0005" thick) for the inner release layer, rather than 0.0005" mylar he calls for. Both released fine, and just required some poking to get out of the inside.
The ones I just made had about 7 wraps of the 1.7oz./yd^2 Kevlar and 0.75 oz glass sandwich. I used a strip cut from the polyethylene drop cloth to wind on the outside. I didn't use the cabosil to get it started, just picked up the edge of the glass and got it on the tube as straight as I could.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Jan 24, 2013, 02:13 PM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
Thanks for the replies. I have to study a little what you ve said (too many unfamiliar words) and I will come back
Old Jan 24, 2013, 06:10 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
Hi dk31, I'm doing a tiger 60 bash and I made a fiberglass sleeve off the 3/4" aluminum tube for slip on wings. Total cost was about $20, works great and easy to do, includes the tube.
See the build here: www.rcgroups.com/forums/showthread.php?t=1786693
Leroy
Leroy G is offline Find More Posts by Leroy G
Old Jan 25, 2013, 02:14 AM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
@tom43004
I think that you refer to how to make/mold the joiner itself. I am going to use a bought CF tube as joiner and just want to make myself the slip tube (the "nest" for the joiner that will be built in the wing)
@kcaldwel
So if I got it right, the order of layers from joiner and out are:
-vaseline
-mylar or thin polyethylene drop cloth
-wax (what type of wax? any link would be greag
-7 wraps of Kevlar and glass sandwich (Is Epoxy aplied here? If yes, over the glass surface or both Kevlar and glass? )
-polyethylene drop cloth strip
-masking tape
Is that right?
Old Jan 25, 2013, 02:28 AM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
@Leroy
So, if you ignore the first attempt, your method would be:
-Clear packing tape on the joiner
-Wax on the tape
-around 6 wraps of glass soaked in epoxy
Is that correct?
Also, I forgot to ask before, do you need liquid epoxy? I have the common gel-like 30min epoxy, would that do the job?
Old Jan 25, 2013, 11:05 AM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
Originally Posted by dk31 View Post
@tom43004
@kcaldwel
-vaseline
-masking tape
Is that right?
Not quite. I waxed the CF joiner tube a couple of times with carnuba car wax, just to keep the epoxy from sticking on the end I was handling. Then a thin layer of vaseline in the area where the lay-up will be. Then a straight wrap with either drop cloth or waxed paper that overlaps on your tube slightly, and is maybe an inch longer than your cloth piece you are going to roll on.
I wet out the Kevlar/glass cloth sandwich with laminating epoxy while it was laying flat on a piece of glass, but a kitchen cutting board would work. You might need something thinner than the common tube-style epoxy to easily wet out the cloth. You could just use just 2 oz. glass on a bias (45 degrees), rather than Kevlar/glass, but Kevlar is much lighter and stronger for this application.
Pick up the 1/2" extra of the thin glass, get the wrap started on your waxed paper wrapped CF tube, and roll it all onto the tube as shown in Dr. Drela's drawings. Wrap with a spiral strip of polyethylene maybe 1" wide, and then another wrap with a stretchy tape like electrician's tape. Let it cure at room temperature.
It slides off pretty easily on the layer of Vaseline, and then you have to poke the waxed paper out from the inside. The resulting tube is about 0.001" over-size on your CF tube, which is nice fit. Packing tape would make a looser fit, and maybe wouldn't slide off as easily as the Vaseline layer does.
Kevin
Old Jan 25, 2013, 02:18 PM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
Thank you for making it clear. I will start gathering information where to find all the materials locally
Old Feb 02, 2013, 10:42 PM
AleG is offline
Find More Posts by AleG
AleG's Avatar
Bangkok
Joined Oct 2007
When I had to make a fiberglass tube I used a similar technique to the one in post #3, but instead of rolling the last plastic layer around the mold and fiberglass I just folded it around and clamped the two ends in between two pieces of wood pressed hard against the mold.
The advantage I see in doing it that way is that it's easier to squeeze the last layer to remove as much excess resin as possible; just clamp it and pull on the ends to tighten the material over the mold.
Of course there's a small ridge along the length of the final shape but it's easy to remove by sanding, or it won't bother at all for the intended use.
AleG is offline Find More Posts by AleG
Old Feb 11, 2013, 03:17 PM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
Material gathering will delay a little as there are only few sellers and they're far from where I live... So I decided to give it a try with what I have in hand, for educational purposes
It went like this:
1.Vaseline on the tube --> not exactly a uniform layer. I spread it with a piece of cloth, trying to keep a thin layer equal around the tube, but it spreads like more here-less there.
2. One wrap (with a little overlap) of Plastic drop cloth. It was a very very thin cloth that resembles food storage film
3. Ten wraps of 0.75oz fiberglass. I mixed some regular epoxy with alcohol and aplied with a paint brush
4. One inch strip of drop cloth-spiral around the tube
5. Electrician's tape
Release of the tube was very easy, inner drop cloth came out easily and the slip tube makes a perfect fit with the alu tube.
What went wrong, is that the outer drop cloth spiral got stuck on the outer of the slip tube, and I had to peel it off bit by bit, like skin under the summer sun. Also the outer surface is wavy.
Next attempt will be with thicker drop cloth, heavier Fiberflass and maybe squezzing the excess epoxy off while rolling the fiberglass...
Discussion How To Make Molds - Composite Gliders SOOFLY Composites Fabrication 12 Jun 02, 2015 01:42 PM
Question Carbon wing joiner: diameter? How make outer tube? sroge The Builders Workshop 10 Jan 25, 2013 02:38 PM
Wanted someone to make vacume fiberglass moulds for custom fusees brojo FPV Equipment (FS/W) 0 Jan 06, 2013 09:59 AM
Discussion Easiest way to make a fiberglass tube? gobigkahuna Composites Fabrication 29 Mar 12, 2010 09:19 AM
Making fiberglass tubes dbaya Composites Fabrication 6 May 14, 2005 09:10 AM
