Old Jan 24, 2013, 09:35 AM
vinnieg is offline
Find More Posts by vinnieg
vinnieg's Avatar
United States, NJ, Edgewater
Joined Feb 2012
Measuring motor RPM from recorded motor sound using free software
Im looking for a way to measure the RPM of my motor by analyzing the sound file. By measuring the RPM and the voltage drop we can intern calculated the KV of the motor. I did find this old post that has some good information but would like to use open source software that is not system dependent so that anyone can use it. Audacity seems to fit these requirements and runs on Macs, Windows and Linux.
So far I have the motor sound recorded and the sound sample imported into Audacity as a WAV file. Can someone provide clear directions and a technical explanation on how to measure the RPM from here ? I guess this would requires some noise filtering and maybe some signal transforms ?
I thing the overall process would be :
1. from the recording, isolate a clean sample of the sound to analyze which can be done from visual inspection of the WAV file
2. run a filter to remove noise (Low pass filter or an amplitude filter??)
3. run some type of transform to easily identify the prop frequency (spectrum plot ?? )
vinnieg is offline Find More Posts by vinnieg
vinnieg is offline
vinnieg's Avatar
Joined Feb 2012
reserved
Old Jan 24, 2013, 10:45 AM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
http://www.rcgroups.com/forums/showt...t=interest+way
modisc is offline Find More Posts by modisc
Old Jan 24, 2013, 10:52 AM
vinnieg is offline
vinnieg's Avatar
Joined Feb 2012
please see my original post. It already has a link to your thread.
Old Feb 01, 2013, 06:16 AM
juuuut is offline
Find More Posts by juuuut
Joined Dec 2010
Hi,
why recording the sound ..
i use this free prog http://www.zeitnitz.de/Christian/scope
if you go to frequency tab you will find a main frequency that you can also clean up with a low or high pass filter.
regards
feix
juuuut is offline Find More Posts by juuuut
Old Feb 01, 2013, 10:00 PM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
Tnx for that link, J!
rusty case is offline Find More Posts by rusty case
Discussion Free and easy-to-use 2D CAD Software? sroge CAD/CAM 9 Nov 03, 2013 12:45 AM
Discussion Calculate speed from sound recordings using Doppler shift bastian74 Power Systems 0 Sep 14, 2010 11:11 AM
Alert My new test stand measures effciency by using torque and rpm measurements. simo10 Power Systems 37 Aug 05, 2007 07:01 PM
Discussion Measuring RPM from brushless motor lead Ralph Weaver DIY Electronics 3 May 11, 2007 01:47 PM
Free program to measure rpm using sound? Nicke Power Systems 18 Mar 27, 2005 11:59 AM
