Old Jan 24, 2013, 08:15 AM
mongdex is online now
Find More Posts by mongdex
If it flies, I like it.
Thailand, Sing Buri, In Buri
Joined May 2012
Is this a good FPV system?
Is this a good system?
http://www.hobbyking.com/hobbyking/s...SC_520TVL.html
What else do I need when (if) I buy this?
Thanks.
mongdex is online now Find More Posts by mongdex
Old Jan 24, 2013, 08:22 AM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Check your link.
PiperCub49 is offline Find More Posts by PiperCub49
Old Jan 24, 2013, 11:33 AM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
Thanks.
Without more information is difficult to answer. What is your aircraft control system, 2.4 gHz, 72 mHz, UHF? What is the RF enviroment where you're flying? How are you going to view the video picture? monitor, goggles? How will you mount the Video board camera on the plane/truck? (HK has board camera mounts) Pan & tilt or fixed? (servos). You see what I mean on the information.
1fullbird is offline Find More Posts by 1fullbird
Old Jan 24, 2013, 12:44 PM
Varmit is offline
Find More Posts by Varmit
Spads, Balsa & Foam
United States, IA, Newton
Joined Oct 2012
I bought that exact same kit. I use it for my Quad Copter for scouting farm fields and it works fine for that. But like everyone says there is a lot of other factors that will affect it works for you.
Might need a filter if you are using it with a 2.4...
Varmit is offline Find More Posts by Varmit
Old Jan 24, 2013, 01:56 PM
f2001m is offline
Find More Posts by f2001m
f2001m's Avatar
Joined Feb 2012
check this review from RCModelReviews
Preview: unboxing the 900MHz FPV video transmitters from HobbyKing (5 min 46 sec)
and this
Flight test of the HobbyKing 200mW 900MHz FPV video system for RC planes (7 min 55 sec)
f2001m is offline Find More Posts by f2001m
Old Jan 24, 2013, 04:10 PM
JoeyJoyce17 is offline
Find More Posts by JoeyJoyce17
JoeyJoyce17's Avatar
Canada, BC, North Vancouver
Joined Dec 2009
Is it compatible with fat shark goggles?
JoeyJoyce17 is offline Find More Posts by JoeyJoyce17
Old Jan 24, 2013, 04:55 PM
Joined May 2012
using it with JR 72mhz.
Old Jan 24, 2013, 05:45 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
1.2ghz is a much better frequency (at least here in USA) because of the very low background noise and its ability to penetrate through objects.
Since you are using 72mhz, you don't have to worry about interference.
Actually, you could get that kit since it has a good camera and a receiver and also buy
http://www.hobbyking.com/hobbyking/s...700mW_FPV.html
Im 85% sure that the receiver and the 1.2ghz vtx work together, I have to check that to be 100% sure though.
Since you live in Thailand, I don't think that the authorities are too concerned what radio frequencies you are using but its still a good idea to check what frequencies you can legally use.
Ok, I checked it and ch4, 5 ,6 and 7 on the receiver work with the 1.2ghz vtx.
Some people have complained that the antenna that comes with the 1.2ghz vtx isn't that good so you may want to spend 20 minutes building a inverted vee antenna.
Koo is offline Find More Posts by Koo
Old Jan 24, 2013, 06:42 PM
1fullbird's Avatar
Joined Nov 2011
900 mHz Video will work fine with it. Here is a white paper from DPCAV on 900 mHz:
http://www.dpcav.com/data_sheets/whitepaper_RFI.pdf
Old Jan 24, 2013, 06:45 PM
Joined May 2012
Will this thing work with 72mhz radios?
http://www.hobbyking.com/hobbyking/s...ch_CCD_Camera_
Old Jan 25, 2013, 05:30 AM
jhebbel is offline
Find More Posts by jhebbel
"Watch this!.... Oh crap"
jhebbel's Avatar
United States, FL, Seminole
Joined Jan 2012
Of course, still alwayse a good idea to add a LPF though
jhebbel is offline Find More Posts by jhebbel
Old Jan 25, 2013, 05:38 AM
jhebbel is offline
jhebbel's Avatar
Joined Jan 2012
the reason 1.2 is so clear is probably because 1.2 is illegal here in the us :-P At least all the vtx ive seen fall into the banned frequencies.
Correction, I found one that has ONE channel legal in the US but it still requires an amateur radio license
Old Jan 25, 2013, 08:28 AM
Koo is offline
Koo
Koo
Koo's Avatar
Joined Mar 2012
Just remember that if you buy a 100 or 200mw vtx dont expect to fly past a mile
And jhebbel, there is actually two channels
Old Jan 25, 2013, 10:11 AM
jhebbel is offline
jhebbel's Avatar
Joined Jan 2012
The one i found only allowed one wit ha ham lic. still would rather have a wider freq array to choose from in case a channel has interference in an area. Personally i've never had an issue in the 5.8GHz and while its range is shorter than uhf/vhf, I can still get several miles and the picture quality is a major difference.
Also, antennas play a much bigger role in range than power, Since to double your range you have to at least quadruple the power output, but this usually means heavier equipment and could lead to blead into your radio frequency. it is much easier and safer to increase range by using polarized antenna and directional instead of omni's. You can easily get 5 or so mile with clear line of site on a 100mw
Question Do good Hitec HS-82mg servos sound like this? Saxguy1000 Power Systems 27 Jan 23, 2013 09:46 AM
Discussion Check out this radio system rcjarvis UAV - Unmanned Aerial Vehicles 1 Jan 21, 2013 09:51 AM
Question seeking a good heli stabilization system for FPV/photo AlCapone Electric Heli Talk 4 Apr 13, 2010 07:52 PM
