Old Jan 24, 2013, 07:01 AM
pyrohaz is offline
Find More Posts by pyrohaz
Joined Jan 2013
Thrust and movement
Hey guys, I have a trolley with a mass of about 80kg on castors (125mm, able to handle up to 100kg), and I want to make this a propellor powered car.
What I want to know though, I have a 3.2kw Brushless motor with a KV rating of 230, along with a 19x10 prop. I'm running the whole electrics system off 24v with a maximum supply-able peak current of 480A, My ESC is rated at 100A.
How can I know whether this setup will be able to push my system or not? 3.2kw of motor seems one hell of a lot as I have built go karts and other such projects on just 500w successfully.
The trolley has to be air powered.
Cheers, Harris
pyrohaz is offline Find More Posts by pyrohaz
Old Jan 24, 2013, 02:51 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Best to make it simple. Find out how much force is needed to move the trolley. Then find out how much thrust the 19x10 prop will put out. Depends on the prop design, but typical of a 19x10 is around 17 to 18 pounds of thrust between 7000 to 7500 rpm.
At 24 volts, and 230kv equals about 5500 rpm. So might be nice to gear it, to get a little more rpm. It should not come close to the power rating of the motor, unless used with a larger prop.
I don't have numbers on a 19x10 at such low rpm, but I figure it would move the trolley.
Roto Rob is offline Find More Posts by Roto Rob
Old Jan 24, 2013, 09:01 PM
pyrohaz is offline
Joined Jan 2013
What would be the best way to calculate the required force? I don't really have any form of force measuring equipment. If the trolley was literally being dragged along the floor, I could use the coefficient of friction equation but i'm not sure how to calculate this using castors.
Anyone know how?
Cheers,
Old Jan 24, 2013, 09:24 PM
pyrohaz is offline
Joined Jan 2013
I'm not too up on mechanics but I know that the hardest part will be overcoming the static friction.
Knowing that F=uN (u being coefficient of friction)
The coefficient of friction for a ball bearing is apparently around 0.0015,
N=mg with no vertical net force so n = 80*9.81 = 784.8N
Now knowing that the only main opposing force is friction (not accounting air resistance which is pretty mega), Fr = 0.0015*784.8 = ~1.2N which seems awfully small!
Old Jan 25, 2013, 02:32 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
If you can easily push it with one finger, it should be fine. That is unless you have very strong fingers.
Sold AEO Head Movement Tracker X-GYRO 1000 Art Newland FPV Equipment (FS/W) 6 Apr 04, 2013 10:51 AM
Question UMX P51 motor and gearbox thrust karfrik Scratchbuilt Indoor and Micro Models 9 Jan 21, 2013 07:48 PM
Help! Strange gimbal movement - ideas ?? ed_jza80 Aerial Photography 8 Jan 09, 2013 12:58 PM
Discussion Strange gimbal movement - ideas ?? ed_jza80 Multirotor Talk 6 Jan 08, 2013 03:47 AM
Question Servo linear or rotary movement fauconnier Micro Helis 1 Jan 03, 2013 01:28 PM
