Old Jan 24, 2013, 06:31 AM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
Help!
DIY Brushless motor gimbal, need help sourcing parts for gimbal
Need some help from a fellow DIYer or engineer parts guru.
In photo below labeled
1 in pink. Any one knows the name or where I can find this alloy motor or case housing?
From the screw layout at the back it looks like it has a regular motor screwed on in side it, It maybe a custom part or off the shelf part or motor.
need to know where i can source it.
2 in green. what is this joint called?
I want to source a similar joint like this, need to know whats the proper name for these type of joint as I think that they are out there, just need to now what they are called so I can run a search.
The needs from this is for my personal use, as a fellow DIY guru who likes to build his own stuff.
Any one with the knowledge or knows where I can find similar items, please do chime in.
hexa is offline Find More Posts by hexa
Old Jan 24, 2013, 07:17 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
2: looks to be a custom extruded aluminium L angle.
if you have a cnc machine, then you could make something similar.
for diy'ers, best option is to just use standard L angle such as this
<edit> if you see something similar in this lot, then maybe could use it instead
Mike Barton is offline Find More Posts by Mike Barton
Old Jan 24, 2013, 07:43 AM
hexa is offline
hexa's Avatar
Joined Nov 2010
Great thanks for this info. Now i have a some items i could manipulate. thanks
Old Jan 24, 2013, 09:19 AM
darthvider is offline
Find More Posts by darthvider
China, Guangdong, Shenzhen
Joined Dec 2010
1 it is a custom motor
2 it is a custom extruded aluminium L angle.
darthvider is offline Find More Posts by darthvider
Old Jan 24, 2013, 11:12 AM
alfi666 is offline
Find More Posts by alfi666
Joined Nov 2012
1, I believe its a standard hobby motor in some aluminium can.... If you plan to DIY, then you don't need it.. use the mounts on motor directly.
alfi666 is offline Find More Posts by alfi666
Old Jan 24, 2013, 04:47 PM
hexa is offline
hexa's Avatar
Joined Nov 2010
r4I have sourced 2 the L bracket, very easy to sort out.
Now 1 is the brain buster, i shall try to find some one with a lathe to cut one like it.
I like this motor drum style as it will make building the gimbal much easier,
Old Jan 26, 2013, 08:33 PM
vip is offline
vip
Find More Posts by vip
vip
United States, WA, Seattle
Joined Jan 2012
where in the world did you see this DD gimbal?
vip is offline Find More Posts by vip
Old Jan 27, 2013, 01:19 PM
kalleman is offline
Find More Posts by kalleman
Sverige, Västra Götalands Län, Trollhättan
Joined Oct 2006
Here is one place: http://www.rcgroups.com/forums/showthread.php?t=1815204
kalleman is offline Find More Posts by kalleman
Old Jan 30, 2013, 12:27 AM
WBD is offline
WBD
Find More Posts by WBD
WBD
Carbon Fiber Geek
WBD's Avatar
United States, TX, Irving
Joined Feb 2012
Ive been researching this gimbal on a french forum and I think a Russian website.
http://www.simplebgc.com/about/
Also see here
http://fpv-community.de/archive/index.php/t-15899.html
The motors are standard motors that have been disassembled and rewound from what I interpreted. I'm subscribing to this thread because I want to DIY a BLDC gimbal as well.
YouTube copter38 there are some videos showing it in use. It is very impressive.
The gimbal is also on pre-order here:
http://www.fpvmodel.com/SBGC.html
WBD is offline Find More Posts by WBD
Old Mar 12, 2013, 06:38 AM
Ryan Thomas is offline
Find More Posts by Ryan Thomas
Ryan Thomas's Avatar
Randburg
Joined Jul 2008
I have one!!!
I love this new tech!!
I just tested the YUN-1 Brushless Gimbal from fpvmodel, have not had time to tune but I don't know if I have to!!
YUN-1 Brushless Gimbal (0 min 0 sec)
(still processing)
Ryan
Ryan Thomas is offline Find More Posts by Ryan Thomas
Old Mar 12, 2013, 06:20 PM
Flying_Flair is offline
Find More Posts by Flying_Flair
United Kingdom, England, Hemel Hempstead
Joined Feb 2010
Hex, what did you source for the L bracket, was it just standard extruded aluminium or did you find a ready made bracket
malcolm
Flying_Flair is offline Find More Posts by Flying_Flair
Old Mar 12, 2013, 10:31 PM
hexa is offline
hexa's Avatar
Joined Nov 2010
malcolm
I found L brackets on ebay http://www.ebay.co.uk/itm/3904472733...84.m1438.l2649
the seller has various size
Old Apr 13, 2013, 02:59 PM
Greg Nuspel is offline
Find More Posts by Greg Nuspel
Canada, BC, Duncan
Joined Sep 2011
That motor may be a Maxon or some other motor like one from a vcr tape head. There are so many brushless motors out there these days.
Greg Nuspel is offline Find More Posts by Greg Nuspel
Old Apr 13, 2013, 03:08 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You can use pretty much any brushless outrunner, but you need it to be a really low kv, or you need to rewind them with alot more turns of wire to make it a lower kv.
The motors I just picked up at 70 turn outrunners.
wparsons is offline Find More Posts by wparsons
Discussion WKM to HoverFly Gimbal. Need help kokla55 Hoverfly Technologies 10 Mar 11, 2014 07:51 AM
Help! Need help finding the correct part number for the first generation OS rotary engine murcielago Engines 12 Jan 10, 2013 01:52 AM
Discussion Need Help - GIMBAL or PAN-TILT for SKYWALKER xgimp FPV Talk 0 Jan 05, 2013 11:21 PM
Build Log DIY camera mount/gimbal {and need a bit help} jy0933 Multirotor Electronics 9 Aug 25, 2012 02:43 AM
parts for diy brushless motors? gunwolf DIY Electronics 0 Mar 19, 2005 12:39 AM
