Old Jan 23, 2013, 10:47 PM
m.g. is offline
Find More Posts by m.g.
Joined Sep 2009
wire
I met a man at Hansen Dan last week buy the name of JC if I remember correctly and he had coded wire on his rigging. Where can I buy this type of wire? Thanks Mike
m.g. is offline Find More Posts by m.g.
Old Jan 23, 2013, 11:35 PM
poltergeist is online now
Find More Posts by poltergeist
Kevin Gault
poltergeist's Avatar
Pomona, CA
Joined Apr 2007
I assume you mean nylon coated wire. I use this stuff, it's nylon coated 1x7 Stainless fishing leader wire. http://www.afwhiseas.com/HI-SEAS-Surflon-s/1835.htm
I usually buy it by the spool on Ebay. 30lb test seems adequate for the boats I've used it on.
Kevin
poltergeist is online now Find More Posts by poltergeist
Old Jan 24, 2013, 06:43 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Probably any fishing shop or as you Americans say tackle store.
Nearly all rigging used on Rc yachts would be fishing line of some sort
8387mike is offline Find More Posts by 8387mike
Old Jan 24, 2013, 08:08 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
I used SS wire leader as a similar function to "Rod" rigging on full scale -- not multi-strand nylon covered.
http://www.rcgroups.com/forums/showp...&postcount=227
http://www.rcgroups.com/forums/showt...6#post21100184
jrb is offline Find More Posts by jrb
Old Jan 24, 2013, 08:49 AM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
My personal opinion: Skip the coated wire.
I have had, and seen, to many failures with the coated wire - at the ferrules. Once I ran out of the coated and started using the uncoated wire, I haven't had a failure (and now I have a bunch of extra wire).
Guz is offline Find More Posts by Guz
Old Jan 24, 2013, 09:49 AM
gpzy is offline
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
MG if you want coated wire or any bits for your boat, get to Hansen Dam this Sunday the 27th. Jay king supplies that coated wire to the local sailors. Also Thomas Brighton of Brighton Boat Works will be there sailing, he has all the rigging supplies needed for building.
This Sunday starting at 11, the local club will be racing US1M and RG65s.
Manny
gpzy is offline Find More Posts by gpzy
Old Jan 24, 2013, 11:01 AM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Guz:
Were the multistrand wire failures due to fatigue of the wire strands at the ferrules or did they slip out? You have to strip the coating from the wire where it will be in the ferrule.
I have used both the Sevenstrand Sevalon http://www.fishermanswarehouse.com/s..._detail&p=3203 and single strand ss wire sold for control line planes.
You have to use the correct size ferrules for the size wire you are using and the proper crimping tool to get the proper "bite" on the wire or it will creep under load.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Jan 24, 2013, 11:04 AM
Boomer1 is online now
Find More Posts by Boomer1
Boomer1
Boomer1's Avatar
United States, CA, Temecula
Joined Sep 2009
Wow - never had an issue with the nylon coated leader I use. I am guessing but if you used ferrules or sleeves that were not matched to the test (diameter) of leader or "wire" that could be a possibility. The nylon coating is a safe guard to eliminate a loose strand from tearing or snagging the sails.
Just sayin.............
Boomer
Boomer1 is online now Find More Posts by Boomer1
Old Jan 24, 2013, 11:17 AM
gpzy is offline
gpzy's Avatar
Joined Apr 2007
I think I have seen the coated wire MG saw at Hansen Dam, it is single strand and coated in vinyl.
Most failures I have seen are not broken but bad crimping. And that will happen on any wire.
Old Jan 24, 2013, 11:27 AM
m.g. is offline
Joined Sep 2009
Manny
Thanks GPZY Jay King is the man I met nice guy.
Old Jan 24, 2013, 11:35 AM
gpzy is offline
gpzy's Avatar
Joined Apr 2007
I should be there Sunday with my US1M.
Manny
Old Jan 24, 2013, 11:37 AM
m.g. is offline
Joined Sep 2009
I thank you guys for the info I'm just getting started with this hobby, I'm leaving Gas boats for sailing. I met some guys a the dam last week and they were very good with info. I hope to make it out there soon to see what the clubs all about. I enjoy building and sailing these boats and would like to learn more about them.
Old Jan 24, 2013, 11:42 AM
gpzy is offline
gpzy's Avatar
Joined Apr 2007
Sailing also at Balboa out in the Valley. Saturday the 26th they will be out there with Micro Magics and Victor Models Soling One Meters.
Old Jan 24, 2013, 12:05 PM
woodybob is online now
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Is that a sausage your sailing Manny?
woodybob is online now Find More Posts by woodybob
Old Jan 24, 2013, 12:10 PM
gpzy is offline
gpzy's Avatar
Joined Apr 2007
WB close, it is a Orco Hot Dog
For Sale deans no wire parallel adapter $1.99 each goldsworthy Aircraft - Electric - Batteries & Chargers (FS/W) 7 Oct 19, 2014 11:42 AM
Sold 4 - Yellow Male to Male Servo 24awg Wires - Futaba/JR/Spektrum iiinsaiii Aircraft - Electric - Multirotor (FS/W) 3 Jan 24, 2013 09:29 AM
Sold deans no wire parallel adapter $7 shipped 3drcparts Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 17, 2013 04:35 PM
For Sale your choice of 6 HD twisted wire extensions, 6", 12, 18 or 24", mix and match sizes 3drcparts Aircraft - General - Radio Equipment (FS/W) 0 Jan 17, 2013 01:28 PM
