Well, I recently upgraded to V4 Altimeter. I made one test flight and the result was above my expectations. I praised the V4 in the original Altimeter V4 thread (just about a week ago).
Today, I did my second flight with the new V4 Altimeter on board my hexacopter.
I am climbing straight up on a clear afternoon. Temps are in low 70s (very dry conditions).
All of a sudden I get a voice alert from my OSD system. The max altitude (400 feet) exceeded. I look at the reading and it shows over 600 feet!!! WHAT?
I am confused!.. Then it corrects itself. I am at 100 feet. I climb to 150 feet and stop there. It shows 150feet (-/+ 2 feet) very acceptable. I am just thinking that it was probably the sudden environment change (from my car to outside). I didn't wait much for the sensor to get adjusted to outside conditions.
So in about 10 seconds, the altitude reading jumps back up to 350feet. I land and it reads 200+ while on the ground.
I reset the OSD. It starts at 0 and does the same thing again. Worse than Altimeter V3!!! What the heck...
I stop flying and trying to understand what causes this. I do a few more resets. Nothing changes. It starts at zero feet every time; It is consistent for a few second and then jumps 20-30 even 50feet while I am holding the multi in my hands (No motors are running) So I know it is not about interference.
Then all of a sudden, I realize the sun light hitting the sensor directly from the Horizon. It is a sunset time; and the Sunlight hitting the sensor from the side. I mounted the sensor so that the single-digit screen is facing sideways.
As soon as Sunlight hits the sensor, altitude reading jumps; when I cover it with my hands it goes back to normal.
I then cover the sensor with an electrical tape; fly and sensor functions as expected.
The reason why it fixed itself all of a sudden during the first take off was that I was rotating. And at the moment sensor turned away from the sunlight.
The other day when I did my first test flight, it was after the sunset (almost in dark). So that's why it didn't happen. So I am pretty sure the cause is the sunlight.
Is this a KNOWN issue with this sensor? How? why? Reason!..
Should I change my mounting position or cover the sensor?
Bill, hopefully you will read this soon
