Old Jan 23, 2013, 08:35 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Putting lipstick on a pig!
Brad built this several years back, his first build in over
twenty five years.
It is a scratch build, enlarged 50% of a free flight grasshopper.
http://www.theplanpage.com/Months/20...rasshopper.pdf
Then he decided to change colors in the middle of the build,
then he decided to make it an earlier version..
Our version
It had a Thunder Tiger 36, Hot! It was so over powered
it was just barely flyable. It was flown twice. On the
second flight Brad thought is was going to stall and
powered up and pulled up. The tail hit the ground and
the tail wheel came off fouling the rudder and it turned
hard left and cart wheeled. The only damage was the
tail wheel and one strut mount. It is a tough bird. I thought
it was all over. Any way, the motor is now in an air boat
and he got it out and is going to make it electric.
We weighed all the stuff and added in the motor and esc
and it should be just under three pounds AUW. Over
a pound lighter than original. It had all standard servos
before and now it will have HS-81's.
Tail wheel fix. He recovered it after it was done and the
covering job wasn't that great. It is not damaged so we
are going to go with what we have.
Day one BTW 10/23/2009
This is one plane before the Cub. Note the missing rear window, and
the back, top of the fuselage is flat. It does not have the bungees. on the
bottom, they are on the top.
The battery will be under the wing, with the connection on
the out side. Don't want to butcher it anymore that we have
to.
Kimber is offline Find More Posts by Kimber
Old Jan 24, 2013, 10:20 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
All fixed! Good as new.
Old Jan 25, 2013, 05:45 PM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
Nice looking model, I see no pig in the pictures. The only thing that distracts from it's looks is the glow engine. A 300W electric conversion should make it look and fly a lot better. Save the .35 for something fast...... and save the lipstick for it's intended purpose!
wizard of odd is offline Find More Posts by wizard of odd
Old Jan 25, 2013, 07:07 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
It flew like a pig. It is getting a 550w Powerup 15 Sport.
http://www.headsuprc.com/servlet/the...5-Sport/Detail
The 36 went in an air boat.
Old Jan 28, 2013, 09:01 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
There are to be major changes to this aircraft. there will be pic's
when it is done. No more updates.
Old Jan 29, 2013, 11:48 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
No more updates! I would consider that cruel and inhuman punishment
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my Senator.....
Old Jan 29, 2013, 01:46 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Ken
Trust me, you are going to like this. It will be a "different"
kind of plane. We got the hinge material and wheels today.
Make some wood parts and start putting it back together.
It falls under the "what if" category.
Old Jan 30, 2013, 12:45 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Old Jan 30, 2013, 09:50 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Did the watt test tonight.
Powerup Sport 15, HURC 40a ESC. 3s, 2000mah, 11X7 APC slim.
300W! 25A! WOT! We can use a 13" prop with lots of room, the 11
looks good. We have a 12/6 wood we may check out.
Old Feb 01, 2013, 10:37 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Got it all together, put the heavier wheels back on it to help the CoG.
Making the battery box now. Looks like the AUW will be just under
2 1/2lbs.
Recover one landing gear strut.
Old Feb 01, 2013, 12:02 PM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
So what ever happened to "no more updates"???
Seems like a couple have been posted......
Ken
Old Feb 01, 2013, 01:28 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Ken
Are you married?
Old Feb 01, 2013, 04:01 PM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
Are you married?
'Nuff said And yes to the same woman for 31 years so I should have known better
Ken
Old Feb 01, 2013, 04:35 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Brad and I just did 18.
All that is left is to cut a hole in the side window to get to the
battery connection. CoG is perfect, ended up at 3lbs even.
The glow motor was mounted on wood rails and the cowl was
balsa built up around them. After much looking, thinking, talking.
he made the decision to just cut the whole thing off and start over.
BTW, the struts are functional.
Old Feb 01, 2013, 10:13 PM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
Looking good!
Question How To Put Storage Charge On Lipo With Triton Jr. NEW222 Batteries and Chargers 6 Jan 13, 2013 06:51 PM
Wanted Small cheap camera to put on an RC Car and possibly plane. TheBeastTamer FPV Equipment (FS/W) 1 Jan 04, 2013 05:48 PM
Discussion Lipstick on a Pig Indiana_Geoff Life, The Universe, and Politics 235 Sep 13, 2008 03:54 PM
Video: When Pigs Fly! (Pollutionless Pig Maiden) doc-e Sport Planes 4 Sep 19, 2004 07:00 PM
Lipstick on the mirror William A Humor 0 Aug 26, 2003 01:59 PM
