Old Jan 23, 2013, 09:33 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Chimera VTOL (tricopter tilt rotor)
After trashing the QTR, I now have another VTOL void that needs to be filled.
I do want to release a build log along with plans for this plane in the future provided it performs well. I need someone who wants to convert all the measurements into pdfs.
I designed this thing to have a lower parts count and be more friendly and responsive in hover/ forward flight. It also needed to be a performer capable of decent performance.
So this thing was born, its the first prototype (which will probably be crashed into oblivion) I also wanted the minimal amount of equipment for decent flight performance.
I just tested hover performance with a KK board coupled to one of the tilt nacceles, funny thing is the right tilt naccele is moving on its own from the forces in flight and it not being plugged into anything. tomorrow i'll test forward flight.
I'm planning on going the ardurino route again using Casses code or RC vertt. Although LF seems to have it completely dialed in.
more pics/ video/ frustration to come.
Chimera VTOL Plane hover test (0 min 44 sec)
I had more video but I couldn't use any as it was all to dark, I had to go back outside and re shoot it with a flashlight
also on an unrelated note, CHECK EVERYTHING THAT COMES FROM CHINA. I just got a batch of 100 male/female JST't that have been completely sent with reverse polarity. I set one of my ESC's on fire and lit up the PCB traces on my first KK board on this thing. Also evaporated some wires.
foam and tape is offline Find More Posts by foam and tape
Old Jan 23, 2013, 09:35 PM
beavercreek,ohio
Joined Jan 2007
reserved
Old Jan 23, 2013, 09:36 PM
beavercreek,ohio
Joined Jan 2007
reserved #2
Old Jan 23, 2013, 09:37 PM
beavercreek,ohio
Joined Jan 2007
reserved #3
Old Jan 23, 2013, 09:51 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Fog of war...
ilektron is offline Find More Posts by ilektron
Old Jan 24, 2013, 08:15 AM
v22chap is offline
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
very good F&T keep it going
v22chap is offline Find More Posts by v22chap
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Nice!
Add a couple of layers of foam to the bottom of the front fuse and make it the first water capable VTOL.
If you go with the Wii controls, I'll be glad to help you if I can.
leadfeather is online now Find More Posts by leadfeather
Old Jan 25, 2013, 01:53 PM
beavercreek,ohio
Joined Jan 2007
thanks guys!
LF, yeah I may add some sort of pontoons or extension of the wheel pants to act as stability floats for some water landings.
I'm going to give Cass's V 1.8 code a try. Are all the configurable parameters for adusting servo speed/ orientation under the config.h section of the code?
Old Jan 25, 2013, 02:46 PM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
FT,
Could please post how do you connect all stuff at the wii board?!A drawing something!?
Regards
nadine is offline Find More Posts by nadine
Old Jan 25, 2013, 03:50 PM
beavercreek,ohio
Joined Jan 2007
Originally Posted by nadine View Post
FT,
Regards
sure, i'll get lots of pics of the current one, I may do a assembly guide, although LF pretty much has covered it with his wii F-35
http://www.rcgroups.com/forums/showp...&postcount=384
Old Jan 25, 2013, 05:53 PM
Brandano is offline
Find More Posts by Brandano
Do you get both main rotors to tilt on a single servo and use the tail rotor for yaw or are you using differential tilt for yaw?
Brandano is offline Find More Posts by Brandano
Old Jan 25, 2013, 06:14 PM
beavercreek,ohio
Joined Jan 2007
Differential tilt for yaw controll, the tail motor is fixed. I went this route to reduce parts and it makes the tilt component much stiffer and slop free since each motor has its own servo.
Old Jan 25, 2013, 09:12 PM
beavercreek,ohio
Joined Jan 2007
Hmmm... i'm getting this error message when trying to upload V 1.8 to the board. The code compiles ok though.
I'm also really confused, I need to use VTOL DUAL and I know to uncomment VTOL tail and comment VTOL dual.
Also where do I turn off the elevon mixing, I just have the ailerons where left ail servo is and elevator where right servo is?
thanks
Old Jan 25, 2013, 09:25 PM
Winging it >
Joined May 2006
Originally Posted by foam and tape View Post
thanks guys!
I used the 1.7 in the F-35. I'm not sure if I ever got 1.8 working.
There is no elevon specific option. In the sketch you define how the servo is controlled, from pitch or roll or a combination if you want elevon type mixing.
Old Jan 25, 2013, 10:43 PM
beavercreek,ohio
Joined Jan 2007
Thanks LF, I'll give 1.7 a shot. Do you have a link to the completed code? I'm also using 0023, will 0022 work better or does it matter?
Discussion Tricopter Rudder Motor tilt vs control surface? dcame002 Multirotor Talk 0 Jan 11, 2013 03:08 PM
Discussion VTOL - Tilting rotor shaft? Tomo8281 VTOLs 11 Aug 11, 2011 12:04 PM
Discussion Various tilt rotor VTOL attempts, full size, but interesting. eflightray VTOLs 1 Jun 16, 2010 09:23 AM
Discussion Full 90 degree tilt rotor VTOL numb_thumb VTOLs 19 Dec 15, 2009 12:45 AM
Discussion twin engine VTOL ( tilt rotor ) persianpatient Coaxial Helicopters 0 May 02, 2008 04:18 AM
