Espritmodel.com Heli Air
Old Jan 23, 2013, 06:10 PM
USA, CA, Oakland
Joined Apr 2005
Converting OS 46VR Marine engine to Air
Is it possible to convert an OS 46VR-M (marine) to aircraft use? The goal is to make a rear intake/rear exhaust airplane engine -- to run open-faced.
I have an OS 40VF aircraft engine I can use for parts. I have not purchased the marine engine yet.
I would really appreciate advice from anyone who has done this.
Randy
rbush is offline Find More Posts by rbush
Old Jan 23, 2013, 06:59 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Since the first 7.5cc ducted fan engines were converted marine engines, going the other way should pose few problems. I don't own a 46VRM, but do have a couple of D/F versions. I think the port timing is identical (check the OS parts list to be sure). You'll need an air cooled head and probably a couple of additional head gaskets. If the crank is too short you can use a prop adapter such as was used for D/F engines. Buy some good single strand carbon fiber props - on a pipe it'll turn over twenty grand in the air.
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Jan 23, 2013, 07:48 PM
USA, CA, Oakland
Joined Apr 2005
Thanks Geoff.
I see the 46VF and VRM take the same crankcase. Does that allow me to rotate the case 180deg to get the exhaust to the rear?
Then will the prop drive washer, prop, and nut off the VF fit on the VR crank shaft?
I will be running with no pipe and no muffler.
Randy
Old Jan 23, 2013, 07:57 PM
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
You'll need a head from a VF46, or possibly another 46 from the same era, because the 40VF has a smaller bore. Apart from swapping front and rear ends around you'll need to swap around the conrod so the chamfer on the rod big end faces the crankweb. But that also means you have to swap around the piston because the wristpin has one end blanked off and the blank faces the boost port.
downunder is online now Find More Posts by downunder
Old Jan 23, 2013, 08:46 PM
USA, CA, Oakland
Joined Apr 2005
downunder, thanks for the details.
Can I remove the water jacket part of the head to allow air cooling? Maybe do some machining?
I'm thinking the project is a non-starter if I can't put a prop on the crankshaft. Any ideas?
Randy
Old Jan 24, 2013, 11:51 AM
-insert witty saying here-
Hemikiller's Avatar
Killingworth, Connecticut
Joined Dec 2005
Crankshaft is shared by the VR-M and VR-DF versions, so it might be long enough for a standard prop driver and washer/nut. You'll need to remove the flywheel to see what'll be needed. If it's too short, a "reach through" type prop nut is available from Tru-turn for around $10. I use them for my YS heli to air engine conversions.
Hemikiller is offline Find More Posts by Hemikiller
Old Jan 24, 2013, 12:36 PM
USA, CA, Oakland
Joined Apr 2005
Thanks for the good info.
Randy
Old Jan 25, 2013, 07:03 AM
Two left thumbs
Muncie, IN
Joined Sep 2006
You'll need to ream the prop to 3/8" when using the Tru-Turn adapter. (I'm glad Hemikiller remembered who still makes them!) I think Fox still makes the reamer to do the job fairly precisely. It used to be pretty common. Dooling and McCoy racing engines all used this setup.
Why no tuned pipe? That's where the power is! Annnnnd, it sounds soooo cool when they come on the pipe!
I may have a scrap .46 VRDF if you need parts.
Old Jan 25, 2013, 02:03 PM
USA, CA, Oakland
Joined Apr 2005
Good photo. I may have one of those adapter nuts. I definitely have the reamer.
Good question ---
I need an engine for Control Line Carrier competition, which has two main tasks:
1. Standing-start half mile. I'm looking for 110 to 120mph average speed.
2. A half mile of the slowest flight possible. I'm aiming for 5 to 15 mph. This is done at 60 degrees angle of attack and requires dependable, precise throttle control.
The rules allow a pipe with 10% max nitro, OR unlimited nitro with no pipe -- my choice.
The planes weigh 40 to 60 ounces and are scale models of navy carrier aircraft. Wing spans about 28 to 36 inches. The models and control lines are very draggy. In the flight score, low speed is weighted heavier than high speed. Here's a link with pix: http://www.controllineworld.com/whatiscarriercl.html
So I'm looking for the best compromise. Dependable throttle is necessary when one is flying below stall speed at 2 feet AGL in a varying crosswind (hanging on the prop.)
So I guess a question is how does the 46VRM idle and transition?
Old Jan 25, 2013, 06:30 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Ahhhh.... Well, that's a problem! This engine is timed for very high rpm, but you need a prop much larger than it will handle. Unless they'r now flying ducted fans in Navy Carrier, and you fly something like a Grumman Cougar (Gobs of wing area for slow flight) I'm afraid this engine's impractical.
Old Jan 26, 2013, 01:41 AM
USA, CA, Oakland
Joined Apr 2005
I was afraid of that. My experience is that anything smaller than a 9" dia. prop hurts your acceleration in this event, unless the plane is very light. As a rough guess, a 9X6 turning 20k would give a good average speed.
Sold Zenoah G26 or SIKK CY26 Gas Marine Engine clutch assembly NEW! arnie84 Boats (FS/W) 2 Jan 20, 2013 10:49 AM
Sold Rare Long Discontinued OS Max 10 FSR Marine W/Muffler $75.00 stevster Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 15, 2013 12:33 AM
Sold Rare Long Discontinued OS Max 10 FSR Marine W/Muffler $75.00 stevster Boats (FS/W) 1 Jan 15, 2013 12:30 AM
For Sale OS-46VR Ducted Fan Engine, New $125 WINDSHEAR II Aircraft - Fuel - Jets (FS/W) 0 May 11, 2009 08:21 AM
Question Converting marine engine to air sleepwalker Engines 0 Oct 20, 2008 12:51 PM
