Old Jan 23, 2013, 06:09 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Question
HVLP detail gun recommendation
Does anyone have a good HVLP detail gun they would recommend? I tried following up some of the old links here for cheap Harbor Freight guns, but they don't exist any more. Gravity feed, 4 oz cup, 1mm nozzle is what I'm looking for. I had a Sharpe FX100 that got stolen, and they don't make that one any more.
Thanks!
BillO is offline Find More Posts by BillO
Old Jan 24, 2013, 10:51 AM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
I have been using this one - http://www.harborfreight.com/hvlp-de...gun-46719.html with waterbased paints and Transtar clearcoat. It takes a bit of fussing to get the air/fluid flows correct, but for $35 it is hard to beat. It has a 0.8mm tip so whatever you spray needs to be thin or able to be reduced.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Jan 24, 2013, 10:02 PM
BillO is offline
Firecracker!
BillO's Avatar
I searched the HF site a couple of times and never found this gun! Thanks -- for $35 I might even get one for color and one for clear!
By the way, which Transtar clear are you using? I see there are several different ones. I'm always on the lookout for a decent clear that is isocyanate-free.
Bill
Old Jan 25, 2013, 12:04 AM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Detail gun.
This one may be too small for you Bill. I have one, and they are fantastic!
Extremely economical to use for detailing stripes, wing tips etc.
I have mixed 1 ml of paint with 2 ml thinners for painting tips using a syringe, for example. Almost no waste!
http://www.ebay.com.au/itm/125-ml-Sp...20845232088605
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Jan 25, 2013, 10:22 AM
BillO is offline
Firecracker!
BillO's Avatar
Thanks, that looks very interesting, but you're right it is a bit small. I have an airbrush with a .5mm jet that I use for the small stuff...
Old Jan 25, 2013, 10:52 AM
Elk Grove, CA
Joined Sep 2002
Yeah, their search engine or tagging is terrible. Unless you knew it was tagged as HVLP you would have never found it.
I am using the 7311 Low VOC Euro Classic 2.1 with the 3728 fast activator. It does produce a hard glass-like finish, but because it is so hard it has a narrow 8 hr window to buff out. However......it DOES have polyisocynates in the activator. ( http://www.tat-co.com/product-files/...msds_73261.pdf ) I just use a 3M half face respirator with the organic cartridge. (Caution - they are only good for 40 hrs after opening unless stored in a zip lock bag when not in use).
FC
Old Jan 26, 2013, 11:52 PM
BillO is offline
Firecracker!
BillO's Avatar
OK thanks for that. It is my understanding that a single exposure to isocyanates can cause very serious problems. It is recommended to use a positive-pressure full-face mask with that stuff. Be careful!!
Old Jan 26, 2013, 11:56 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
For what it's worth, I like a 1.4 mm tip for most composites stuff. It works great for PVA, paints, and clear-coats. It's a little small for some primers, but a little extra reducer usually lets it squeak through.
wyowindworks is offline Find More Posts by wyowindworks
Old Jan 27, 2013, 09:35 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Lowes has a small gravity feed HVLP gun that I have been using and love it. Mine has a 1.3mm tip.
Brand is Kobalt, Item #: 301339 and around $40
The spray isn't infinitely adjustable, but the gun has been very reliable, easy to clean, and consistent.
tom43004 is offline Find More Posts by tom43004
Old Jan 27, 2013, 11:00 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Has any one tried this gun?
http://www.harborfreight.com/profess...kit-93305.html
A10FLYR is offline Find More Posts by A10FLYR
Old Jan 27, 2013, 11:31 PM
gizzo is offline
Find More Posts by gizzo
Live slow, Die whenever
gizzo's Avatar
Adelaide, Australia
I have one the same and used it to paint my motorcycle with 2 pack. Worked really well. Throws out a lot of paint if you want it to.
gizzo is offline Find More Posts by gizzo
Old Jan 31, 2013, 08:40 PM
BillO is offline
Firecracker!
BillO's Avatar
I ended up ordering a Sharpe Finex FX 1000 with a 1mm tip, and one of the HF guns recommended by FC.
The HF gun just arrived and I must say it looks cheap (what do you expect for $35!). I had to wipe off some oil that was oozing from several spots; the trigger is too short for me to use 2 fingers; and every moving part feels "scratchy". I'm going to give it a try, and it may work OK, but surely this will not be a gun I enjoy using.
I paid $115 for the Sharpe gun, and everything about it is nicer. What really sold me (aside from the fact I had the previous generation) is that you can get different nozzle sizes, something I didn't see on any other detail gun. If I'm still having trouble shooting System 3 water-reducible clear, I'll get one of the bigger tips and see if that helps.
Old Feb 02, 2013, 11:36 AM
Elk Grove, CA
Joined Sep 2002
Bill:
The instructions say that before using it you should take it apart and clean it. The oil is a rust proofing while it is in transit (in cargo containers sitting on the deck of a ship as it crawls its way across the Pacific!).
The trigger on mine was a little stiff too. A little polishing with 1200 grit wet/dry and it was fine. The cup leaked where it screwed into the base, but a little Teflon plumbers tape cured that.
For only $35 dollars, and less if you use the 20% off coupon, you expect it to be a bit "rough".
FC
Sold Binks MACH 1 HVLP Touch-Up Gun RCFlyer55 Aircraft - General - Miscellaneous (FS/W) 0 Dec 27, 2006 11:05 AM
Sold *** Brand New European Gravity Feed Hvlp Spray Paint Gun *** Rudderman98 Non R/C Items (FS/W) 0 Apr 23, 2006 12:27 PM
Sold " DEVILBISS TGHV-635 HVLP TOUCHUP PAINT GUN" Rudderman98 Non R/C Items (FS/W) 2 Apr 15, 2006 09:52 PM
Sold "devilbiss Exl Hvlp Spray Gun" Rudderman98 Non R/C Items (FS/W) 0 Apr 13, 2006 11:47 PM
Sold HVLP Touch-Up Spray Gun radioflier Aircraft - General - Miscellaneous (FS/W) 0 Mar 14, 2006 03:00 PM
