Jan 23, 2013, 03:50 PM
USA, WI, Wauwatosa
Joined Nov 2007
Motor/esc/servo/rx hobbyking lot--$115
Hi guys, I experienced a shift in priorities. The used equipment below was stripped from a well flying foamie that had begun to fall apart. The new stuff was an entire HK order that I bought to put together a twin, but that's not happening anytime soon. That order was just over $140 with shipping to the US. I'm asking $115 shipped/pp in the continental US, which includes everything in this thread. NO TRADES. If you have any questions don't hesitate to ask.
EDIT: forgot to mention, I really, really don't want to part out. looking to sell this as a lot. Thanks. Make an offer.
Used—
--Turnigy Aerodrive motor, exact specs unknown. Flew a 1.2lb foamie with unlimited vertical on 3s. Probably around 1600kv. No esc connectors.
--HK 30amp esc, worked excellent paired with the above motor. 3A BEC. No motor connectors. Has EC3 and a JST for the lights (see below)
--3 hxt 900 servos, each with one servo arm. Work fine, some light hot glue residue.
--2 3s 1300mah turnigy 20C packs. Work ok, starting to get weak. Charge and balance fine, good for practice.
--Roughly 3 ft of LED string, works great powered directly from a 3s flight pack. Incredibly bright, colors are red, white, and blue. Enough for a small-medium size foamie.
--3 pushrods with clamps.
New, unopened—
--2 Turnigy D2826/6 2200kv motors
--2 Red Brick 50A escs, 2-3s lipo, 3A BEC@ 5V
--Hobbyking UBEC, 5A @5V
--6 HXT900 servos
--Orange RX, DSM2, 6 channel single antennae
--2 Turnigy 3s1p 2200mah lipos, 30C, never charged, stock XT60 connectors
--Package of little clevises
--Pack of bullet connectors, 2.5mm
--Sheet of CA hinge material
--5 wheels, good for foamies/small electrics.
--4 8x4, 2 8x6 APC style props
