Old Jan 23, 2013, 03:14 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Build Log
Bi-wing Flying wing
Ive heard people talk about a flying bi-wing but havnt seen one done so this is my attemp. I model it after the ace combat 3 X-49 night raven.
Im using:
Motor: hexTronic 5g 2000kv
Prop: GWS 5030
Lipo: Turnigy180mah 3s 17gr
Servo: Two hobbyking 2.2gr servos
ESC: Turnigy 6amp 3gr (stripped)
RX: FrSky 5ch 1.8gr
chester2240 is offline Find More Posts by chester2240
Old Jan 23, 2013, 04:48 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Don't know if you're interested,but one of the earliest flying wings was a bi.Some info here.
http://www.rcgroups.com/forums/showt...9#post23895461
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jan 23, 2013, 06:37 PM
GoatZilla is offline
Find More Posts by GoatZilla
GoatZilla's Avatar
Joined Sep 2005
http://www.time.com/time/specials/pa...934567,00.html
GoatZilla is offline Find More Posts by GoatZilla
Old Jan 23, 2013, 08:20 PM
Schoolya is offline
Find More Posts by Schoolya
Schoolya's Avatar
United States, FL, Mayo
Joined Jul 2012
Subscribed. And a EDF would make this that much more awesome.
Schoolya is offline Find More Posts by Schoolya
Old Jan 24, 2013, 02:29 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Originally Posted by GoatZilla View Post
The Dunne wing was described at the time as being "uncrashable"A bit of twist(washout) and plates between the tips.
Subscribed. And a EDF would make this that much more awesome.(quote)
Good idea!
Old Jan 24, 2013, 04:22 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Just a couple examples of successful Bipe Flying Wings.
http://www.rcgroups.com/forums/showp...8&postcount=99
http://www.rcgroups.com/forums/showp...4&postcount=11
DT56 is offline Find More Posts by DT56
Old Jan 24, 2013, 11:19 AM
Joined Jul 2011
Thanks for the links !
An EDF would be really cool and i have a 30mm im not using but for now this is just to see if this works. I would like to make a larger scale X-49 80mm edf since this is so easy to build.
Old Jan 24, 2013, 05:14 PM
Schoolya is offline
Schoolya's Avatar
Joined Jul 2012
If this works for you I think I will be cutting one from foam.
Old Jan 26, 2013, 05:39 PM
Joined Jul 2011
I took it for its maiden today and it flew right out of my hands and up into a tree
Second try went much better i flew it for a few minutes getting a feel for what it can do and cant and its very stable and rolls super fast but it doesnt pitch up well i think that mostly due to it being nose heavy tommaro ill move the battery back and see what happens. If this plane last threw wedsday ill give it a paint job and a canopy i hate the lipo being ontop like it is
I'll try and get my brother to tape a video of it flying!
These are pics after the maiden and some repairs
Old Jan 27, 2013, 01:37 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Can you get the battery between the wings,I bet it will make a big difference to how it flys.
Try to stiffen up the control surfaces,a wire linkage between would be better.
Old Jan 27, 2013, 10:55 AM
Joined Jul 2011
Its alittle to wide but it could i didnt know where the CG would be thats why its on the top but when or if i ever build another one i would put it between the wings.
I'll do carbon wire linkages next time this is working out pretty good the plane is so light 56gr with lipo the foam is holding up fine.
Old Jan 27, 2013, 11:26 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Yes I know its out of this world but would be extremely cool to see.
This is also a Bi Wing.... of sorts.
1320fastback is offline Find More Posts by 1320fastback
Old Jan 27, 2013, 03:50 PM
Joined Jul 2011
Lol what show is that from?
This plane is pretty triky to get flying but when it up its up and easy to fly. I think the best way to take off is full throttle and throw it up at a 60degrees.
Old Jan 27, 2013, 05:20 PM
USA, CA, Oceanside
Joined Jul 2008
Put on your Geek Caps
Its a Romulan D'deridex Class warbird from Star Trek: The Next Generation.
Geek Caps off!
Old Jan 28, 2013, 10:45 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Maybe it's a perspective thing but the gap between the wings looks a little too small. It should be slightly bigger than the chord of your wings. I'd increase it by about half an inch or so.
slebetman is offline Find More Posts by slebetman
Discussion KF Swifty wing - need advice on powering this flying wing bbz Foamies (Scratchbuilt) 3 Jan 20, 2013 02:16 AM
Discussion Topsoaring manta ray flying wing, help wanted guitarcher Flying Wings 1 Jan 16, 2013 02:42 AM
Discussion Bi-Directional flying wing KillerCut Flying Wings 0 Aug 30, 2012 09:08 PM
Video Flying Bi-wing Bugman Jeff Electric Plane Talk 0 Jan 08, 2011 12:15 AM
Discussion Flying Wing bi-plane? Rusty-Gunn Flying Wings 10 Oct 01, 2006 06:29 PM
