Espritmodel.com Heli Air
Old Jan 23, 2013, 02:13 AM
Joined Jan 2013
Servo mod tension mini cp and genius cp.
I know that everyone has seen the servo mod for the mini cp and the genius cp. One of the main topics behind this is the tension on the servo horn. I have found a quick, easy and CHEAP way to add tension to the servo horn. Simply cut out a section of the spring from a ball point pen. Simply place it around the servo horn after cutting the horn with a knife. You can add tension by squeezing the cut portion of the spring. It works great and you don't have to find the super small O-ring that everyone suggests. You also have at least 20 sections from a single spring. If you mess it up or it pops away, you have plenty of extras.
davidkbr6 is offline Find More Posts by davidkbr6
Old Jan 23, 2013, 03:45 AM
Madison WI
Joined Jan 2009
I'm having trouble picturing this. Do you have a photo? Thanks.
jazzjohn is offline Find More Posts by jazzjohn
Old Jan 23, 2013, 06:34 AM
Joined Jan 2013
You can see the cut piece of the spring on the servo. Sorry my pictures are limited to my iPhone. It is just a section of the spring from a ball point pen it is the perfect diameter.
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 471 Apr 26, 2013 05:05 PM
Sold Devention-10 ten channel transmitter w/ genius cp + xtras - $225 greenz Aircraft - Electric - Helis (FS/W) 0 Jan 16, 2013 05:02 PM
Discussion mini cp servo saver mod tension? dreamz123 Micro Helis 2 Jun 16, 2012 06:06 PM
Discussion Will someone with a Mini-cp install the Genius rx-board into the Mini cp? mescalinedream Micro Helis 2 Jan 29, 2012 10:55 AM
