Old Jan 22, 2013, 09:26 PM
rokwell is offline
Find More Posts by rokwell
Joined Jan 2013
Help!
Is my Current Sensor / Data Logger Board broken?
Whenever I plugged the current sensor to the data logger board the Voltage and Current can me worked properly, but other data such as altitude, speed, Gx, Gy, EGTA, EGTB, TempA, TempB are stopped working. If I remove it, all other data will be worked properly again.
This happens with my #1 system (I have 2 systems).
rokwell is offline Find More Posts by rokwell
Old Jan 26, 2013, 03:17 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
That's odd. To confirm, if you move the same current sensor to your second recorder, it logs everything, but when the current sensor is plugged into your first recorder, it only logs current?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 28, 2013, 10:52 PM
rokwell is offline
Joined Jan 2013
Thank you for your reply.
It's now able to use but I have to move it a little bit tight. This may be the problem of the #1 recorder.
I'm now also looking forward to the answering at Ticket #876403
Old Jan 30, 2013, 09:29 PM
rokwell is offline
Joined Jan 2013
Please take response to the Ticket #876403, it's been many days past and I'm waiting for the answering.
Old Feb 01, 2013, 12:50 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Rokwell,
I checked on the status of the ticket. We've been able to reproduce the issue you were seeing per our reply, and we're investigating why this is happening. We'll get this sorted for you as soon as possible.
Site Sponsor
Discussion servo current sensor kills fdr????? johnfly1234 Eagle Tree Systems 11 Feb 01, 2013 09:09 PM
Sold Oracle Data Logger Flight Data Recorder bovick Aircraft - General - Miscellaneous (FS/W) 2 Jan 22, 2013 08:29 PM
Sold Oracle Data Logger Flight Data Recorder bovick Aircraft - General - Radio Equipment (FS/W) 0 Jan 21, 2013 11:43 PM
Sold Oracle Data Logger Flight Data Recorder bovick FPV Equipment (FS/W) 0 Jan 21, 2013 11:40 PM
