Old Jan 22, 2013, 09:17 PM
rokwell is offline
Find More Posts by rokwell
Joined Jan 2013
Help!
Seagull's Transmitter stop working
I have 2 Seagull Wireless Systems and they stop the transmission between the test at around 30 sec to 7 minutes. When I disconnect and reconnect the Tx again it will be worked. I also unchecked the box that tell the recorder to stop logging after the memory is full.
Is anyone knows how to fix this?
rokwell is offline Find More Posts by rokwell
Old Jan 26, 2013, 03:13 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, and sorry to hear about the issue. Is this a 2.4Ghz Seagull system? Also, what is connected to the Seagull transmitter (eLogger or Recorder, and what accessories)?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 28, 2013, 10:49 PM
rokwell is offline
Joined Jan 2013
It is 2.4Ghz 100 mW Tx connected to the Recorder with Temp Sensor, Micro Temp, G-Force, GPS, RPM, EGTA, and EGTB.
But whenever I connected only the Micro Temp and Temp Sensors, it works properly.
Ticket #876403
Old Feb 04, 2013, 02:19 AM
rokwell is offline
Joined Jan 2013
[SOLVED]
I found that the problem was from the GPS sensor - whenever I connected the GPS to the recorder, the recorder will be stoped the transmission.
When I removed the GPS sensor but still connected all other sensors, everything works properly.
However, this problem was occur on the older Software and Firmware. Now I updated the systems to the latest softwate and firmware then everything works properly - using version 10.44.
If I found any problems or any suggestions, I will send the e-mail to you.
I'm very happy to use your systems with your great supports. Thank you very much.
Discussion Seagull's Funfly 3D 46-55. AA5BY 3D / Fun Fly Fuel Planes 6 Mar 10, 2013 02:14 PM
Help! OMG My S023 Stopped Working!! Spirittoo Coaxial Helicopters 1 Jan 12, 2013 10:55 AM
Discussion Waterproof LED's stop working when waterproofing removed. Why??????? panther3001 Night Flying 9 Sep 07, 2012 06:53 PM
Discussion please help hsp warhead transmitter stopped working craigosa Radios 0 Oct 23, 2011 02:24 AM
Help it's stopped working!! rigger Beginner Training Area (Aircraft-Electric) 5 Sep 23, 2005 10:38 PM
