This thread is privately moderated by rctimer, who may elect to delete unwanted replies.
Old Jan 22, 2013, 07:01 PM
rctimer's Avatar
Hong Kong, Pok Fu Lam
Joined Sep 2009
Rctimer f800-m6
Diagonal axis length: 800mm
- Takeoff Weight: 6kg
$1049.99
http://www.rctimer.com/index.php?gOo...t.dwt&gcat=208
CM301 IN STOCK!
Please order it now!
Frank
rctimer is offline Find More Posts by rctimer
Site Sponsor
Old Jan 28, 2013, 03:53 AM
Harpia's Avatar
Brasil, PE, Gravatá
Joined Apr 2004
Nice work. I am planning buy a Rctimer S800.
Edson
Harpia is offline Find More Posts by Harpia
Old Feb 16, 2013, 10:30 AM
Joined Jan 2013
any experiences?
aliche is offline Find More Posts by aliche
Old Mar 20, 2013, 05:37 AM
joecarnine's Avatar
Malaysia, Selangor, Sepang
Joined Apr 2012
Mine is on the way!!!
I think we can also discuss everything about f800 here now!
joecarnine is offline Find More Posts by joecarnine
Old Mar 20, 2013, 08:03 AM
Joined Feb 2008
Yes it is....Double Checked, Tested and Packed Snug as a Bug in a Rug
RYBAT is offline Find More Posts by RYBAT
Old Mar 20, 2013, 09:11 AM
Joined Feb 2008
UAVObjects F800 M6 Build
I'm starting a F800 M6 Build
F800 M6
RCTimer HP 4114 350 kV motors
ArduFlyer 2.5 915 Mhz Kit
Turnigy 9xr with UHF Orange LRS Tx / Rx 8 Channel
CM301 High Precision Gimbal
I'll incorporate the best methods into this build to assist other builders
First things First:
Never drill into the main center section to mount sensors, flight controllers or camera mount....these frames have positive and negative pathways for built-in power distribution and are directly connected to your Lipo Battery
Vibration is the root of all evil...take the time to balance your props properly.
Buy a Digital Voltage Meter....even cheap versions work well...check your connections for Continuity and or Voltage before final connections...doing this will help prevent Magic Smoke
Before doing anything with power....READ THIS FIRST!!!!
http://www.rcgroups.com/forums/showthread.php?t=1840891
Take the time to build, install and use Jabrams " Short Preventer" while performing Bench Work....it will save your equipment
Old Mar 20, 2013, 11:43 PM
jabtyler's Avatar
United States, CA, Oak Park
Joined Jun 2011
waiting for mine in the mail
jabtyler is online now Find More Posts by jabtyler
Old Mar 21, 2013, 12:28 AM
Joined Feb 2008
Yours left China today...I'll have tracking tomorrow I'll email you the number so you can follow..It should arrive Tuesday- Wednesday you should have it Friday-Saturday...Shipment was delayed waiting on radios
Kendall
Old Mar 21, 2013, 10:18 PM
Phantom Flyer
United States, NV, Reno
Joined Mar 2013
Hi Kendall,
I am interested in the F800-M6 and had a few questions.
Could you outline some of the differences between that and the S800?
I did not see on the web site which props it is using - 15" x ??
Are they the same as the S800, interchangeable? Or would I have to use the RCTimer props for replacement?
I would like to use a Naza or WKG FC - any comments on this?
Do you have a recomended battery/batteries for this?
Does the CM301 have its own controller or will it work off the Naza/WKG OK?
Finally - what is the delivery time on these in the US?
Thank you,
Mark
HammonPhoto is offline Find More Posts by HammonPhoto
Old Mar 21, 2013, 10:36 PM
Joined Feb 2008
Originally Posted by HammonPhoto View Post
Hi Kendall,
Thank you,
Mark
Hey Mark,
I can't comment regarding the DJI S800...cause I've never been around one.
Regarding Flight Controllers.... that's up to you...the F800 will fly with any controller your little heart desires... My favorites are OpenPilot and ArduFlyer for different reasons. The standard Props are15 x 5 but, the 4114 350kV can handle larger....on 6S....some guys buy high milliamp 3S lipos and connect in series giving you 6S power.....the motors have "clamp" type prop adapter...and require, inline 3 hole, flat prop hubs... Most guys get excellent performance with the standard props. I receive shipments every 6-10 days. Due to the rapid popularity.. I will begin stocking the F800 M6 , CM301 and the F800 M8 in April.....Shipping from me...coast to coast 2-4 days...usually 3
Hope this helps...
Kendall
Old Mar 21, 2013, 10:50 PM
Lathrop, Missouri, United States
Hey Everyone, RCT just announced that they NOW have IN-STOCK the ESC's to make the 4 RED and 2 GREEN ESC's. At this time they have a limited supply of a little over 100pcs. I do have them on order and will announce when they are in...
Gerry
gjhinshaw is offline Find More Posts by gjhinshaw
Old Mar 22, 2013, 12:37 AM
Joined Feb 2008
Gerry
I have them now....
Old Mar 22, 2013, 01:03 AM
bradbxyz's Avatar
San Diego
Joined Jun 2004
My new F800 ( recieved Monday ) has 2 red and 4 green ESCs. I like it!
bradbxyz is offline Find More Posts by bradbxyz
Old Mar 22, 2013, 09:40 AM
Gimbaled
superdave42's Avatar
morgan hill california
Joined May 2004
Hi Kendall,
Thank you,
Mark
Hi Mark, I am using the Naza + GPS on mine and it's working very well. I'm using a 6S 5,000 battery so far and getting some real good flight times out of it.
The 800 with Naza GPS (0 min 54 sec)
superdave42 is offline Find More Posts by superdave42
Old Mar 22, 2013, 10:46 AM
Mark,
~There isn't much difference between the 2. Now, the DJI does have a plug on the platform where the RCT does not.
~Props are the same.
~Yes, They are interchangeable parts. Is one better than the other? I don't think so.
~The Naza is A LOT cheaper than the WKG as there is only 2 main parts as the WKG has 3. I do think that the WKG is better because it has a separate gyro system. I DO have both and I DO like the WKG better.
~I use 4S 5000mah.
Here are 2 pictures. first is DJI.
Hope this helps!
Gerry
Hi Kendall,
Thank you,
Mark
Build Log RCTimer RCT800 Frame and HP4215 (630KV) mkmkmk13 Multirotor Talk 6 May 05, 2013 09:51 AM
Discussion rctimer dist? Mahskeeter Multirotor Electronics 6 Jan 04, 2013 05:10 AM
Discussion RcTimer Ardu2.5 with octo? fotografmartin Multirotor Electronics 1 Jan 03, 2013 01:58 PM
Discussion BMW F800s 1:1 limbo jimbo Motorcycles 3 Apr 10, 2007 05:46 PM
