Old Jan 22, 2013, 05:34 PM
Spacenutz is offline
Find More Posts by Spacenutz
United States, GA, Warner Robins
Joined Mar 2009
Help!
Quad motor not starting. ESC maybe?
I have a vid to show what's going on. Basically, all motors idle up normally except one. This one happens to be the recipient of a brand new esc. I have calibrated 3 times but the issue remains. I can rapidly go to full throttle and back and it will kick start the affected motor and as long as i don't go back to zero throttle, it will fly just fine. Can anyone tell me what is going on?
Multiwii pro 2.0
20A House ESC all from Witespy.
Video
Multicopter with bad ESC possibly (1 min 10 sec)
Spacenutz is offline Find More Posts by Spacenutz
Old Jan 22, 2013, 07:19 PM
giek2000 is offline
Find More Posts by giek2000
Joined Nov 2008
Dodgy solder joint somewhere.
giek2000 is offline Find More Posts by giek2000
Old Jan 22, 2013, 07:20 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
Is the new ESC identical to the old ones? You don't mix ESC's in a multi rotor so if it's not identical that'll be the reason. Even if it's the same make/model it may not be the same ESC underneath the shrinkwrap
WendoNZ is offline Find More Posts by WendoNZ
Old Jan 22, 2013, 08:10 PM
Joined Mar 2009
I re-soldered the esc to the power distribution board but that doesn't mean something isn't loose on the FC. I'll check that out.
It actually looks different but Witespy says it is the same under the shrinkwrap.
Old Jan 22, 2013, 08:11 PM
Joined Mar 2009
BTW the problem is only when starting the engine, once its going i can complete an entire flight without any problems at all.
Old Jan 22, 2013, 08:54 PM
MayMayDay is online now
Find More Posts by MayMayDay
ParagonUAV
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
Definitely one of those bullet connectors between the ESC and the motor. That twitching is because it can't get the timing through the loose connector to keep it spinning. Had that issue with one of my ESC/motors. Lightly tugged on one of the bullets and the wire popped right out.
As to why it works at high throttle, my guess is that once it gains momentum, the 2 phases of the ESC can keep it spinning even though the 3rd is failing because of the bad connection.
MayMayDay is online now Find More Posts by MayMayDay
Old Jan 22, 2013, 09:54 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Verify solders on your ESC: http://www.rcgroups.com/forums/showp...&postcount=475
Mortimer is offline Find More Posts by Mortimer
Old Jan 23, 2013, 09:04 AM
Joined Mar 2009
That makes sense Mayday. I think i'm just going to ask if Paul will refund that esc.
Thanks Mortimer. That's is exactly what has happened to 3 of my esc's now. The pad gets ripped off and i can't get it soldered back. I may try the hot glue on the two remaining escs so they don't fail too.
Old Jan 23, 2013, 10:30 AM
ParagonUAV
MayMayDay's Avatar
Joined Mar 2012
Do a switch check to make sure it's the ESC. i.e. run the motor on a different ESC and run the ESC with a different motor. If the problem follows the ESC you have a pretty strong case for returning it.
Old Jan 24, 2013, 06:04 AM
Joined Mar 2009
I switched out a brand new spare motor and it did the same thing. I'm just waiting on a response now to return the esc. Thanks for all the help everyone.
Old Jan 27, 2013, 07:53 AM
Joined Mar 2009
I got a new set of HK esc's, flashed them with simonk and now everything works perfectly. I guess it was the bullet connectors on the old esc's. It also fixed a jumpy throttle problem i was having. Its nice to be back in the air thanks for everyones input.
Help! Motor/ESC problem after soldering?? low beeps and motor wont start calle3 Micro Helis 0 Jan 14, 2013 12:58 PM
Discussion Esc not arming? motor won't start. dudly Electric Plane Talk 5 Jan 15, 2012 10:47 AM
Discussion ot? maybe, maybe not but interesting idea fooman2008 Dock Talk 0 Jan 26, 2010 09:19 AM
Discussion Autogyro for AP Maybe? Maybe not. Can Fly Land?? Aerial Photography 3 Jul 11, 2008 01:30 PM
