Old Mar 03, 2013, 05:50 PM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
Originally Posted by Bricobrac View Post
Viacopter version handle the GP2 and maybe even the GP1 (sure for the DIY, for Viacopter gimbal i need to ask Jussi).
It was posted before...
Originally Posted by JussiH View Post
Yes, there is individual front-pieces for all current versions of the GoPro cams. So there will be a version for Hero 1/2 and a version for Hero3.
and
The gimbal that will be launched soon is for GoPro cameras 1, 2 and 3.
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Mar 03, 2013, 06:02 PM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
and
beamen is offline Find More Posts by beamen
Old Mar 03, 2013, 06:13 PM
Movie Guy is offline
Find More Posts by Movie Guy
Movie Guy's Avatar
Delta, BC, Canada
Joined Apr 2004
I *think* the GP 1 and GP 2 are physically the same size. I have a GP2 so I am patiently waiting for that gimbal. I don't know if I have the motor winding gene in me.....
Movie Guy is offline Find More Posts by Movie Guy
Old Mar 03, 2013, 06:18 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Since I have time waiting for the board to arrive, I have been getting all my ducks in a row. Wires, button, gimbals, mounting hardware, and other odds and ends. After reading the tuning manual to the point of memorizing it It is pretty clear that the "Extended mode" for calibration is recommended. With that I was thinking that a level of small size would be pretty helpful. I happen to have an old plastic cheapo level that the bubble chambers pop out of. These little chambers only weigh 1 gram ea. 2 for the long one. I used a small amount of household Goop adhesive and attached one on the lower support arm of my gimbal.
It doesn't do much for aesthetics but it will certainly be functional. It will also allow me to quick reference the gimbal before each flight.
It's a cheap reference idea that could be applied to any gimbal, Just thought I would toss it out there.
power is offline Find More Posts by power
Old Mar 03, 2013, 07:11 PM
Bricobrac is offline
Find More Posts by Bricobrac
E-Copter
Bricobrac's Avatar
Paris / Nice, France
Joined Aug 2002
and
Thanks for the info Miha
Best regards,
Fabien
Bricobrac is offline Find More Posts by Bricobrac
Old Mar 03, 2013, 08:42 PM
which.wabbit is offline
Find More Posts by which.wabbit
Joined Jan 2011
Originally Posted by power View Post
...With that I was thinking that a level of small size would be pretty helpful. I happen to have an old plastic cheapo level that the bubble chambers pop out of. These little chambers only weigh 1 gram ea. 2 for the long one. I used a small amount of household Goop adhesive and attached one on the lower support arm of my gimbal.
I saw these on another gimbal thread and thought they might help with the aesthetics.
Nic
which.wabbit is offline Find More Posts by which.wabbit
Old Mar 03, 2013, 08:53 PM
dmsgodeep is offline
Find More Posts by dmsgodeep
Austin, Texas
Joined Apr 2009
Originally Posted by milouze View Post
Did you bought from CGSshop? 'cause on the board, scl and sda are reversed; that may lead to i2c errors.
Yes...from CGSshop.
Yes...I switched the cables. That wasn't the cause.
Originally Posted by Fredrik R View Post
How long is your cable from the sensor to the board?
I think it was cable length. I am using servo cable wire and I just put a long 18" piece on there to test with. It didn't occur to me that would be the cause.
Now I have about a 7" piece on there. It still goes a bit crazy when I grab the wire...but when I just hold the sensor board...it seems to behave like I would expect, without random movements.
What is the max cable length I should use and is there something better to use than servo cable wire? Do I need something more insulated from outside interference?
Thanks guys.
Brent
dmsgodeep is offline Find More Posts by dmsgodeep
Old Mar 04, 2013, 12:28 AM
SteadiDrone is offline
Find More Posts by SteadiDrone
Joined Sep 2012
Originally Posted by tritan View Post
You are fast to hi-jack this thread but didnt bother to answer any of my emails regarding an interest I had in one of your multis a couple of weeks ago.....
If you claim to be a serious company go and start your own thread instead.
Hello, but sure I did not get your emails, we reply to emails daily.
SteadiDrone is offline Find More Posts by SteadiDrone
Old Mar 04, 2013, 02:06 AM
ultrojo is offline
Find More Posts by ultrojo
ultrojo's Avatar
Malaysia, Johor, Johor Bahru
Joined Feb 2012
guys, help me to choose the suitable rewound motors.
which one good for tilt motor & which one good for roll motor.
1) motor 4006 with 0.21mm copper wire, 130 turns each one pole for nex5n size gimbal or similar
2) motor 4006 with 0.21mm copper wire, 150 turns each one pole for nex5n size gimbal or similar
3) motor 4008 with 0.21mm copper wire, 200 turns each one pole for nex5n size gimbal or similar
thanks in advance.
ultrojo is offline Find More Posts by ultrojo
Old Mar 04, 2013, 02:08 AM
nikivan is offline
Find More Posts by nikivan
Joined Dec 2005
Originally Posted by dmsgodeep View Post
Yes...from CGSshop.
Thanks guys.
Brent
Try soldering 10K resistors in parallel to the I2C pullups on the sensor board.
nikivan is offline Find More Posts by nikivan
Old Mar 04, 2013, 04:21 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Your gimbal looks great - minimalistic and yet fully functional - but it also looks like it's substantial enough to carry something much heavier than a GoPro. Could one that was much thinner (and lighter) still do as good a job? Would it also then work with smaller, lighter motors? I'm constantly on the look out for something as light as possible for the DJI Phantom.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Mar 04, 2013, 05:15 AM
power is offline
power's Avatar
Joined Apr 2003
It is very strong/stiff as it sits, I wanted small but yet I didn't want to get too thin as I have been down that road and things start to move/vibrate. I use a .1875 thickness on the frame since it is not a full box. I would think that going as low as .125 or even .0935 would work. I may try one after I get this one figured out
Old Mar 04, 2013, 05:31 AM
HARWIND is offline
Find More Posts by HARWIND
Mental is Everything
HARWIND's Avatar
Australia, NSW, Termeil
Joined Oct 2011
Been busy over the last couple days and as a result we now have a gimbal.
It is based on RC Timer motors 2830/14, which are still to be rewound. That is the next job on the list. It is nothing fancy, just made up of what I had on hand, all constructed with hand drill, hacksaw and files. Oh, and of cause a big hammer . The whole gimbal with an old beat up GoPro Hero camera, weights in at 305 gms.
HARWIND is offline Find More Posts by HARWIND
Old Mar 04, 2013, 06:20 AM
Fredrik R is offline
Find More Posts by Fredrik R
Joined Feb 2008
Yes...from CGSshop.
Thanks guys.
Brent
I tried a different cable but same length and had zero problem. So It also depends on the cable...
Firs cable I had was a thicker servo cable and that didn't work well. Tried a thinner with good results.
Fredrik R is offline Find More Posts by Fredrik R
Old Mar 04, 2013, 08:20 AM
Austin, Texas
Joined Apr 2009
Ok...good info.
I will try different/better cable and see if that eliminates it.
Thanks.
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1672 Jul 01, 2016 05:42 AM
Yippee! Simple Brushless Gimbal Controller--FPV MODEL fpvmodels Multirotor Talk 3396 Dec 26, 2014 06:23 PM
Discussion A very simple camera-gimbal for Gaui 330xs babanan Multirotor Talk 2 Oct 09, 2013 08:46 AM
