Old Jan 23, 2013, 12:29 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by robin4 View Post
You won't be able to control nick, even if you connect the controller to the mikrokopter fc?
You will need an output that you can use as a pass-through to assign the transmitter channel to both the flight controller and the gimbal control.
Dunno if the MK can be configured for this...
kinderkram is offline Find More Posts by kinderkram
Old Jan 23, 2013, 01:02 PM
yelmarb is offline
Find More Posts by yelmarb
Joined Dec 2012
Could a manual tilt be done with a Naza FC / Futaba S-Bus receiver?
yelmarb is offline Find More Posts by yelmarb
Old Jan 23, 2013, 01:08 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
I need this to be a stand alone device running off a separte reciver for the camera man...
is this possible?
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Jan 23, 2013, 01:10 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Jussi,
Never a doubt that a gimbal like this would be of interest to many!
You made the RCG front page as a HOT thread
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jan 23, 2013, 01:21 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
is this possible?
Steve
Yes!
JussiH is offline Find More Posts by JussiH
Old Jan 23, 2013, 01:22 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Thanks, Jim
I did see it. Last time that happened was when we released the AQ and ESC32...
How is the AQ coming along? Gonna show some video soon?
Best
Jussi
Originally Posted by jesolins View Post
Hi Jussi,
Cheers,
Jim
Old Jan 23, 2013, 02:05 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Hi Jussi,
Ya, this thing has to be hot if RCG says so!
Old Jan 23, 2013, 02:20 PM
robin4 is offline
Find More Posts by robin4
Stavern/Larvik - Norway
Joined Dec 2008
hi
Won't the signals transferred from the mk fc be able to override the signals from controller?
I was thinking of connecting like shown in the attachment.
The wiring with my setup today with regular servoes is basicly the same - just bypass the controllerboard and connect directly to servoes instead of the BL motors..
robin4 is offline Find More Posts by robin4
Old Jan 23, 2013, 02:42 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Yep, Robin - in theory this should work. But only Jussi can tell atm.
Unfortunetely I can't test it for you.
I'm pretty sure Jussi will provide us with some more info soon.
Once the storm has calmed down...
Edit: need to elaborate the above a bit.
When you connect the output of the FC, the internal stabilization takes affect.
Means you'll have the signals of the stabi sensors on the feed for the cam controller.
They simply will fight each other. (That's where the GUI kicks in to adjust these influences.)
For a pass-through of the override channel (usually an AUX on a jog dial or knob of the transmitter) you need to eliminate or at least dampen the influence of the FCs sensors - unless this is a wanted effect.
Example: through the POI function of the AutoQuad you can point your camera at a desired coordinate.
If we combine it with the stabilization of the stand-alone controller we can
- free the FC from doing the stabi job
- overlay the camera controller with GPS based functionality
That'll be a feature every AV artist will be licking his fingers for...
Old Jan 23, 2013, 02:52 PM
robin4 is offline
Joined Dec 2008
Sounds good. Hopefully Jussi can bring some good news on the subject
Think theres alot of mk users out there how'd like to be able to manually control nick - me included
Old Jan 23, 2013, 02:58 PM
DorianJ is offline
Find More Posts by DorianJ
DorianJ's Avatar
Freehold, USA
I'd also be interested in this. Nick control through MK board, for reasons of my own other than the standard 1 or two man operation.
DorianJ is offline Find More Posts by DorianJ
Old Jan 23, 2013, 03:09 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Sure guys, me too!
If you have a button in the MK tools where you say "sensors shut up" to only use the override ... why not.
Not sure if you can tell the MK "your a gimbal port but please do nothing, just listen to my command"?
Ooops: you obviously missed my "Edit"...
Old Jan 23, 2013, 03:36 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
The controller can utilize two types of input:
Direct RX connection, either passed through your FC or from an extra free channel or from a seperate RX. There is two channels (axises) that can be controlled in the current version.
There is also a 360 function in the making, that will allow to use a channel to control a continous pan/tilt/roll rate proportional to the stick deflection in either direction.
The controller can also take the pitch/roll gimbal output from your FC - it uses this to know the attitude of the frame, this is used to lock in the stabilisation further for fast moves and looking down angles and involves a calibration procedure (a simple one)
But it can be used standalone - that was what we did in the videos.
Old Jan 23, 2013, 03:59 PM
Kenpilot is offline
Find More Posts by Kenpilot
Kenpilot's Avatar
Joined May 2006
Subscribe
Looks incredibly smooth. Nice work!
Kenpilot is offline Find More Posts by Kenpilot
Old Jan 23, 2013, 04:13 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
Man I love the activity with this it just kind of exploded over the past week. I can't wait to get a board and tinker with gimbal ideas. Excited to see people's ideas for a canon 5d gimbal.
Dolby is offline Find More Posts by Dolby
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1672 Jul 01, 2016 05:42 AM
Yippee! Simple Brushless Gimbal Controller--FPV MODEL fpvmodels Multirotor Talk 3396 Dec 26, 2014 06:23 PM
Discussion A very simple camera-gimbal for Gaui 330xs babanan Multirotor Talk 2 Oct 09, 2013 08:46 AM
