Old Sep 20, 2013, 04:19 AM
hellafilming is offline
Find More Posts by hellafilming
Joined Jun 2013
Got it taken care of
Originally Posted by hellafilming View Post
I got a reply from flydunio and it was a mistake, new guy in the office. I appreciated the quick response, now we will see how long it takes to get here. So far so good on customer service.
They guys at Flydunio got the replacement boards out quick and nice. I am happy with their customer service.
hellafilming is offline Find More Posts by hellafilming
Old Sep 20, 2013, 04:56 AM
Sijmen is offline
Find More Posts by Sijmen
Joined Feb 2013
Can anybody help: I have bought Spektrum SX7s and AR8000 to command gimbal. The rest of th model is working properly but the gmbal doesnt react at all. Previously i used a 4 channel tx/rx and that worked fine. Is there some setting in the board I need to change for it to listen to the AR8000?
Help is appreciated.
Sijmen is offline Find More Posts by Sijmen
Old Sep 20, 2013, 06:27 AM
godwisper is offline
Find More Posts by godwisper
Joined Aug 2012
does the alexmos board from Flyduino come with all the pins soldered ? sorry for asking but with solder I always do a mess
godwisper is offline Find More Posts by godwisper
Old Sep 20, 2013, 08:03 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
The 2 axis board does, but the 3rd axis board requires you to solder them.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Old Sep 20, 2013, 09:41 AM
nisouck is online now
Find More Posts by nisouck
Belgique, Région Wallonne, Braine-l'Alleud
Joined Dec 2008
I think E-Copter and Fabien are deads.....
Pré-order start on february and - at almost - end of september nothing yet!
nisouck is online now Find More Posts by nisouck
Old Sep 20, 2013, 11:57 AM
TonyTypeS is offline
Find More Posts by TonyTypeS
United States, CA, Hacienda Heights
Joined Jun 2004
Sorry I haven't kept up to date with the thread, but what is the difference with the V2 and the V3? They both function just the same just the V3 has the 3rd axis with the main board?
TonyTypeS is offline Find More Posts by TonyTypeS
Old Sep 20, 2013, 02:45 PM
Panza is offline
Find More Posts by Panza
Panza's Avatar
France, Midi-Pyrénées, Toulouse
Joined Jun 2012
yes
and some new components
Panza is offline Find More Posts by Panza
Old Sep 20, 2013, 02:52 PM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
Case design nearly finished for Viacopter with 3 axis.
USB extension for flush mount mini USB, pushbutton in side of case, plastic standoffs for 3 axis board. Holes in side to allow for power & rc control wires to exit.
Magpul fans may notice and like the Pmag style rounded rectangle insets.
Photoship One is offline Find More Posts by Photoship One
Old Sep 20, 2013, 03:34 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
Polynésie française, Îles du Vent, Papeete
Joined Mar 2010
you have to sell those boxes !!!!!!!
flytahiti is offline Find More Posts by flytahiti
Old Sep 20, 2013, 10:24 PM
aonavy is offline
Find More Posts by aonavy
United States, NH, Epping
Joined Jul 2011
Originally Posted by Panza View Post
Hi
I tried Alexmox 3axis extention board on a Alexmoss copy, it works with.
I have built th brushlessgimbal.com gimbal with GBM 5208 150T
Can anybody give me the PID with this motors ?
you have any luck with this?
aonavy is offline Find More Posts by aonavy
Old Sep 20, 2013, 10:39 PM
tombrown1 is offline
Find More Posts by tombrown1
Joined Jul 2012
Originally Posted by highviz View Post
It just sounds like the c of g of the mount is not balanced around the yaw axis, so as you pitch the MR, gravity is overriding the stabilisation. Alternatively, if it only happens at speed, there is an aerodynamic effect resulting in a similar problem....
When hanging from a single point, getting a good yaw C of G can be tricky if there is any flex in the gimbal, as it naturally acts like a pendulum when you tilt it....
Malcolm
Thanks Malcolm. I've tried balancing it as best as I can, and I also lifted the camera as high as I could to help fend off this pendulum effect. I think I may have something that is workable - getting a flight up tomorrow to test it. I may just need to go with a bigger motor - using the iPower 5206 now.
tombrown1 is offline Find More Posts by tombrown1
Old Sep 21, 2013, 01:44 AM
Panza is offline
Panza's Avatar
Joined Jun 2012
yes and no. I stop use the copy (drotek) because there is no yaw control.
i used original alexmos card
the motor are good, execpt for the yaw. even at power 170, its a little less for the yaw.
Old Sep 21, 2013, 05:56 AM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
Fabien, please answer my pm or email.
Salocin is offline Find More Posts by Salocin
Old Sep 21, 2013, 07:57 AM
JKSniper is offline
Find More Posts by JKSniper
Joined Nov 2006
Is it possible to get 3D of both AlexMos boards (normal+pan extension), it will make nicer overall model of gimbal
Please PM me
Thanks!
Jure
JKSniper is offline Find More Posts by JKSniper
Old Sep 21, 2013, 02:57 PM
djiflyer is offline
Find More Posts by djiflyer
Joined Jul 2012
Has anyone been able to get the "Yaw Offset" feature within in Follow Mode to function so as to be able to center the camera on the yaw axis? I have the latest FW and GUI but no luck with it. I have been using a lever on my TX as a work-around but would much prefer to use this Offset Yaw feature. I have tried just about everything but cannot get my Yaw axis to respond to any of the changes I make. Does anyone have a tip on how to make this work?
djiflyer is offline Find More Posts by djiflyer
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1672 Jul 01, 2016 05:42 AM
Yippee! Simple Brushless Gimbal Controller--FPV MODEL fpvmodels Multirotor Talk 3396 Dec 26, 2014 06:23 PM
Discussion A very simple camera-gimbal for Gaui 330xs babanan Multirotor Talk 2 Oct 09, 2013 08:46 AM
