Joined Jun 2012
I have been in this hobby for more than 5 years..and this is the biggest revolution I've seen...thank you Alex Mos...'spasiba'
![]() Quote:
All "Alexmos" controllers are derived from the same basic design devised by Alexei Moskalenko. Its basically an Arduino with 2 motor drivers, not that many ways you can do that.
Our controller was layed out by the same guy that created Nanowii and the upcoming UltraESC, Felix Niessen. It was done with proper attention to support parts, trace scaling and cooling properties of the PCB. Alex licensed his work to different distributors and HW manufactorers. Viacopter, Flyduino and E-copter have teamed up on electronics and motor production to bring cost down and have a common European platform of high quality with good support, documentation and continued development behind it. But there are others making Alexmos controllers and gimbals to use with it. So far There is a chinese version (FPVmodel) and a Russian?? version (CSG). They will have to answer for themselves in relevant threads.... ![]() As for big DSLR´s, only one way to know for sure if it will work: Testing - if you want an answer "right now", there is basically 3 things you can do: 1: Get a controller, build a gimbal and test it... 2: Wait for someone else to make it and test it, hoping it will be "soon". 3: Get something else.. Sry, I dont mean to be rude, but I think that everyone has to realize that this is still in its infancy - this thread has been up for less than 2 weeks. I do think that it will grow up very fast, and we´ll see lots of exciting solutions for different cams in due time. Based on what I have seen so far, my guess is, that with proper attention to weight, balance and motor choice the current controller likely will be able to handle a pro DSLR like a 5DMkII or D700. But until I have tried it myself, I am not gonna say for sure that it can. One of you guys can be the first to find out.. ![]() Video with Alexmos controller and a 550D have been shown already, but not many details on the motors and gimbal was posted. Quote:
Latest blog entry: AutoQuad hexacopter with Alexmos...
USA, ME, Ellsworth
Joined May 2008
I think to get the best advice on motor re-winding the best way to do it is to go to that subforum and start a thread with the motor you want to rewind in hand. They will walk you through the process of getting it apart, getting the old windings off, and deciding how you want to rewind it. Your thread will be read by the smartest motor rewinders on this forum and the discussion as to what you want and how you'll use it will get you advice on the best choices for motors as far as the number of stator arms, the magnet counts, the winds to use, and other details like that. And you'll also get introduced to things like turn calculators, winding scheme generators, and sources for the wire and the other materials needed. The interest here is apparently to have a motor with a low Kv or RPM/Volt rating and also one that has the smoothest movements as far as cogging. I say that because I've seen mention of winding with 60 turns and of wanting the least perceptible amount of cogging. As an example of the things that have caught my interest here, I think you guys are starting with motors that, as one example, are purchased wound with 15 turns and a 400 Kv and rewinding those with the same wind but 60 turns. I know that will change the Kv from 400 to about 100. That is an unusually low KV for motors this small. But it will work of course. But I think all of you quad guys and camera gimble guys will get more and better advice if you raise the motor thing as a topic over on the motor forum. We're seeing an occasional quad guy drop by with other motor questions and as near as I can tell they are going away happier and with better motors. Someone will always ask, does it make sense to spend this kind of time and a little more money to rewind a motor that you can buy new for $10 or $15? You bet it does! Why? Because we get smoothing starting, smoother running, and more powerful motors. And they are perfectly matched to the propellers. And they are often motors you simply cannot buy with wind type and termination type that are best for what you want to do with the motor. And it is fun too! After all, this is a hobby! Look at this DAT-750 motor before and after being rewound, which one do you think is the better motor? Jack |
USA, ME, Ellsworth
Joined May 2008
Glad you guys enjoyed it. If you have a motor in mind, searching the forum might turn up everything you want to know from a past rewind someone else did.
The search engine here seems not so good sometimes, but if you go the the Advanced mode and choose to search thread titles for the motor name or model (like "Turnigy" or "DT750") and set an Any Data range, you can find threads about your motor sometimes. A search of entire posts and not just titles will get you a lot more hits. How hard is it? Here is the manual for winding and assembling a kit motor with a 12 arm stator and it shows how to do one of the most common and useful winds: http://www.micronradiocontrol.co.uk/...o/KH-257-2.pdf Is there one particular motor you are using? Jack |
| Thread Tools | |
| Yippee! Simple Brushless Gimbal Controller--FPV MODEL | fpvmodels | Multirotor Talk | 2748 | Today 01:01 AM |
| Mini-HowTo Super Simple Gimbal - SSG - Now with Tilt | crezzee | Aerial Photography | 750 | May 20, 2013 08:45 PM |
| Discussion A very simple camera-gimbal for Gaui 330xs | babanan | Multirotor Talk | 1 | Jul 19, 2011 02:13 PM |
