Old Jan 25, 2013, 10:05 AM
milo12 is online now
Find More Posts by milo12
Joined Feb 2011
Who is Stabileye?
trim.BMtXfV (1 min 35 sec)
milo12 is online now Find More Posts by milo12
Old Jan 25, 2013, 10:12 AM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
Originally Posted by JussiH View Post
We deliberately mounted the cam so the arms would be visible for the demonstration. The camera looks straight forward.The vid was done with a HeroHD in 720/60P which is the widest setting available on the HeroHD.
Mount it a bit more forward and looking down 10-15 degrees and you wont see the arms. GP3 also lets you set the FOV, so options should be good to avoid arms in the picture. I cant wait to try the 720/120P mode on GP3...should allow to make some stunning slomo videos.
Just a recommendation: try 1080p 60f or 2.7k 30f - much better than 720p 120f IMO due to less aritifacting. For youtube videos, it probably doesn't matter though
jcmonty is offline Find More Posts by jcmonty
Old Jan 25, 2013, 10:29 AM
robin4 is offline
Find More Posts by robin4
Stavern/Larvik - Norway
Joined Dec 2008
more videos
Test №3 direct drive gimbal (4 min 28 sec)
Video of a russian guy that uses alexmos simplebgc on his gimbal. The camera is a canon 550
Another great video that shows what the simplebgc is capable of
robin4 is offline Find More Posts by robin4
Old Jan 25, 2013, 11:22 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by milo12 View Post
Who is Stabileye?
It's Paul@SCC from the UK:
http://www.rcgroups.com/forums/showthread.php?t=1817209
kinderkram is offline Find More Posts by kinderkram
Old Jan 25, 2013, 11:29 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Originally Posted by flitelab View Post
What size lipos are being used on the test gimbals so far? 3S or 4S? How is the power consumption?
We used a 460/3S in the video. I didnt measure the current yet, but its gonna be in the mA range for sure. According to Alex, a 2S should work well in this size.
Theoretical upper limit for the HW is some 20V/2A per motor, but things will get very hot and likely fail at those loads...we are probably gonna say somewhere in the 2-4S <1A range as "safe", but we need further tests to determine the final rating.
JussiH is offline Find More Posts by JussiH
Old Jan 25, 2013, 11:31 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Ah nice, that isn't too bad at all. Just wasn't sure how these motors handled with how they are being used. Thanks.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 25, 2013, 12:19 PM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
Only 2s-3s required?! So then these rewinded BL motors work with pretty low voltage. How comes the Maxons that are used on the Zenmuse require high voltage (6s) to work at all and still have very little torque? Okay, the Maxons have optical enoders, right, and the ones on the Zenmuse are supposed to have 0.05 of dynamical pointing performance. How you guys are able to get this with these rewinded motors, low voltage and no optical encoders (okay, dedicated IMU) is amazing to me.
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Jan 25, 2013, 12:20 PM
recep is offline
Find More Posts by recep
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
As I can see from robin4's video this controller can handle motors for a 700 gr camera so it handle a nex5 or gh2 am I right?
recep is offline Find More Posts by recep
Old Jan 25, 2013, 12:22 PM
Bricobrac is offline
Find More Posts by Bricobrac
E-Copter
Bricobrac's Avatar
Paris / Nice, France
Joined Aug 2002
Hi,
we use 3S and also Polaris mini FPV bec from Gryphon ( 12v bed), very useful when using 4S to 6S powerplants. .
the current on the motors depend on the weight, inertia but also a lot of the gains settings. As per Alexmos recommendations, for such small motors, 1,5A without active cooling is a maximum to allow, with cooling it can be eventually up to 2 A.
The motors drivers can handle up to 7,1A each (datasheet) and have overcurrent / temperature / voltage protection.
The basics informations are on simplebgc.wom, use the Russian language and google translate as all pages are not yet translated into english ( i'll try to do it over the week end so Aleksey can update his website).
Best regards,
Fabien
Bricobrac is offline Find More Posts by Bricobrac
robin4 is offline
Joined Dec 2008
bump
Old Jan 25, 2013, 12:36 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Originally Posted by robin4 View Post
Not my video guys, just an upload from youtube - The guy calls himself provada1
http://www.youtube.com/user/provada1?feature=g-subs-u
Please don't clutter this thread and post videos without further info.
That's confusing.
At least tell the audience what's on the videos you post here. Some might have been under the impression that this was another flight video of Jussi's BLG.
Thx in advance.
Old Jan 25, 2013, 12:44 PM
rcposter is offline
Find More Posts by rcposter
Je Suis Turkana Boy
rcposter's Avatar
United States, CA, SF
Joined Apr 2011
That's confusing.
Thx in advance.
What IS it a video of?
rcposter is offline Find More Posts by rcposter
Old Jan 25, 2013, 01:00 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
These are rubber grommets. Industry uses them in all different shapes for vibration damping, isolation or protection of wires and mechanics on moving or shaking units.
Yeah but most bobbins are meant to dampen in compression while those appear to be mounted for tension which is what Im curious about.
epyonxero is offline Find More Posts by epyonxero
Old Jan 25, 2013, 01:34 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Can't tell you if this is a proper solution for vibration damping or if this will cause even more troubles in certain situations.
At least you will need another plate to attach it to...
Old Jan 25, 2013, 01:42 PM
d33pz is offline
Find More Posts by d33pz
Joined Jan 2013
JussiH: Hey! Maybe a bit offtopic, but do you mind sharing your autoquad setup? Im thinking about building a similar hex.
What kind of booms (length) and landing gear are you using on your FCP HL frame? Do you have any building pictures etc of it? What is your average flighttimewith 4S 400mAh and the gimbal?
d33pz is offline Find More Posts by d33pz
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1672 Jul 01, 2016 05:42 AM
Yippee! Simple Brushless Gimbal Controller--FPV MODEL fpvmodels Multirotor Talk 3396 Dec 26, 2014 06:23 PM
Discussion A very simple camera-gimbal for Gaui 330xs babanan Multirotor Talk 2 Oct 09, 2013 08:46 AM
