Old Jan 22, 2013, 03:36 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
New Product
Simple AlexMos 8bit brushless gimbal controller from Viacopter
Edit 20/3-2013
Pictures added of production prototype VectorDD gimbal for GoPro and a first prototype gimbal for mirrorless cam and small to medium DLSR.
More controllers will arrive on moday 25/3 at Viacopter
So,
I decided to take out a thread about the Alexmos gimbal system that will soon be launched from ViaCopter and Flyduino
Dont ask for preorders or lists - we are serious people, and we just dont begin to sell things that we dont have in stock Availability will be announced in good time before they go on sale.
Here are the videos:
Autoquad Alexmos gimbal test (2 min 36 sec)
PsykoKoptR vs Alexmos GoPro3 Gimbal (0 min 56 sec)
AutoQuad L1 vs Alexmos brushless gimbal (1 min 44 sec)
Alexmos gimbal onboard vid (0 min 45 sec)
Alexmos GoPro Gimbal (0 min 43 sec)
The gimbal is adjustable, so it can be balanced perfectly. It is also designed to put the lens on the exact center of the roll axis - something that is very important for aerial videography. Gimbal design by SebastianJ
Final production version with USB and IMU for camera:
Price for the controller and IMU is 110 Euro.
GoPro Gimbal for HeroHD and GoPro2 will be launched first. Also of course version for GoPro3. We dont have an ETA on those, since it depends on how fast our metalworking factory can produce them for us. We are shooting for them to be available inside 3-4 weeks, but its not a promise.
GoPro version is 268 grams with camera and controller. GoPro3 version will be slightly lighter.
We are currently designing gimbal for Compact and System cameras like HX9, Nex 5/5N/7 and EOS M.
Later will come versions for DSLR and Camcorders like CX730 and CX760.
Feel free to ask questions or post suggestions.
Thread shortcuts:
Tuning guide (By Fabien from E-copter)
http://www.rcgroups.com/forums/showpost.php?p=24435592
Motor winding info:
http://www.rcgroups.com/forums/showp...&postcount=151
Motor schematic for a 12n/14p motor:
http://www.rcgroups.com/forums/showp...&postcount=383
Detailed explanations on motor winding from jackerbes - thanks:
http://www.rcgroups.com/forums/showp...&postcount=368
http://www.rcgroups.com/forums/showt...815204&page=25
Basic information about Alexmos systems, licensing and cams possible to swing:
http://www.rcgroups.com/forums/showp...&postcount=347
GoPro3 Version - production prototype:
Design study and first prototype for mirrorless cam and small to medium DSLR:
JussiH is offline Find More Posts by JussiH
Old Jan 22, 2013, 03:45 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Additional info
Like everyone else in the MR community the AutoQuad Team was seeking for a solution for a top notch gimbal control, though the internal camera stabilization of the AQ6 worked pretty well even with cheap gimbal/servo combos.
Spreadsheet by Soul Patch Films for PIDs and other settings for different gimbals/motors
https://docs.google.com/spreadsheet/...=sharing#gid=6
This video shows the complete setup and tuning process, examplary connected to an AutoQuad FC
VectorDD gimbal & Alexmos controller & AutoQuad flightcontroller (23 min 37 sec)
Thanx to the SBGC project by Alex Moskalenko and the efforts of AQ Team members like Jussi (ViaCopter), Paul (Flyduino), Felix (famous Flyduino NanoWii and UltraESC design) and SebastianJ (Gimbal design) we'll soon have what many desire: an affordable, simple but effective solution for Multirotors - and any vehicle you can think of attaching it to.
I'll try to collect some more info about Alexmos' SimpleBGC as we go...
Here you can find more info on the VectorDD / Alexmos brushless gimbal
Recommended forum tools:
Image Browser
File Browser
Here's a nice tutorial, based on Fabien's aka Bricobrac info:
http://aerialpixels.com/support/alexmos-brushless-gimbal-controller-simplebgc-tuning-guide
A growing FAQ by dasrustler can be found at http://aerialpixels.com/support/alexmos-setup-guide
Donīt miss the Step by Step instructions by Aerialpixels
You will also find most necessary Downloads here.
Before you plug in the board for the first time, get the Silab USB COM Port drivers for windows
Depending on your board you might need drivers by FTDI insteand.
Most important files for Windows can also be found in the attachments below.
Please Scroll down!
New Manual for the AlexMos / BaseCam controller:
http://www.rcgroups.com/forums/showa...mentid=6022506
How to: Alexmos/Basecam Controller - Make it work perfectly (26 min 53 sec)
SimpleBGC 2.4 firmware (3 min 12 sec)
How to install and use the USB Windows COM Port Drivers and GUI software (by dasrustler)
Alexmos Brushless Gimbal Controller USB Driver Install & Initial Firmware (4 min 52 sec)
How to determine the orientation of the IMU's X/Y/Z axis (video by Buffythesaint)
X, Y and Z Axis (3 min 53 sec)
How to balance a DSLR on an Alexmos BL Gimbal (video by dasrustler)
Balancing DSLR Cameras for Alexmos Brushless Gimbals (2 min 5 sec)
Tutorial: Tuning a 3-Axis HiFly Gimbal with Alexmos Controller from Basecam (SimpleBGC) (7 min 55 sec)
How to perform the 6 Point Calibration on a cube (video by teramax)
how to - SBGC 6 point IMU calibration (5 min 51 sec)
Connection diagram and functions:
As you can see, Alex' solution is a separate controller with special firmware that can be connected externally to override the channels by both the flight controller and the receiver. The proto has a separate IMU.
As Jussi already mentioned Felix' design will include a USB connector and a separate IMU.
So you can easily connect it to the GUI for basic settings and control.
Using 2 Alemos boards for a 3-axis solution
Using the extension board for a 3-axis solution
Stacking the extension board on a v2 main controller
How to connect an analog joystick like the PS2 ones to your controller
- close J1 (JP1 or L1 on some boards) to provide 5V to the RC channels
- connect GND/5V of the joystick
- connect the VRx and VRy pins to RCpitch and RCroll
- assign the desired ports (in most cases pitch & yaw) in the RC settings
SOURCE: Analog
PITCH: RC_PITCH
YAW: RC_ROLL
- reboot your controller
More tutorial videos by dasrustler
Alexmos Controller V1 and V2 Joystick Connections and GUI Setup - Part 1 (4 min 38 sec)
Alexmos Menu Button Profile Setup Guide - Aerialpixels.com (6 min 12 sec)
Alexmos Receiver Connection, GUI Setup, Dual Operator Setup & GUI Setup (8 min 10 sec)
All-in-one GUI v2.x to setup and tune your SBGC
New Alexmos GUI quick introduction / tuning guide (16 min 27 sec)
Fabien aka Bricobrac from E-Copter wrote a nice tutorial on how to tune the PID settings here:
http://www.rcgroups.com/forums/showt...4#post24435592
All tools, firmware etc. can be downloaded here:
http://www.basecamelectronics.com/downloads
New Alexmos Android Configurator
[IMG]Android Configuration tool for the alexmos Controller[/IMG]
Can be downloaded at the Google Play Store
New Forum for the Alexmos / Basecam project:
http://forum.basecamelectronics.com
More videos of the ViaCopter/Flyduino SBGC will be collected in our YouTube Playlists
New 3axis Brushless Gimbal Extension by Alexmos:
BrushlessGimbal DSLR01 (3 min 38 sec)
New 3axis gimbal Controller
More info on the upcoming 32bit 3axis controller:
http://www.basecamelectronics.com/simplebgc32bit
How the "Follow Frame" mode works
SimpleBGC: How the "Follow Frame" mode works (12 min 19 sec)
FXPro Elite HD 3 Axis Handheld Brushless Gimbal - RED Scarlet - Follow Mode Demo (1 min 29 sec)
Alexmos did it again! Demonstrating the 5th axis for up/down movements:
Brushless 5-axis stab test (1 min 6 sec)
AutoQuad 6 Hexa X with BL Gimbal prototype
Some more yummie pics of the parts for the Alexmos brushless gimbal
Third Axis extension board (YAW)
V3 of the Alexmos 2axis Main Board (stackable 3rd axis board available
kinderkram is offline Find More Posts by kinderkram
Efti is offline
Find More Posts by Efti
Efti's Avatar
Norge, Rogaland, Bryne
Joined Oct 2011
Count me in on this gimbal.
My experience with the FreeIMU 0.4.3 is very good.
Efti is offline Find More Posts by Efti
Old Jan 22, 2013, 03:48 PM
SebastianJ is online now
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Nice looking gimbal
SebastianJ is online now Find More Posts by SebastianJ
Old Jan 22, 2013, 03:52 PM
rwijnhov is online now
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
Subscribed
rwijnhov is online now Find More Posts by rwijnhov
Old Jan 22, 2013, 03:57 PM
moriwaky is offline
Find More Posts by moriwaky
Spain, Valencia, V
Joined Nov 2007
please think on three axis gimbal too!
moriwaky is offline Find More Posts by moriwaky
Old Jan 22, 2013, 04:13 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
nice work! Looking forward to the release
Jelico is offline Find More Posts by Jelico
Old Jan 22, 2013, 04:15 PM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
The best picture so far
Sign me up!
culexus is offline Find More Posts by culexus
Old Jan 22, 2013, 04:36 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Since Jussi posted the video for the first time people keep banging at our doors.
So there was an urge need to canalize the info - not having to tell everyone the same again and again...
Old Jan 22, 2013, 04:38 PM
bakchos is online now
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
I am ready!
bakchos is online now Find More Posts by bakchos
Old Jan 22, 2013, 04:44 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Nice work guys, can't wait to try one out.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 22, 2013, 04:55 PM
Droner
SebastianJ's Avatar
Joined Mar 2006
In the works.
Old Jan 22, 2013, 05:15 PM
DorianJ is offline
Find More Posts by DorianJ
DorianJ's Avatar
Freehold, USA
PLEASE include a ramping feature on the tilt axis (pan axis when available). If you look at Zen videos you will notice pilot control on the pan and tilt axis are somewhat robotic. A ramping feature will smooth this movement.
DorianJ is offline Find More Posts by DorianJ
Old Jan 22, 2013, 05:25 PM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Subscribe :-)
DrEvil is offline Find More Posts by DrEvil
Old Jan 22, 2013, 05:35 PM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
Count me in! Already reserved the bucks for it
Do you have a estimation what the motors will cost?
Great work guy's. I'm really looking forward to it.
Remy is offline Find More Posts by Remy
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1664 Jan 07, 2016 08:45 PM
Yippee! Simple Brushless Gimbal Controller--FPV MODEL fpvmodels Multirotor Talk 3396 Dec 26, 2014 07:23 PM
Discussion A very simple camera-gimbal for Gaui 330xs babanan Multirotor Talk 2 Oct 09, 2013 09:46 AM
