Old Jan 22, 2013, 02:40 PM
monika is offline
Find More Posts by monika
Joined Jan 2013
tricopter help
I am making a tricopter based on rcexplorer design. I have a question..i am new to the rc world..any help would be great..a picture maybe
How to connect the escs and receiver to the HobbyKing V2 board? I have the male to male servo wires..but which port to connect to exactly and which wires go where?
Thank you.
monika is offline Find More Posts by monika
Old Jan 22, 2013, 03:11 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
Some info here: http://www.rcgroups.com/forums/showthread.php?t=1726124
mattcro is offline Find More Posts by mattcro
Old Jan 22, 2013, 08:00 PM
MultiWii2XS is offline
Find More Posts by MultiWii2XS
LoS sUAS AP/V is not a crime
United States, CA, Grass Valley
Joined Mar 2012
The product page on the HK web site has a Files tab near the bottom.
I found this there:
MultiWii2XS is offline Find More Posts by MultiWii2XS
Old Jan 23, 2013, 01:41 AM
monika is offline
Joined Jan 2013
tricopter help
I have my doubts cleared!
Thank you !
now about the yaw mechanism of the tricopter, is there a simple method of doing it? The crank shaft way has been explained here, but a few closer picture and some explanations would be of great help..
Old Jan 23, 2013, 09:20 AM
Joined Mar 2012
The scracthbuilt Multirotors thread has lots of good ideas.
http://www.rcgroups.com/forums/showt...&highlight=yaw
Old Jan 25, 2013, 12:07 AM
monika is offline
Joined Jan 2013
tricopter help
Thanks a lot for the thread Sir! This place is truly awesome!
Old Jan 25, 2013, 12:44 AM
monika is offline
Joined Jan 2013
tricopter help
How to check whether Escs are working fine?
Motors should be connected to Escs and Escs to battery..But where to connect the signal wire of escs to receiver? How do I understand which channel to connect to? I have a hobbyking Tx-Rx 6 Ch. This is my first build..a basic explanation would be of great help!
I have Hobbyking 25 A SS escs, how to set the parameters with the radid?
Old Jan 25, 2013, 03:26 AM
JNJO is offline
Find More Posts by JNJO
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
@monika
David has all the info you need on his site: -> http://rcexplorer.se/
Look under Projects and Educational.
I use his yaw mechanism described in Tri 2.0. Works really good for me.
Happy Building.
/J
JNJO is offline Find More Posts by JNJO
Old Jan 25, 2013, 10:39 AM
monika is offline
Joined Jan 2013
That was exactly what i had been looking for!! Thank you so much J.. All the time it had been there and I didnt know!
Thanks again!
Old Mar 13, 2013, 11:07 PM
monika is offline
Joined Jan 2013
Tricopter not lifting up
Tricopter is not lifting up...everything's running fine,motors rotating,Hobbyking V2 board flashed with tricopter firmware,it is getting armed..sometimes one arm is lifting up..most of the times the tricopter remains on ground even with full throttle.
Any help,any advice regarding this would be great..please help!
I am using Hobbyking SS 25 A escs which donot beep when programmed and calibrated with the board,but they rotate the motors synchronously.
Motors-Turnigy 750 kV,14 A max, 800 gm thrust with 9*6 props, Turnigy lipo battery 2200 mah,25 C,3S.
The AUW is 900 gms(including battery)..Help please
Old Mar 13, 2013, 11:21 PM
monika is offline
Joined Jan 2013
Gyro compensation checked,all correct..Props 9*5 exerting air towards ground..tried out with 3 CW props and with 2 CCW for front arm and rear,CW for the other front arm..Gyro pots on board at 50%..nothing works,tricopter refuses to lift up at 12.3 V,even with full throttle,one arm just lifts up..please help
Old Mar 14, 2013, 10:44 AM
squid10 is offline
Find More Posts by squid10
Israel
Joined Nov 2012
have you mount the prop right?
CCW rotation is a regular prop (e.g 8045)
CW rotation is a pusher prop (e.g 8045R or 8045P).
place all props while the letters on it are facing up.
also check that you connect all motors to the right ports.
squid10 is offline Find More Posts by squid10
Old Mar 14, 2013, 09:09 PM
monika is offline
Joined Jan 2013
Yes Sir,motors are rotating in anticlockwise direction,and the props have their face upwards(i.e the 9*5 writing upwards), I also have checked that with all CCW,all CW,combination of both keeping in mind that the air is exerted downwards...I am not being able to post a video of the tricopter..its not uploading,i am trying...
Old Mar 15, 2013, 02:22 AM
biswajyoti is offline
Find More Posts by biswajyoti
Joined Mar 2013
My Hobbyking V2 board is not arming..please help..
biswajyoti is offline Find More Posts by biswajyoti
Old Mar 16, 2013, 03:48 PM
WinterDevil is offline
Find More Posts by WinterDevil
WinterDevil's Avatar
Canada, QC, Sherbrooke
Joined Aug 2012
Edit: wrong answer, sorry.
WinterDevil is offline Find More Posts by WinterDevil
Build Log newbie ready to take on tricopter build palcuz Scratchbuilt Multirotors 62 Mar 05, 2013 08:38 PM
Help! Need KK 1.6 Tricopter (Agressive) firmware RobDog Multirotor Electronics 3 Jan 17, 2013 09:12 AM
Discussion tricopter yoyo'ing bluesteel212 Multirotor Talk 0 Jan 07, 2013 11:51 PM
Discussion Differences in flight performance on Tricopter FCs. acetech09 Multirotor Electronics 1 Jan 06, 2013 03:16 AM
For Sale Tricopter DlgHucker Aircraft - Electric - Multirotor (FS/W) 7 Jan 05, 2013 09:00 PM
