Old Jan 22, 2013, 10:13 AM
mfische is offline
Find More Posts by mfische
Joined Feb 2012
Windows 7 not recognizing my eLogger4 when plugged in?
Hi, I just bought the eLogger4 and installed the software included with the disk. After I installed it, I ran this wizard that is supposed to help you plug in the eLogger4 and get it set up to use in the software. However, when I plug in my eLogger4 with the given mini USB into my laptop that runs windows 7, my laptop doesnt recognize it, and nor does it pop up with any drivers to install like the instruction manual said it would do. The LED light blinks about once every second repeatedly..if that means anything..
what should i do?
mfische is offline Find More Posts by mfische
Old Jan 26, 2013, 03:11 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, that blink pattern indicates that it's getting power from the PC, but the USB is not connecting (as I think you realized).
I can think of a couple of causes:
1) if, when you plug the USB into the laptop, the laptop presents a USB error, there may be a compatibility problem. If that's the case, could you try rebooting the laptop, temporarily try a different PC, or try a USB hub?
2) if nothing at all happens at all on the PC, is the plug fully seated in the eLogger? If so (and the above steps don't bear fruit either) I am wondering if there may be an issue with either the cable or the eLogger's plug. This seems unlikely as USB connectivity with the eLogger is the last thing tested here, but I don't want to rule that out.
billpa is offline Find More Posts by billpa
Site Sponsor
Discussion Windows doesn't recognize my Elogger eduardokenithi Eagle Tree Systems 2 Nov 06, 2012 06:35 PM
Discussion Castle Link drivers not loading in Windows 7 (64bit) jfacky Castle Creations 7 Jul 04, 2011 12:12 AM
Discussion Windows not recognizing some buttons on my JR SX600 transmitter. SidSpeed Simulators 9 Oct 28, 2010 06:02 PM
Discussion Windows Movie Maker for Windows 7 (NOT windows live) aaron_gx FPV Talk 1 Jun 17, 2010 12:22 AM
Question Why do my servos keep moving when I plug my battery in? myace Electric Plane Talk 13 Jun 21, 2006 12:45 PM
