Jan 21, 2013, 11:41 PM
Indianapolis, IN
Joined Nov 2006
Oracle Data Logger Flight Data Recorder
Some info:
A tiny 1" x 1.8" lightweight unit with the most power and functionality of any R/C data recorder.
Records up to 10 different parameters: Volts, Amps, Watts, AmpHrs, WattHrs, two (2) Temperatures, RPM, Throttle and an Aux input. The RPM Phase sensor with no magnets or optics, just a connection to one wire of your brushless motor.
User configurable for Sample Rate, Channels to record and much more to get just get the data that you need. Records from 20 minutes to over 10 days worth of data (depending upon sample rate and number of channels recorded).
Barely used. Comes with sensor, USB programming cable, software CD, and manual.
Purchased originally for $80.
Make a reasonable offer.
