Old Feb 08, 2013, 10:48 PM
Tin knocker is offline
Find More Posts by Tin knocker
United States, PA, Edinboro
Joined Jul 2009
Looks Great!
You might have it done in time for show and tell at the Club dinner.
That is a lot of work. between the building, photo taking and typing up your posts.
Go... Man... Go!
Murray
Tin knocker is offline Find More Posts by Tin knocker
Old Feb 09, 2013, 07:45 AM
willey is offline
Find More Posts by willey
warbirds
willey's Avatar
United States, PA, Waterford
Joined Jul 2007
LOL!!! yes I was a good boy....... well..... it depends on who you ask, the wife would probably give you a different answer .
The Dinner....I did think about that, I'll see if I can get more done
willey is offline Find More Posts by willey
Old Feb 09, 2013, 08:36 AM
Boomer1 is offline
Find More Posts by Boomer1
Boomer1
Boomer1's Avatar
United States, CA, Temecula
Joined Sep 2009
Willey
Boy your build report has been great! Tower Hobbies should send you a thank you note! Here are the specifications published on this boat. Note they report the hulls are fiberglass in the business denoted as "FRP" = fiber reinforced plastic (just and FYI) it doesn't state the material the cross beams are made out of. I suspect either PE (polyethylene) or ABS (both materials are popular with toy manufactures.)
Wonder what the heck they phase it as "completely factory built"? Wonder if we'd think it was partially factory built or some part of it might have been built in some one's basement or by strangers that came by and wanted to help? Just curious.
FEATURES: Completely factory built fiberglass hull
Low drag hydrodynamic steel ballast
Light and strong extruded aluminum mast and booms
High performance tear resistant racing sails
Black anodized aluminum display stand
INCLUDES: Voyager 1/25 scale ETNZ 1-Meter America's Cup Racing Yacht, deck
fittings, display stand, sails, epoxy, rigging thread, decal sheet,
and instruction manual
REQUIRES: Radio: 2-channel with one standard servo, one sail winch servo
Battery: 4.8V for receiver
Building and shore equipment
SPECS: Length: 39" (993mm)
Beam (width): 6.75" (172mm)
Sail Area: 744 sq in (48 sq dm)
Mast Height: 51.4" (1306mm)
Overall Height: 67" (1700mm)
OVerall Weight: 7.7lb (3.5kg)
Can you show as the servo arrangements and what batteries you are going to use?
Thanks again!!
Boomer
Boomer1 is offline Find More Posts by Boomer1
Old Feb 09, 2013, 10:55 AM
Joined Jul 2009
Boomer
I hadn't seen those discriptions and specs.
The one that caught my eye was the
"Black anodized aluminum display stand"
So I was looking for that reference, and then found the specs
were a bit different too.
And
Willey
I sure have a lot of learning to do.
The names and terms...
Having bought my Seawind second hand, already built, has
put me behind the learning curve.
I've down loaded its manual and plan to read through it.
I'm sure it will be a dry read.
Doe's anyone have some reading
learning/material that is not over welming?
Murray
Old Feb 09, 2013, 11:00 AM
Boomer1 is offline
Boomer1
Boomer1's Avatar
Joined Sep 2009
Originally Posted by Tin knocker View Post
Boomer
I hadn't seen those descriptions and specs.
I've down loaded it's manual and plan to read through it.
Does anyone have some reading
learning/material that is not over whelming
Murray
Murray
I know a guy that has a collection of old Playboy magazines - think those will work for you?
Boomer
Old Feb 09, 2013, 11:19 AM
Joined Jul 2009
Good learning material has good photos.
So your sugestion would be over whelming!!!
Murray
Old Feb 09, 2013, 12:42 PM
offshore1987 is offline
Find More Posts by offshore1987
United Kingdom, England, Portsmouth
Joined Nov 2006
Really like the build so am very jelous Cant wait to see more of the build, looks an even better yacht than i had thought she would be
Dan
offshore1987 is offline Find More Posts by offshore1987
Old Feb 09, 2013, 03:48 PM
northernmike is offline
Find More Posts by northernmike
Joined May 2011
Is it rocking your world, that's the question on everyone's minds.
northernmike is offline Find More Posts by northernmike
Old Feb 09, 2013, 04:06 PM
rcsoar4fun is offline
Find More Posts by rcsoar4fun
United States, ID, Star
Joined May 2003
Is the fin weighted or just plastic?
rcsoar4fun is offline Find More Posts by rcsoar4fun
Old Feb 10, 2013, 08:23 AM
willey is offline
warbirds
willey's Avatar
Joined Jul 2007
Boomer, I was thinking a "BIG Gift Certificate" from Tower and or Thunder Tiger would be nice!!
Thanks for the other info too.
As for the servo.... I was thinking the Hitec 785HB? any other thoughts from anyone would be great, I need to place an order. I have a Hitec 605 or similar for the rudder.
Battery....6v, Receiver... Spektrum M200 Marine.
Everyone...This will be my first winch type install so any advice is very welcome
Old Feb 10, 2013, 08:28 AM
willey is offline
warbirds
willey's Avatar
Joined Jul 2007
Murry, don't worry, you will be stripping all the hardware and lines for painting, so you will learn just as I did, You are not getting away that eeeeasy!!!!! You need to feel the pain! Growing pains there called
Start by praticing/learning KNOTS & Clean that bench off!
Old Feb 10, 2013, 08:49 AM
willey is offline
warbirds
willey's Avatar
Joined Jul 2007
Dan
Actually... my thoughts exactly, Really I did not expect this nice of a kit, maybe its there photo's? TT should show more detail and more angles in their photos.
the looks, the kit, and the build/construction - A+, few things I would change in the instructions, but overall - good.
I am no Sailor, I only have some Seawind experience, but we will see how well it sails???? I guess that the BIG question.
Old Feb 10, 2013, 08:50 AM
willey is offline
warbirds
willey's Avatar
Joined Jul 2007
I love that POPCORN DUDE! can you tell??
Old Feb 10, 2013, 08:55 AM
willey is offline
warbirds
willey's Avatar
Joined Jul 2007
LOL!!! For this week its doing very WELL!!
Old Feb 10, 2013, 09:00 AM
willey is offline
warbirds
willey's Avatar
Joined Jul 2007
Tork rod molded in Plastic, pretty tuff stuff, I already rammed the keel in a door jam - no damage
Sold Thunder Tiger Pro 46 ABN w/ muffler new in the box hobbyfun100 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 21, 2013 12:33 AM
Question Thunder Tiger .40 glow to electric question bsfixit Glow to Electric Conversions 7 Jan 20, 2013 02:28 PM
Sold New Never Fueled Thunder Tiger 91 FS Four Stroke Nice! $115.00 FREE SHIPPED!!! stevster Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 19, 2013 08:50 PM
Discussion thunder tiger engines Holt Engines 2 Jan 16, 2013 06:01 PM
Sold Thunder Tiger eHawk 1500 new Twinkletoze Aircraft - Sailplanes (FS/W) 1 Jan 12, 2013 10:18 AM
