Old Jan 21, 2013, 10:27 PM
stape is offline
Find More Posts by stape
United States, TX, Gainesville
Joined Jul 2008
Best Epoxy for Bagging?
Hello all! I've been reading these forums for years so here goes the first thread.. I am about to begin assembling a dlg short kit and need to vacuum bag the wings. I've beaten myself to death with all the info I can find on how to go about the bagging, but what is the best epoxy system to use for a beginner? Obviously a slower cure will be helpful, but the viscosity will play an important part, as will price. Anyone with experience in this please chime in and thanks in advance!
stape is offline Find More Posts by stape
Old Jan 21, 2013, 10:59 PM
bwill6 is online now
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
I have been using Resin Research Composite Pro for a while now and absolutely love it. It's crystal clear, low viscosity, very strong, and has absolutely NO smell.
bwill6 is online now Find More Posts by bwill6
Old Jan 22, 2013, 09:16 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Best is MGS in most opinions including mine, but it's expensive and only available from a couple of places in the USA.
West Systems is very available at woodworking stores and boating supply stores. It's a great low viscosity resin for most uses.
Resin Research is great as well and is inexpensive. It's a slightly higher viscosity than West or MGS but still extremely usable and probably the best value.
Others like US Composites are quite good as well, but I don't have alot of personal experience with them.
tom43004 is offline Find More Posts by tom43004
Old Jan 22, 2013, 09:22 AM
rdwoebke is online now
Find More Posts by rdwoebke
The Self Confuser
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
If you are not with a large group and can get a group order of something like MGS for a guy giving it a go on his own I really like the 12 ounce 60 minute EZ-LAM kit for $18.00.
http://www.acpsales.com/Epoxy-Resins.html
I mix mine by mass with a digital gram scale.
I now have MGS. The MGS is better. But if I didn't have a local buddy with a local source of the stuff I would still be using the EZ-LAM.
Ryan
rdwoebke is online now Find More Posts by rdwoebke
Old Jan 22, 2013, 10:37 AM
G Norsworthy is online now
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
I like US composites for thicker laminates but in my experience it is not well suited to thin skins on DLG wings or tails.
G Norsworthy is online now Find More Posts by G Norsworthy
Old Jan 22, 2013, 10:41 AM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Avoid West Systems for this use. The glass transition temperature is too low for sunlight summer exposure. It may be good for wooden boats, where a little bit of creep may help keep it mated better to wood which certainly changes dimension, but you don't want your wings warping just because of a little summer sun. Besides, it is too thick.
MGS is my preference. If you are certain you are serious and plan to do a number of wings, I'd recommend just going with it. Perhaps split up a gallon with some local friends?
Gerald
G_T is offline Find More Posts by G_T
Old Jan 22, 2013, 10:43 AM
Joined Jun 2011
I won't argue with the fact that MGS is the best. You won't find anything better. However, it is the most expensive. I will, however, argue that Resin Research has lower viscosity than West. I use both on a regular basis (RR for my own projects, West at work) and the difference is noticeable. US Composites is higher viscosity, but it is very strong and stiff if post-cured. Wyowindworks has a thread in the Composites forum where he shows tests done with all of the above resins. It's worth reading through.
I started with the 12oz EZ-LAM kit from ACP. It's not a bad way to try out composites building. The resin is decent and the kit isn't expensive. You should be able to get at least a couple of wings and several tails out of one bottle.
Old Jan 22, 2013, 10:49 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
My first wing skins somebody suggested West systems epoxy. It was not what I would have suggested party because it got tacky to soon and had me scrabbling to get things straightened out to close up the mylars. I have since used MGS 285 and refuse to use anything else.
Mgs is like working with 30 weight motor oil. Its nice with zero odor and seems to react the same with every batch. I always get things finished before it ever shows signs of thickening.
To me, Its worth the extra money
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Jan 22, 2013, 10:55 AM
nickbox is offline
Find More Posts by nickbox
SCSA - Nick Wu
nickbox's Avatar
China, Guangdong, Guangzhou
Joined Apr 2009
Thanks for the information!
Glad to know where to get them.
nickbox is offline Find More Posts by nickbox
Old Jan 22, 2013, 11:17 AM
Joined Apr 2010
Good advice
http://www.rcgroups.com/forums/showthread.php?t=1135513
Old Jan 22, 2013, 11:29 AM
Joined Jun 2011
Thanks for posting the link, DLGjunkyard. I was too lazy to go find it. It's worth noting that in his tests he uses Composite Pro 2070, which is the medium modulus resin. The 2050 will yield a stiffer part. I have only used the 2050 so I can't tell you just how much more viscous it is, but I don't have any difficulty wetting out parts.
I might have to try MGS sometime just to see how much of a difference it'll make.
Old Jan 22, 2013, 11:41 AM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
Has anyone tried Adtech's ProBuild Marine laminating resin with the Tropical Hardener for DLG wings? I've been using it for repairs and been happy with it so far, but I can't compare because I haven't used any other laminating resin. It's about $65 for a quart of resin and pint of hardener, shipped.
Wazmo is online now Find More Posts by Wazmo
Old Jan 22, 2013, 11:47 AM
Joined Jun 2011
I know Wyowindworks has talked a lot about Adtech resin, but I don't know specifically which one he's used. I just know he was very happy with it and recommended it as a less expensive alternative to MGS
Old Jan 22, 2013, 12:10 PM
Joined Apr 2010
The heart of the problem for new builders is the volume needed. There are many suitable brands. Just not many sold in quarts.
BTW GUYS aircraft spruce now carries pro set. Its very comparable to MGS
http://www.aircraftspruce.ca/catalog...tSysEpoxy3.php
Old Jan 22, 2013, 12:17 PM
David Forbes is offline
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Except for the blue hardener of MGS I can't tell much practical difference between it and Pro-set 125/229.
Dave
David Forbes is offline Find More Posts by David Forbes
Question Epoxy for a Sky Raider Mach II trixieandme Balsa Builders 1 Jan 21, 2013 04:33 PM
Question PU Glue vs Epoxy for FG and Vac Bagging wingnutt Composites Fabrication 27 Mar 02, 2009 09:14 PM
Discussion cut fiberglass cloth then apply epoxy or other way round for wing bagging. noobee Composites Fabrication 17 Apr 26, 2008 08:51 PM
Discussion plasticiser for epoxy -bagged epp jirvin_4505 Composites Fabrication 9 Jul 03, 2007 07:33 AM
Question Prepping vinyl bags for epoxy??? punkindrublik Composites Fabrication 5 May 04, 2006 12:17 AM
