Old Jan 21, 2013, 10:02 PM
J Lombard is offline
Find More Posts by J Lombard
United States, NV, Gardnerville
Joined Jan 2013
OS 4 Strokes
I am thinking of using either an OS 72-a or 81-a in a Top Flite P039 Airacobra that i"m building. anyone having any experiance with these engines I would appreciate your comments.
thanks
J
J Lombard is offline Find More Posts by J Lombard
Old Jan 21, 2013, 10:56 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
I had this kit with an OS FS90 on it. It was a rocket and weighed a ton (12 pounds)
datsunguy is offline Find More Posts by datsunguy
Old Jan 22, 2013, 12:38 AM
triflyer is offline
Find More Posts by triflyer
United States, MI, Clarkston
Joined Mar 2007
I had a OS72 in the TF P39 and found it was very marginal for power especially on takeoff. I replaced it with an older OS90 like Datsunguy used and found that it had plenty of power. I believe that the old OS90 rear cam motor was more powerful than the newer OS 91's. I do not think you will be happy with the 72 or 81.
My opinion only!
triflyer is offline Find More Posts by triflyer
Old Jan 23, 2013, 09:51 PM
Joined Jan 2013
Thanks guys for your opinions. Guess I'll have to rethink my power plant.
thanks again
J
Old Jan 27, 2013, 03:17 PM
AirmanBob is offline
Find More Posts by AirmanBob
AirmanBob's Avatar
USA
Joined Feb 2005
Yep... I have that P-39 and I put an OS 91 four stroke in it
I installed the engine on its side, that way the exhaust blew
down and away from the fuselage.
Mine has the air retracts too.
The 91 flew it pretty good but the plane was so heavy that
you have to land it really hot or it will stall.
It sure is pretty though...
Bob
AirmanBob is offline Find More Posts by AirmanBob
Old Jan 27, 2013, 03:25 PM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Video...
The real plane flew pretty easy and stalled at ~100 mph...
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 28, 2013, 08:31 PM
Joined Jun 2011
Bob
That was exactly the problem with mine. It would stall and snap roll at the drop of a hat at low speeds. You had to land going lickity split. Always exciting. The old 90 was more than enough power though.
Old Jan 30, 2013, 04:32 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
I think you'd be fine with the .81. I don't understand why the OS 72 even exists. The 81 is essentially the same but more powerful. It is only down from an OS 91 Surpass by a couple hundred rpm on standard props (I cannot believe the old 90 FS was more powerful than the Surpass; If it seemed so then the prop on the Surpass was not optimal).
So just be careful about weight as you build, always a good idea; if the old 90 FS will fly it then I'm sure the 81 would also.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Discussion OS 120 4 stroke or Saito 120 4 stroke Smo0 Fuel Warbirds 9 Sep 22, 2014 06:26 PM
Sold 2 OS 4-stroke. 61 and 70 VampeD4 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 14, 2013 04:51 PM
Found os 91 4 stroke, and os 91 2 stroke glo's chyorn Aircraft - Fuel - Engines and Accessories (FS/W) 7 Aug 22, 2011 08:19 PM
