Haha! I got quite a laugh out of the idea of someone actually trying something as ridiculous as my down-only aileron example but after looking into the Farman, it seems that the ailerons were actuated with a single cable, but only upward not downward.
Doing lazy flat 8's is simple with these designs. rudder ONLY is used - a slight corrective elevator is sometimes required. |
Sorry aero, that's all completely wrong. A turn requires both yaw rate and side force. It is absolutely impossible for a continuous turn to occur with only a single, non-rotating force (F=ma => straight line). Planets orbit because the gravitational force is rotating relative to their path. Planes turn because they continuously yaw and thus the side force is then rotating relative to their path. Planes turn with aileron-only inputs because they slip inward and the vertical tail then causes an inward yaw rate.
Any airplane can fly flat circles, even a flying wing with no fuselage or vertical tail whatsoever. All you need is something to create a yaw rate. For example a split aileron/drag rudder. Lateral area greatly improves the effect but it's the yaw rate that makes it possible.
edit: somehow got fixated on yaw rates and forgot what I said two posts up. I should have said that any airplane with any amount of usable side area can perform a flat turn, since a lateral force is still needed in conjunction with the yaw rate. A B-2 Stealth Bomber style aircraft with no usable vertical surface would simply fly straight, but at an oblique angle if yawed. |
tho some designs do not turn with only banking inputs. |
No, actually if it's a "plane" it will turn whenever banked. By "plane" I mean it's not a missile flying a zero-g ballistic trajectory, and it's not unstable or untrimmed. The reason being that a stable plane in trim must have some decalage or reflex -- by definition. So if you took one of the extreme example planes pictured below and actually trimmed them for stable level flight you would have to have some positive static margin offset by some up elevon trim per the definition of pitch stability. In that case the "wing" will fly at some positive AOA at any bank angle, while the "fuselage" will always try to fly at zero AOA. Hence you'll get a lateral lift component and subsequent sideslip that produces a yaw rate.
If it's unstable in pitch (as many are) this will not be the case. In fact these types of planes are often flown with negative margin and are divergent in pitch and may even require down trim for level flight, in which case they would indeed turn opposite the bank angle -- in theory. I say "in theory" because if it's divergent then there really isn't any point in claiming what it would do in a turn because it can't do anything on it's own and can't fly in any direction without randomly darting in some other direction so that's far outside the realm of applicable theory. Of course a symmetrical plane like this with exactly zero static margin could be in trim and able to maintain lifting flight at any bank angle without turning, but again this is only theory since it's not actually possible to get a true zero static margin. |
In actual practice the very lightly loaded stuff with lots of lateral area & balanced corrrectly DO simply hold a straight path when the normal level wing flight is altered - weird stuff to fly- I had one of those Hyper Taxi- it was not good at doing this -but other bipes with huge interplanes etc., were very good . George Hicks designed the first one of these I flew - George is a design engineer for an aircraft co and also a very sharp model designer and flier.
Most planes can be made to do a level "steady heading sideslip" (hold a constant bank angle with no turn). In most cases, all that is required is to apply sufficient rudder opposite the bank angle.
An airplane with lots of side area, strong apparent dihedral effect, strong adverse yaw due to aileron deflection, and weak directional stability can even do a steady heading sideslip with no rudder deflection. In extreme cases, an aircraft like this could do a level turn to the right in a bank to the left, with no rudder deflection. This unlikely be a desirable flying quality. |
The Willamette Valley, Oregon
Joined Dec 2008
"Once the yaw rotation has increased as needed to keep up with the turn rate (curvature in the flight path), the requirement for a yaw torque vanishes, and depending on various other details at play, sideslip may vanish too." --END EDIT What you are missing Vespa is that providing the yaw rate is trivial. It just takes a very small yaw torque and temporary yaw torque, to overcome the plane's yaw rotational inertia and initiate the required yaw rotation. There is no problem with the plane's "weathervane effect" or "directional stability" acting to provide this yaw torque, even if we are using something like a CG-mounted rudder or a sidewise-mounted CG-mounted thruster to drive the turn, which creates no yaw torque in and of itself. Consider a control line airplane. The control lines connecting near the CG are providing the centripetal force that drives the turn. Is something putting a steady yaw torque on the plane? Is it a requirement, for example, that the plane's rudder be deflected toward the inside of the turn, or that the airflow strike the inside of the vertical fin, to provide the needed yaw torque to keep the turn going? Not at all. At a steady turn rate, net yaw torque is zero. I stand 100% by all my comments of my previous post. Consider carefully and perhaps you might see things in a different light. Turning by sideforce is fundamentally no different than turning by banking. It is generally much less efficient, but there is no fundamental difference as far as the need for some sort of yaw torque to be imposed upon the aircraft, etc. It is a misconception that a turn requires a large yaw torque. Whether we are turning by banking the wing or turning by sideforce, the heart of a turn is the centripetal force acting at the CG of the aircraft. Only a small, momentary yaw torque is needed to initiate the yaw rotation, and this yaw torque can easily be provided by the plane's "weathervane effect" or directional stability, after a few brief moments of sideslip create a sideways flow over the aircraft. Once the yaw rotation has increased as needed to keep up with the turn rate (curvature in the flight path), the requirement for a yaw torque vanishes, and depending on various other details at play, sideslip may vanish too. Even after settling into a constant-bank constant-rate turn, we do usually see some continuous sideslip in a rudderless aircraft. That is not because the slip is "needed" to provide a net yaw torque to power the turn. Rather, that is because the outboard wingtip flies faster and creates more drag than the inboard wingtip, which creates a yawing-out torque, and the only way the net yaw torque can balance out to zero is for the nose to be yawed/displaced a bit toward the outside of the turn (yaw string streams to inside). The resulting sideways airflow interacts with the vertical fin or other equivalent surfaces to provide the yawing-in torque that is equal and opposite to the yawing-out torque from the drag of the outboard wingtip, so that the net yaw torque may be zero. Of course, steep-bank turns involve more pitch rotation than yaw rotation. That is a different set of dynamics which we could easily spell out step-by-step, but won't, at the moment.... Give it a bit more thought and you will see that the fundamental requirement for a turn, is a centripetal force acting at the CG of the aircraft. We can provide this force by the unorthodox means I spelled out in my previous post, or we can hold lots of inside rudder and do a flat turn while giving whatever roll input is needed to force the wings to stay level, in which case the airflow hitting the side of the fuselage provides the centripetal force that drives the turn, or we can provide the centripetal force in the usual (and usually more efficient) way, by banking. In no case is there a requirement for a sustained net yaw torque. Net yaw torque is zero in a constant-rate turn at a constant slip angle. Steve |
Joined Dec 2008
I'm not saying that a turn involves no net yaw torque. There is a brief net yaw torque applied to overcome yaw rotational inertia and initiate the yaw rotation. Likewise in pitch. Let's not waste time preaching each other things we already both know. What specifically, exactly, are you saying was wrong with my earlier post re turning by sideforce? Steve |
| Thread Tools | |
| Discussion Unwanted yaw and roll (help plz) | 5th | Multirotor Talk | 16 | Feb 12, 2013 03:56 PM |
| Discussion Bumblebee Yaws Aggressivly | teamhairball | Multirotor Talk | 0 | Jan 20, 2013 08:44 AM |
| Help! My HFP does not yaw | aok | Hoverfly Technologies | 4 | Jan 20, 2013 05:45 AM |
| Discussion YAW overshoot, altitude loss while yawing, GPS oddities | cicadafx | Hoverfly Technologies | 9 | Oct 27, 2011 10:22 AM |
| Discussion Left Yaw, Right Yaw on my BCX2 | jdunn9 | Coaxial Helicopters | 0 | Feb 23, 2007 07:47 PM |
