Old Jan 21, 2013, 04:56 PM
dunginhawk is offline
Find More Posts by dunginhawk
Joined Jan 2013
New blade mcpx v2 . blade issue?
Good afternoon. I just purchased an mcpx v2. I have only had easy fly micros before. so i figured this would be a good place to start learning the other way.
I have an issue.. first battery charge in fact... first off, i cant get it off the ground, but that takes practice
but when i throttle up, just above where it lifts off it rattles the blades like you cant believe. its not air buffetting from what i can tell but it just vibrates and rattles so much so I wont run it. not sure what happened.. any advice?
ill try to take a video here.
thanks
dunginhawk is offline Find More Posts by dunginhawk
Old Jan 21, 2013, 05:15 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You have to make sure the blades are fairly tight and straight. Tight enough that it requires fair finger pressure to move them. No up and down slop at all.
Balr14 is offline Find More Posts by Balr14
Old Jan 21, 2013, 05:23 PM
Joined Jan 2013
i did that . still no relief..
here is a video
IMG_1094 (0 min 16 sec)
Old Jan 21, 2013, 05:28 PM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
balance the blades
chulian1819 is offline Find More Posts by chulian1819
Old Jan 21, 2013, 05:31 PM
Joined Jan 2013
I am new to the single rotor game, so this doesnt come naturally thanks.. ill give that a try when i have some time. is there a certain way to do that or a site i should visit? never done anything like this. thanks
Old Jan 21, 2013, 05:47 PM
TucsonFlyer is offline
Find More Posts by TucsonFlyer
Joined Nov 2011
First, balance the blades.
Second, tighten the blade grips. Tighten the blades so that when held on it's side the blades don't move on their own but will move if you give it a gentle shake.
Third, Remeber to straighten your blades out before spooling up. It's a bad habit to get into and can really damage larger helis.
Finally, get it in the air quickly but smoothly. Most FBL units do funny things when the heli if vibrating against the ground.
TucsonFlyer is offline Find More Posts by TucsonFlyer
Old Jan 21, 2013, 08:14 PM
Joined Jan 2013
so i dont have a balance thing for the blades, but i weighed them. they were both 2.3g.
i tightened them down, but didnt make a difference.
even replaced the blades, same thing.
no really sure where to turn now.. any ideas?
Old Jan 21, 2013, 09:59 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Don't overtighten. This is the standard way.
How to Adjust Blade Tension (0 min 28 sec)
If the blades barely move when you do this, it's way too tight. Mine actually go down further than that.
Check the main gear if it's seated properly and that all the teeth are there. It should be lined up perfectly with the motor pinion and it should not move when you move the rotorhead up and down.
Hajile is online now Find More Posts by Hajile
Old Jan 21, 2013, 11:16 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
Your blades don't need balancing.
Are the links to the head over the balls on the swash or have they been pushed too far and are over the pin connecting the balls to the grips?
The same goes for the links going to the balls on the swash.
Has your swash separated?
Are the balls on the grips and swash intact? I have seen them break so that they are flexible but not separate.
Is your anti-rotation pin in the correct place?
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Jan 21, 2013, 11:29 PM
Joined Jan 2013
so i think its the gear .
here are a couple of pictures.
this is in the down position (the pictures)
if i move blades up it is more centered.
so i accelerate and the big white gear moves up the smaller gold gear and when it gets up in the center of the gold gear thats when it goes all crazy with the noise and rattle.
man i wish i knew more about this stuff. i appreciate all your help, and the continued help
ps the gold gear is stationary, doesnt move.
[IMG][/IMG]
Old Jan 21, 2013, 11:31 PM
Toronto Canada
Joined Dec 2002
Is the gear fully pushed on?
Mcpx main gear fix (1 min 54 sec)
Old Jan 21, 2013, 11:42 PM
Joined Jan 2013
martyn... thanks so much.. that was it... thats all it was...
appreciate all the suggestions and i thank you all
Old Jan 22, 2013, 01:14 AM
ruiomichlet is offline
Find More Posts by ruiomichlet
Joined Jan 2013
ruiomichlet is offline Find More Posts by ruiomichlet
For Sale Sold....NIP Blade MCPX V2 BNF juneebear Aircraft - Electric - Helis (FS/W) 3 Mar 18, 2013 09:58 PM
Sold Blade 3-n-1 control unit - BLH3501 - new in package. Fits Blade MCPX heli skyking1 Aircraft - Electric - Helis (FS/W) 0 Jan 20, 2013 10:28 AM
Sold Blade mCPx V2 BNF with extra stuff $100 or trade joker24458 Aircraft - Electric - Helis (FS/W) 2 Jan 19, 2013 08:17 AM
Sold Blade mcpx v2 for trade, needs a few parts bergguy Aircraft - Electric - Helis (FS/W) 4 Jan 13, 2013 09:04 PM
Sold blade mcpx v2 with extras forsale or trade. Wildcat29 Aircraft - Electric - Helis (FS/W) 0 Jan 04, 2013 02:52 AM
