This thread is privately moderated by charljnr, who may elect to delete unwanted replies.
Old Jan 21, 2013, 12:35 PM
charljnr is offline
Find More Posts by charljnr
Thenewguy
South Africa, WC, Cape Town
Joined Mar 2012
Build Log
Mig 7 Slopie
Ok so I thought I need to build something. The Correx Mig 7 looked appealing, but maybe not robust enough for some sloping fun (=combat)
I have some Isoboard lying around, maybe this can work instead of Correx.
First have to build a hotwire cutting rig..
charljnr is offline Find More Posts by charljnr
Old Jan 21, 2013, 12:42 PM
charljnr is offline
Thenewguy
Joined Mar 2012
Templates made and cutting bow
Used some alumimium guttering sheet and made templates.
Hot wire cutter is ready to cut the wings, but lets make the fuselage first...
Old Jan 21, 2013, 12:48 PM
charljnr is offline
Thenewguy
Joined Mar 2012
Basic shaped fuselage
Took two 50mm thick isoboard sheets and stuck them together with UHU Por.
Made a roughly rectangular block of 100 x 700 x 250mm foam.
Stuck templates on side and top and used hotwire jigsaw to cut rough shape.
Now some 100 grit sandpaper, some elbow grease and voila!!!!
Old Jan 28, 2013, 04:01 PM
charljnr is offline
Thenewguy
Joined Mar 2012
Wings....
Made some templates from alumunium gutter sheet and cut a set of wings using the hotwire bow. Added about 2 degrees washout to the tips. The ends of the wings were a little ribbed due to being tapered so much, but with a bit of sanding it came out fine.
Old Jan 28, 2013, 04:11 PM
charljnr is offline
Thenewguy
Joined Mar 2012
Prepping wings and joining..
I decided to cut the wing trailing edges and put a full length aileron in as this part felt weak. The edge was lined with some balsa sheet that I had lying around and cut and sanded to shape.
Old Jan 28, 2013, 04:16 PM
charljnr is offline
Thenewguy
Joined Mar 2012
Joining the wings
Used the bow to cut angles on the roots of both wings, sanded a bit and then used some thick CA and kicker and joined the wings.
Old Jan 28, 2013, 04:24 PM
charljnr is offline
Thenewguy
Joined Mar 2012
Wings tape
Used some fibre tape and taped the whole wing. This is now as stiff as a surfboard - no spar needed!
Mounted the servos using some hot glue straight onto the tape. Cut wings shape into fuselage bottom and test fitted. Hollowed out part of the fuse so that servos have free movement.
Cut the tailplane with my hotwire jigsaw.
Starting to look like a plane. Tailplane and fin cut from 3mm correx and stiffened with sosatie sticks...
Not happy with the way the servos sit on the wing - too close to the edge of the plane.
Old Jan 31, 2013, 12:44 PM
Jak35 is offline
Find More Posts by Jak35
I'd rather be out sloping...
Jak35's Avatar
Joined Jan 2011
Cool build!
Would be nice in light conditions.
P.S. What on earth did you use the hammer for.....and the cake....working on your daughter's birthday?
Jak35 is offline Find More Posts by Jak35
Last edited by Jak35; Jan 31, 2013 at 12:45 PM. Reason: Who's hiding behind that plane? ;)
Old Jan 31, 2013, 01:59 PM
charljnr is offline
Thenewguy
Joined Mar 2012
Originally Posted by Jak35 View Post
Cool build!
The hammer was for the mozzies....
Yes it was a pink cake...
Old Feb 02, 2013, 06:12 AM
charljnr is offline
Thenewguy
Joined Mar 2012
Ready for maiden!!
First used some popsicle sticks to form a guide for the elevator control wire.
Covered fuselage with fibre tape and then covered with packaging tape. No fancy colour scheme for now - just high visibility for the maiden.
Took photos of the model...
Basic specs as follows:
840 grams
1200mm wingspan
Sold Sebart Mig 29 3D arf,non gyro version evalith8 Aircraft - Electric - Airplanes (FS/W) 0 Jan 21, 2013 07:36 AM
For Sale VMAR MIG 21 - Local Pick up Only. jodini Aircraft - Fuel - Airplanes (FS/W) 7 Jan 16, 2013 10:05 PM
Sold mig umx 95 shipped capekod heli Aircraft - Electric - Airplanes (FS/W) 1 Jan 16, 2013 03:24 PM
Cool Wattage Mig-15: CBP 650mAh and 16/7/7 meteor Electric Ducted Fan Jet Talk 14 Jun 28, 2005 03:55 PM
Video: Wattage Mig-15 + Mega 16/7/7 @ 80W! meteor Electric Ducted Fan Jet Talk 19 Jun 13, 2004 11:35 PM
