Old Mar 02, 2013, 12:17 PM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
pekos, are the formers laser cut?
djacob7 is offline Find More Posts by djacob7
Old Mar 02, 2013, 12:47 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Any time you see dark brown on the edges of the wood they are laser cut, cnc willnot have the dark brown burn.
unclecrash is offline Find More Posts by unclecrash
Old Mar 02, 2013, 04:41 PM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
Laser is CNC. What kind of CNC were you meaning?
Old Mar 02, 2013, 05:25 PM
unclecrash's Avatar
white lake michigan
Doa ,but you get it. I don't think you would see the wood burn from a cnc cutter bit
Old Mar 02, 2013, 05:55 PM
unclecrash's Avatar
white lake michigan
Geez I can't believe I fell for that trap. When I know they are both CnC operated. CNC bit cut is what I was refering to.
Old Mar 02, 2013, 07:18 PM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
OK, with a cutter like a milling cutter is what you meant. I know that some materials, including steel, can be CNC cut with a water jet and also with sand jet. Foam can be cut with a hot wire CNC machine.
I was wondering if the OP used his own CNC cutter or had it done for him outside.
Old Mar 02, 2013, 08:32 PM
unclecrash's Avatar
white lake michigan
CNC Router with a steel cutting bit. they do balsa and ply kits too Or the laser they cut kits too. The wood will be burnt on the edge's, you will know it if you were to pick up a laser cut kit and open the box it will smell burn't. I don't remember if he said he has his own cutter,but with his skills Im sure he could run it.
Old Mar 07, 2013, 03:30 PM
anton-anton is offline
Find More Posts by anton-anton
Danmark, Hovedstaden, Ølstykke
Joined Jul 2010
He pekos
It is possibel to see some of the part, lay flat on a tabel..
Maybe, the first 20 -30 cm of the body.
I`m curious to see how the part are fitting together.
Hope my questions is to understand, and my english is ok
By the way NICE job
anton-anton is offline Find More Posts by anton-anton
Old Mar 08, 2013, 02:59 AM
pekos is online now
Find More Posts by pekos
pekos's Avatar
Czech Republic, Hlavní město Praha, Prague
Joined Sep 2012
Hi, there is some pictures with the parts (lay flat on a tabel..)
http://www.rcgroups.com/forums/showthread.php?t=1727001
it's almost the same
Petr
pekos is online now Find More Posts by pekos
Old Mar 10, 2013, 10:13 AM
Joined Jul 2010
Petr
Thanks a lot. It was exactly that I was looking for.
Do You have a system, your working after, or do you just try, and redrawing if is wrong.
Because it look a littel bit confuse
Can you please tell more ?
Normal I use rhino to make the CAD
Old Apr 10, 2013, 04:32 PM
TNug is offline
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
Amazing work, Pekos. I can't wait to see this one finished and flying.
TNug is offline Find More Posts by TNug
Old Apr 10, 2013, 04:57 PM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
D_FAST is online now Find More Posts by D_FAST
Old Apr 11, 2013, 06:28 PM
TNug is offline
Waypoint Collector
TNug's Avatar
Joined Feb 2012
Pekos, do you ever use your prototypes for mold plugs?
Old Nov 12, 2013, 07:47 PM
Eric Paul is offline
Find More Posts by Eric Paul
Canada, ON, Kawartha Lakes
Joined Feb 2012
Any news on this? I'm dying to see it finished. I'd love to get my hands on one.
Eric Paul is offline Find More Posts by Eric Paul
Old Nov 12, 2013, 10:29 PM
czirh is offline
Find More Posts by czirh
Use your imagination....
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Nice project, good luck.
Cem
czirh is offline Find More Posts by czirh
New Product Blu-Baby 33 Classic (Monoblockless) Kit, Plans, and Build Guide dz1sfb Foamies (Scratchbuilt) 202 Jun 16, 2016 06:15 AM
Sold Stearman PT-17 scratch-build from Barron's Scale Classics Plans 1/6th Scale spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 5 Jan 06, 2013 10:01 PM
Sold Classic Fox 40th Anniversary .35 C/L Engine W/Classic Muffler $35.00 stevster Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 05, 2013 07:12 PM
Mini-Review The T-33 Shooting Star Classic Jet cadetman Pusher Prop Jet Models 38 Jan 30, 2007 07:52 PM
Article 04/05 JDC: SU-33 nborin Electric Plane Talk 0 Dec 28, 2004 12:00 AM
