Old Jan 24, 2013, 07:09 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
That appears to be a parallel setup you have. As such all cells are automatically balanced.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jan 25, 2013, 10:56 AM
taz007 is offline
Find More Posts by taz007
taz007's Avatar
United Kingdom, Higham
Joined Jul 2011
Glen
Thanks Glen.
taz007 is offline Find More Posts by taz007
Old Jan 25, 2013, 11:21 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
Once hooked to the charge cable the current flows from one batt to the other until all are equal voltage,there's no balancing for single cell batt.
The Tug is offline Find More Posts by The Tug
Old Jan 25, 2013, 07:56 PM
taz007 is offline
taz007's Avatar
Joined Jul 2011
so would this work if i hooked up 2 - 3 cell 2200 mAh, charge 3 cell @4400 ??? via a parallel cable (2 male XT60 to 1 female XT60 )
Old Jan 26, 2013, 02:53 AM
USA, GA, Marietta
Joined Aug 2005
Would you please read this: https://sites.google.com/site/tjingu...arging-how-tos
It will give you a better understanding of the overall picture of electrics. And it will answer most of your questions.
Glen
Old Jan 27, 2013, 12:18 AM
dceng888 is offline
Find More Posts by dceng888
I can fly!
dceng888's Avatar
Australia, TAS, East Launceston
Joined Aug 2010
Originally Posted by mrforsyth View Post
Longer flights ≠ last longer.
The reason that a lower charge rate results in a longer flight is that you achieve a more complete charge. More complete charge has been empirically demonstrated to result in fewer usable cycles than charging to a lower termination voltage. As such, lower charge rate can result in lower battery life (# of useful cycles).
Mark
Mrforsyth my charger like most modern chargers holds a constant voltage and lowers the current to about 0.2A at the completion of the charge cycle. So regardless of the set charge current the final step of the charge is always the same. I do not expect I am getting a difference of charging capacity by altering the set current. There for by this reasoning I should be able to charge at maximum capacity with no impact to cell life?
dceng888 is offline Find More Posts by dceng888
Old Jan 27, 2013, 02:13 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
All of my chargers terminate when CV current is 1/10th of initial CC current. Consequently, when charging at 10A, charge will terminate when CV current hits 1.0A. Similarly, when charging at 1A, charge will terminate when CV current hits .1A. The 1A charge thus results higher per cell voltage at end of charge cycle than when charging at 10A.
What charger are you using? If it indeed terminates when CV current is .2A regardless of initial CC current, then yes, charge capacity should be effectively identical.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 27, 2013, 04:06 AM
dceng888 is offline
I can fly!
dceng888's Avatar
Joined Aug 2010
I am using a turnigy 150watt charger. I have not played around with it enough to see if the cut off is different at different charge currents.
I am trying to find out the best charge rate for my 2200mah nanotech packs without affecting life span too much.
Old Jan 27, 2013, 09:38 AM
pe1rdw is offline
Find More Posts by pe1rdw
The Netherlands, NB, Heusden Gem Heusden
Joined Dec 2012
I see a lot of people using paralell charging for single cell lipos but I wonder how safe it is, in other words what will the current be when you hook up 2 fully charged 260 mAh nanotechs (4.2 V) to 2 'empty' 260 mAh nanotechs (3.5 V), will it exceed the maximum charge C or even discharge C in a worst case scenario?
pe1rdw is offline Find More Posts by pe1rdw
Sold Turnigy nano-tech 2650 mAh 11.1 lipo battery Supersteve Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 10, 2013 05:53 PM
Sold Sky Lipo 5S 3300 30C and Turnigy nano-tech 4S 25C scottieusa Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 07, 2013 07:36 AM
Sold Nano Tech 4s 3000 25-50C Lipo's 6x's ATCH Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 07, 2013 05:41 AM
Sold 6 New Nano-tech 600mah 1s 35-70c lipos w/Parrallel Charge jprochnow Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 10, 2012 07:18 PM
Discussion Noob Lipo Charging questions! High Flyin' Batteries and Chargers 2 Nov 08, 2007 10:40 AM
