Old Jan 21, 2013, 08:35 AM
MrTaz007 is offline
Find More Posts by MrTaz007
Joined Jan 2013
Noob question .. Nano-tech lipo charging
Hi Im a noob here so please go gental on me . Iv bought 4x 600mAh 1S 35-70c nano-tech li-po to use on a small quad, Now my question is can i charge these at a higher rate than 600mAh ie 800mAh or 1000 Mah on my charger , Any help would be nice, thanks in advance
MrTaz007 is offline Find More Posts by MrTaz007
Old Jan 21, 2013, 09:16 AM
Elios000 is online now
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
i wouldnt go any higher then 1amp
also you can charge them in parallel if you have a bunch of them
Elios000 is online now Find More Posts by Elios000
Old Jan 21, 2013, 10:53 AM
taz007 is offline
Find More Posts by taz007
taz007's Avatar
United Kingdom, Higham
Joined Jul 2011
taz007 is offline Find More Posts by taz007
Old Jan 21, 2013, 11:32 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I would have no reservation whatsoever charging them at up to 3 amps (5C). Most of the Nanotechs are rated for 10C charge and some even 15C.
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 21, 2013, 12:53 PM
romano_st is offline
Find More Posts by romano_st
no way
Croatia, Split-Dalmatia County, Split
Joined Apr 2012
i usually charge lipos at half their capacity, i use 2200 mah nanotech, as i noticed that they give more power and last longer then when i charge them with more current, they are rated for 10c but i would never try that, that is my opinion, max current i use is full capacity of battery in your case that would be 600 mAh
romano_st is offline Find More Posts by romano_st
Old Jan 21, 2013, 02:23 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
I agree with mrforsyth.
BTW what charger are you using.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jan 21, 2013, 05:20 PM
taz007 is offline
taz007's Avatar
Joined Jul 2011
Glen
Iv got a cheap Imax B6, Iv made a little parallel charger cable 3 female JST to a Tamiya Connector ,
I know im being a bit cheeky but.... whats the best way to charge my cells, Would i do Li-po 3 cell, @ 600mAh or Li-po 3 cell @1800mAh????
Old Jan 21, 2013, 05:36 PM
USA, GA, Marietta
Joined Aug 2005
If you made a parallel cable your charge is LiPo 1S at 1.8 amps, a 1C charge.
But I would go up to at least 3.6 amps, a 2C charge.
Your charger would support 5 amps but I wouldn't go there as I don't like pushing any charger to it's limit. The batteries certainly could take it though.
Glen
Old Jan 21, 2013, 06:27 PM
taz007 is offline
taz007's Avatar
Joined Jul 2011
Thanks Glen
Here is a little picture of my attempt
Old Jan 21, 2013, 07:22 PM
So. Cal.
Nicely done on the adapter.
Since your adapter connects the cells in parallel, simply add capacity and charge as a single 1S pack. For 1C rate, charge at 1800mA. For 2C, 3600mA, etc...
Mark
Old Jan 21, 2013, 11:26 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
So you charge a 2200mah pack a 1.1A?
Waste of time, no pack has any issues with 1C (heck the 18650 cells i use in torches have no issues with 1C) and any decent one will be fine with 2C no troubles.
Minimum 1C, maximum whatever the pack states, maybe a bit less than that if it is a cheap pack (I dont think I would charge nano-techs at 10C, but would have no problems with 5C).
desertstalker is offline Find More Posts by desertstalker
Old Jan 23, 2013, 11:30 AM
no way
Joined Apr 2012
desertstaker, like i said that is what i observed, slower i charge them they last more, since i can fly my funcub approx 5 min on 2200 nanotech ,additional minute or so matter to me. Of course that charging them with 1c or more wont harm them, for example once i was in rush and charged them with 5 amps what is maximum on my charger flight time was around 4 minutes per battery (mixed throttle) , maybe i am wrong but for me they last longer if i charge them with 1/2c
best regards
Old Jan 23, 2013, 02:36 PM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
Low charge rates are good once in a while for a good balance charge,it gets the cells very close in voltage,otherwise i'm not bother'd.
The Tug is offline Find More Posts by The Tug
Old Jan 23, 2013, 04:33 PM
So. Cal.
Longer flights ≠ last longer.
The reason that a lower charge rate results in a longer flight is that you achieve a more complete charge. More complete charge has been empirically demonstrated to result in fewer usable cycles than charging to a lower termination voltage. As such, lower charge rate can result in lower battery life (# of useful cycles).
Mark
Old Jan 24, 2013, 04:35 PM
taz007 is offline
taz007's Avatar
Joined Jul 2011
Just a Little up date to my home made Charger cable gone form a 3 way to a 6 way, charged at 2C took 42mins to charge 3 cells @ 3600mAh,
Thanks for all your help guys,
Just a thought but is there a way to balance charge all 3 cells, I know you don't need to balance charge a single cell but for when iv got 3 or more connected?????
Sold Turnigy nano-tech 2650 mAh 11.1 lipo battery Supersteve Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 10, 2013 05:53 PM
Sold Sky Lipo 5S 3300 30C and Turnigy nano-tech 4S 25C scottieusa Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 07, 2013 07:36 AM
Sold Nano Tech 4s 3000 25-50C Lipo's 6x's ATCH Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 07, 2013 05:41 AM
Sold 6 New Nano-tech 600mah 1s 35-70c lipos w/Parrallel Charge jprochnow Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 10, 2012 07:18 PM
Discussion Noob Lipo Charging questions! High Flyin' Batteries and Chargers 2 Nov 08, 2007 10:40 AM
