Old Jan 21, 2013, 02:31 AM
vinster100 is offline
Find More Posts by vinster100
vinster100's Avatar
Dallas, Texas
Joined Feb 2005
Eraser Extreme info wanted
Hi all. I'm getting back into the hobby after a couple of years and trying to setup an Eraser Extreme. Would anyone happen to know what the surface throws, camber settings and CG range are? Any information would be much appreciated. Thanks.
vinster100 is offline Find More Posts by vinster100
Old Jan 21, 2013, 03:20 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
there is some info on the eraser here:
http://www.f3j.cz/eraser.htm
Manufacturer settings aren't always the best, but it is a start.
If you search on here you will find a few threads relating to the Eraser, no doubt.
satinet is offline Find More Posts by satinet
Old Jan 21, 2013, 03:37 AM
vinster100's Avatar
Dallas, Texas
Joined Feb 2005
I have searched the groups already for the info but was unable to find anything I needed so thought I would try posting. I also saw those drawings however I'm confused by two things about them. First is it says "Eraser 2000" and I don't know if that is the same as the Eraser Extreme and second is, I have an x-tail version and the plans show a v-tail version so I'm not sure if the throws would be the same.
One other thing that is confusing about the diagrams is that they show camber changes for the flap in start and speed flight modes only, not one for thermal. It would be great if I could find the build instructions for the plane.
Old Jan 21, 2013, 06:07 AM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
I was under the impression that the "xtreme" version was different layup. I don't think it is made in a different mould than the eraser 2000.
info here:
http://www.icare-rc.com/eraser.htm
Anyway, I think if you start with the Vtail CG it will probably be on the forward side for the Xtail. I think it is highly unlikely the Xtail will have less tail area than the vtail.
Old Jan 21, 2013, 09:43 AM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
In 2003, I built an Eraser Extreme DPR. Don't remember much about it except that it flew extremely well. I set up the throws according to the instructions and only had to cut down the throws a little and eventually moved the cg slightly forward. The recommended throws and cg are a good place to start.
ChuckA is offline Find More Posts by ChuckA
Old Jan 21, 2013, 12:33 PM
vinster100's Avatar
Dallas, Texas
Joined Feb 2005
ChuckA, you don't happen to still have the instructions for the plane do you? Are you saying to use the throws that are in the plans on the website even though they are for the vtail? Do you have any camber settings and are they for the flaps only or for the ailerons as well?
Old Jan 21, 2013, 12:41 PM
tewatson is offline
Find More Posts by tewatson
Team JR Air
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Going on very distant memory here, but I recall the ballpark CG to be at the center wing bolt.
Tom
tewatson is offline Find More Posts by tewatson
Old Jan 21, 2013, 01:34 PM
psoff3x is offline
Find More Posts by psoff3x
Northumberland,UK
Some info from my old flying partner courtesy of the Knewt site
http://www.knewt.com/planes/f3j/eraser.htm
As it says, the extreme had curly-up tips while the 2000 didn't.
psoff3x is offline Find More Posts by psoff3x
Old Jan 21, 2013, 02:40 PM
ChuckA is offline
Tennessee
Joined Sep 2003
Sorry but the only thing I have is the log I kept while checking out and trimming and most of the notes were about setting up the Evo that I had just bought. I set up the model according to what was included with the kit and what was published in the Januaary 2002 issue of S&E Modeler magazine and I think that was about the Vtail verson.
The initial intial flight was on October 18 2003. The CG was 4.2 inches aft of the wing leading edge and I did have to add a little nose weight to get the model to fly the way I liked. The tow hook was mounted 4.3 inches aft of the wing leading edge and remained there until I sold the model. Over the winter I built a Compulsion and liked it almost as well a s the Eraser. Most of the flying was in October 2003 andd I didn't fly much that winter. The Eraser did not fly $400 better than the Compulsion so in the spring, I sold it to Walt VanGorder.
Old Jan 21, 2013, 03:49 PM
vinster100's Avatar
Dallas, Texas
Joined Feb 2005
Thank you for the link Psoff3x. That should give me a good starting point and seems pretty close to what the drawings showed.
Thought I might add a bit of history on me and this plane. This is my first full sized and flapped sailplane. I purchased it here on rcgroups.com back in 09, flew it a few times in one day but the last flight ended with a hard landing which caused a small crack on the tail boom. It was slight but I didn't want to take any chances so I repaired it.
However shortly after the repair I purchased a Harley, got a new girl friend, moved and had my radio equipment and a few planes stolen from a storage unit. The result being that I haven't flown in a few years. To make things worse, the hard drive where I had all my model information stored went belly up on me so I lost all info and settings I had on the Eraser.
I recently purchased an Airtronics SD-10g so I'm going through the learning curve with that as well. The radio I had stolen was a JR 9303. I never really warmed up to the JR so I'm hoping I like the Airtronics better and so far I do.
Since I'm still new to full house ships I find that I have questions about flap settings. Other than camber changes and being deployed for landing of course, are the flaps supposed to remain at the neutral point or are they supposed to work in concert with the ailerons for turns?
Thanks to everyone that has responded so far.
P.S. I'm still hoping someone out there other than me has an Eraser. If so I'd love to chat with you.
Old Jan 21, 2013, 03:58 PM
tewatson is offline
Team JR Air
tewatson's Avatar
Joined Oct 2006
Other way around, I think. All the Extremes I saw over here (and owned two of them) were based on the Eraser 2000 mold - flat tips.
Tom
Old Jan 21, 2013, 04:53 PM
psoff3x is offline
Northumberland,UK
Tom
I made the mistake of referring to the extreme as having turned up tips. It had both. The Xtreme was a manufacturing layup technology used by Lubos and both the Eraser 2000 and Eraser were available in a variety of layups, including Xtreme.
What was available in different parts of the world was simply a marketing decision. Here in the UK the Xtreme and XTreme D-Box layups were available in both variants of the Eraser.
My Eraser 2000 was the F3B version with flat tips, while my flying partner's (and original importer of Erasers into the UK) was the Eraser Extreme D-Box with turned up tips.
The manufacturer's website explains all
http://www.f3j.cz/technol.htm
Pete
Old Jan 21, 2013, 04:58 PM
wsmorton is offline
Find More Posts by wsmorton
United States, AZ, Prescott
Joined Aug 2006
I have been rebuilding an Eraser (V-Tail) for a while now and have only flown it a few times. I put the CG at about 40%-42% root chord and that seems to work well, although it might be a bit nose heavy for some folks. I plan on moving it back another percent or two. I also have two sets of wings. The original set that came with the fuse has straight tips and is a fiberglass and foam (Herex?) sandwich and the second set of wings have curved up tips and is a fiberglass and balsa sandwich construction. The all up weight with the original wings is around 77 ounces and with the other wings, it should be around 81 ounces. I haven't finished the other set of wings yet.
You probably saw my posts about this model from your search, but here's some links so you can see the repair work I've done.
http://www.rcgroups.com/forums/showthread.php?t=1165202
http://www.rcgroups.com/forums/showthread.php?t=1745606
http://www.rcgroups.com/forums/showthread.php?t=1707446
Scotty
wsmorton is offline Find More Posts by wsmorton
Old Jan 21, 2013, 08:49 PM
cityevader is online now
Find More Posts by cityevader
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
With your radio, you will be able to have either flap only/aileron only, or with the flip of a switch, have full-span ailerons and full-span camber. A couple of mm down for camber should be a good starting point (might have to also mix in elevator correction).
Overall throws will depend on your CG (aft CG=less throw) so you may just have to simply fly it to see what works for you.
Otherwise, I'm so specific help whatsoever.
cityevader is online now Find More Posts by cityevader
Old Jan 21, 2013, 09:29 PM
Soarmark is offline
Find More Posts by Soarmark
Mark LSF # 3792
United States, TX, Garland
Joined Nov 2008
Pete,
I had a few years ago, what is was told was, an Xtreme that I purchased second hand. It has a carbon D-box (you could see the carbon under the paint) and it also has flat tips. It's still being passed around our local club with no crashes. Imagine that no patches on the boom!
When I set it up I started with the settings from Lobos's web site. Can't remember what I ended up with though. I also remember seeing a review here on Groups for the V-tail. Those settings were also in the same ball park.
Tom is correct if I remember the CG was around the center wing bolt. Also, I always mix aileron into flap for added roll control. You just need to get it close then go fly it and see what you need to change to fit your style.
Mark
Soarmark is offline Find More Posts by Soarmark
Found Wanted: Extreme Flight Profile Yak 54 ARF. *Found* jbj620 Aircraft - Electric - Airplanes (FS/W) 4 Jan 16, 2013 10:56 AM
Wanted wanted - new era flamed clod skidplate bigdogrod Cars - Trucks and Parts (FS/W) 0 Oct 21, 2012 06:16 PM
Wanted WANTED: 30's era racers Whoaty55 Aircraft - Electric - Airplanes (FS/W) 1 Nov 04, 2011 08:02 PM
Discussion Actro 24-3 vs X-Era 4025-667 2.5Y (X-Era superior in all respects) blueviewlaguna Large Electric Helis 51 Feb 27, 2009 01:28 PM
Which WW2 era plane do you want? Abomination Parkflyers 82 Jun 01, 2004 12:08 AM
