Old Jan 21, 2013, 02:08 AM
Gene Genie is offline
Find More Posts by Gene Genie
United Kingdom, Leeds
Joined Jun 2011
Avanti S - Sebart - Wing Fixing
For some time now I have been thinking of getting a Sebart Avanti S, recently I came accross a copy of the photo instruction manual and I was interested to see the method of retaining the wings on the model.
It seems that you have to drill through the wing from the underside, ( not sure if the actual postion of the hole is located or identified on the wing ) then the carbon fibre wing tube is installed and then that is drilled slightly smaller using the first hole as a pilot and a 3mm x 16mm screw is inserted to hold the wing in place. It does not identify anything other than the balsa skin and covering as acting as the medium of holding the screw ( and wing )
I have always employed how to say more positive methods of retaining wings and I am looking for any comments on this, it could be that the photo instructions are not showing everything.
Thank you
Gene Genie is offline Find More Posts by Gene Genie
Old Jan 23, 2013, 02:21 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
If you can find someone that has a set.. Mulitplex wing locks are the answer. There may be other similar ways to do it such as automotive locks used to hold body panels on(just thinking out loud)
vettster is offline Find More Posts by vettster
Discussion Wing depression fix RCDad Sailplane Talk 14 Jan 16, 2013 01:05 PM
Yippee! Fix for wing rock, Sebart Katana S 30E Stark 3D Flying 9 Aug 23, 2012 02:58 PM
Sold Avanti Delta wing Steve H. Aircraft - Electric - Airplanes (FS/W) 2 May 02, 2007 12:11 AM
For Sale Avanti Delta wing Steve H. Aircraft - Electric - Airplanes (FS/W) 1 Apr 09, 2007 07:39 PM
Sold Avanti Speed wing Eyefly Aircraft - Electric - Airplanes (FS/W) 3 Jun 22, 2006 01:21 PM
