Planform shape affects stall characteristics.
chord dimensions affect Reynolds Number and drag (see Quantitative Analysis) greg |
i think most of what your asking is captured by airfoil polar diagrams showing the lift and drag for a particular airfoil at various AOA and Reynolds Numbers (RN). RN allow are a function of velocity, as well as length. (again, see Quantitative Analysis).
see SuperGee II, designed by Dr Drela at MIT. You may also be interested in designed you own airfoils, see Xfoil |
Xfoil is a tool which predicts airflow resonably well at lower reynolds numbers. It's pretty much become the standard for evaluating airfoils for use with our model aircraft when you simply don't have a multi million dollar wind tunnel to play with...
![]() As I understand it much or all of the Xfoil ability has been folded into XFLR5. And XFLR5 goes much further and provides the ability to examine whole wings and airframes. I've dabbled with XFLR5 a little but I'm far from even competent with it at this point. But there's no doubt it'll do whatever you can ask. http://www.xflr5.com/xflr5.htm Daniel, much also depends on what you want to do with the model. If you are looking at speed range and efficiency you'll quickly find yourself designing towards a glider like airframe based on the "gains" you see as you shift your numbers to follow the improvements you see from the runs. But there's more to it than this if you are after a model which is intended to be as efficient as possible but still do other things. This is where the nasty word "compromise" rears it's ugly head. For example roll rate and pitch rate is very important to aerobatic models so a long and skinny wing isn't the best option for such a design. So keep some potential practical realities in mind as you work with the program. |
Joensuu, Finland
Joined Mar 2002
Here's a pretty good description of the methods by the author himself: http://web.mit.edu/drela/Public/papers/xfoil_sv.pdf
I'm not familiar with hydrodynamics, but compressible vs. incompressible flow are two totally different animals. I would be surprised if any analytical method could be common for both diciplines. In addition, a boat moves on the surface of water and all kinds of wave phenomena will be a significant factor. |
| Thread Tools | |
| Discussion Using status indicator to help locate downed model | RICHARD3851 | Xtreme Power Systems | 6 | Jan 17, 2013 02:19 PM |
| Discussion Help with old model plane MRC Cessna Cardinal II | 01rednavigator | Classic Pattern Flying | 5 | Jan 16, 2013 03:16 PM |
| Discussion Help with old model plane MRC Cessna Cardinal II | 01rednavigator | Fuel Plane Talk | 4 | Jan 13, 2013 11:19 PM |
| Discussion need some help picking a model - World Models Wing Jet EP | SoarinJohn | Electric Ducted Fan Jet Talk | 0 | Jul 01, 2008 05:24 PM |
| Alert Modelers helping modelers in Iraq | Andy W | Site Chat | 0 | Jul 07, 2004 04:39 PM |
