Old Jan 20, 2013, 10:07 PM
scootrb4 is online now
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Cover iron questions
I want to buy a covering iron for tightening up the covering on the ARF I'm assembling.
I would like to have one that would be good enough to cover a scratch built one day.
What do I need?
And why?
Thank you
scootrb4 is online now Find More Posts by scootrb4
Old Jan 21, 2013, 08:02 AM
WCB is offline
WCB
Find More Posts by WCB
WCB
NC
Joined Aug 2005
http://www3.towerhobbies.com/cgi-bin...?&I=LXPW70&P=0
Here's the combo Black Baron covering iron and trim iron. I have been using these for years. I like the covering iron temp setting in degrees instead of 1-2-3 on some irons. The trim iron temp setting is H or L but it is ok on that. I use the trim iron about as much as the covering iron.Great for getting into tight places.
As a side note a heat gun works good on large areas. Another tool to consider.
WCB is offline Find More Posts by WCB
Old Jan 21, 2013, 01:57 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
For the past 25 years or so I've been using a domestic travel iron. It's much cheaper than the covering irons and, to my mind, the handle on top is much easier to use than the handle out one end of the covering irons I've seen.
Downside is it's not marked in degrees, so I have to test with an offcut before I use it -- though I now know what mark to set it without testing.
abenn is offline Find More Posts by abenn
Old Jan 22, 2013, 11:41 AM
Jim Buzzeo is offline
Find More Posts by Jim Buzzeo
Jim Buzzeo's Avatar
Willmar, Minnesota, United States
Joined Sep 2004
a VERY useful (cheap) addition... pocket thermometer.
http://www3.towerhobbies.com/cgi-bin...&I=LXB352&P=FR
Jim Buzzeo is offline Find More Posts by Jim Buzzeo
Old Jan 23, 2013, 10:17 AM
scootrb4's Avatar
Joined Nov 2011
What is the proper temperature for the various popular coverings? I assume they differ?
Old Jan 23, 2013, 02:09 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
you must use a sock! even with a brand new iron!
any iron will work, the first couple planes I built, were coverd with my wifes black & decker household iron!
all coverings use a lil different temp! temp control will very depending on your technique, the slower you iron the lower the heat needs to be, but you do need to get the iron too the temp that will excite the glue!
then I use a lil hoter temp to shrink the covering!
and less not forget, PREPERATION is KEY! like all paintjobs, they are only as good as the surface, being covered! I use 220 for most my shaping, then final sand, with some 400 grit! then vacume the surface!
whiskykid is offline Find More Posts by whiskykid
Old Jan 23, 2013, 07:26 PM
scootrb4's Avatar
Joined Nov 2011
Okay, I see like everything, there is more to this than I thought initially. Thanks
Old Jan 23, 2013, 07:39 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
IMO best iron out there!
Underthetire is offline Find More Posts by Underthetire
Old Jan 24, 2013, 01:25 AM
kbozarth is offline
Find More Posts by kbozarth
Joined Jun 2008
Using a thermometer for covering is like measuring your feet at a shoe store.
Kurt
kbozarth is offline Find More Posts by kbozarth
Old Jan 24, 2013, 02:53 AM
scootrb4's Avatar
Joined Nov 2011
Thank you, I just ordered the Coverite 21st Century Sealing Irons Pack from Tower Hobbies.
Old Jan 24, 2013, 05:43 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
I have used the Coverite irons - full size and trim - for the past couple of years and I've very pleased with them.
grosbeak is offline Find More Posts by grosbeak
Old Jan 24, 2013, 08:07 AM
WCB is offline
WCB
WCB
NC
Joined Aug 2005
I think you'll be pleased.
Old Feb 14, 2013, 03:10 PM
F16DCC is offline
Find More Posts by F16DCC
United States, NM, Holloman AFB
Joined Oct 2007
I just bought a Top Flight iron and sock package deal from tower for my freshly built aircraft. I've done the wings and most of the fuse and so far so good. I use the heat gun to shrink the covering and to get the wrinkles out. This is my first time building and covering an aircraft and it's pretty strait forward. I don't use a trim iron, I just cram the big one into the crevas and it works just fine.
F16DCC is offline Find More Posts by F16DCC
Old Feb 15, 2013, 09:10 PM
scootrb4's Avatar
Joined Nov 2011
I'm going to try my hand at it tomorrow on a repair section where I've replaced some wood.
Old Feb 16, 2013, 06:48 PM
redh is online now
Find More Posts by redh
Fla.
Joined Apr 2005
Just remember to double seal ( run your iron over ) all edges and take your time . Unsealed edges suck fuel in . ENJOY !!! RED
redh is online now Find More Posts by redh
For Sale FS: Heat gun and covering iron biskit Aircraft - General - Miscellaneous (FS/W) 4 Jan 20, 2013 06:47 AM
Wanted Monokote covering iron Ezobel123 Aircraft - General - Miscellaneous (FS/W) 0 Jan 17, 2013 06:12 PM
Wanted Hangar 9 Pro Seal Covering Iron - WANTED PyroMan Aircraft - General - Miscellaneous (FS/W) 0 Jan 16, 2013 09:32 PM
Wanted Hangar 9 Pro Seal Covering Iron - WANTED PyroMan Non R/C Items (FS/W) 0 Jan 16, 2013 09:31 PM
