Old Mar 27, 2010, 11:42 AM
EarthDog is offline
Find More Posts by EarthDog
EarthDog's Avatar
Greece, Attica, Athens
Joined Mar 2010
Wow!
thank god i found this post...i was ready to just post the same thing..i was like a lunatic trying to see if my lipo is warm....
Guess that's what happens when i was missing from chemistry classes
EarthDog is offline Find More Posts by EarthDog
Old Mar 27, 2010, 06:23 PM
Duduca is offline
Find More Posts by Duduca
Duduca's Avatar
Brazil, MG, Ipatinga
Joined Jan 2010
i am trying to understand how lipo works. I bought a playmate and it came with a 1s 3.7v 130mah and when i try to fly on really cold days, the plane stops responding to the 3 channel radio system that comes with it. Is this a battery problem?. temperature to low?. Bad motor? trasmitter failure or receiver failure ?
The plane completely shuts down and sometimes if i bring back the throatle back to zero and wait like 2-5 seconds, the plane will start everything again, but it will happens again and again every like 30 second or so . What this mystery could be ? Temperature today at the field was like 35 degrees and winds at 8mph.
Duduca is offline Find More Posts by Duduca
Old Mar 27, 2010, 06:29 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
LiPolys suffer deminshed performance when cold. Things should be much better when temps. are 70F or above.
Old Mar 27, 2010, 06:53 PM
Duduca is offline
Duduca's Avatar
Joined Jan 2010
The problem was in the antenna and not on the battery. Problem solved.
Cheap, Easy LiPo Pack Balancing while Charging RD Blakeslee Batteries and Chargers 54 Jan 10, 2007 08:19 AM
Discussion Wall Charger gets really hot while charging. Discusman Batteries and Chargers 5 Aug 16, 2006 08:22 PM
Are LiPo changing size while charging? Bocaben Batteries and Chargers 1 Oct 31, 2003 03:35 PM
Cooling while charging=more power? Mike C Batteries and Chargers 0 Jul 11, 2002 11:01 PM
how much current while charging Transmitter Al P Power Systems 3 May 13, 2001 11:57 PM
