Old Jan 20, 2013, 08:25 PM
Mad Matt is offline
Find More Posts by Mad Matt
Joined Jan 2013
Question
SC10 4x4 - 32 Spur gear / pinion selection??
Hello my fellow radioheads,
I am in the research phase of building a new SC10 4x4 Short Course truck. I have been out of the hobby for about 10 years so there are things I don't know or remember. I am looking for some clarity for my new build's gearing.
I watched several YouTube videos on the truck and I hear everyonr saying use 32 tooth spur gear but I am not getting the information on a pinion.
I am planing a Reedy 540-SL 3900kV brushless motor but Reedy doesn't provide any information on number of turns etc. I don't want to have a motor gear ratio that cooks the solder off and I don't need a rock crawler torque set-up either, just a good center line racing set-up for use at my local track.
So can someone help me out here??
Mad Matt is offline Find More Posts by Mad Matt
Old Jan 20, 2013, 08:51 PM
mredzadventure is offline
Find More Posts by mredzadventure
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
The best bet is going to see what guy's are running at your track. I would check the manual for your final gear ratio is I would start with about one tooth up or down and see how it goes.
This is a link to some of the factory drivers set-ups Maybe this might help for a starting point.
http://www.teamassociated.com/cars_a...anuals_setups/ 2wd
http://www.teamassociated.com/setupsheets/SC10_4x4/ 4wd
mredzadventure is offline Find More Posts by mredzadventure
Old Jan 21, 2013, 10:27 AM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Are you sure they said 32 tooth and not 32 pitch?
Here's the manual with parts listings:
http://www.teamassociated.com/pdf/ca...at_sc104x4.pdf
The stock spur is either 32 pitch 62 teeth or 48 pitch 93 teeth (both are apparently in the kit). The RTR version runs a 62 tooth (32 pitch) spur with a 14 tooth pinion.
The RTR uses a 550 3500kv motor (longer rotor means a bit more torque), so you'll want to drop a couple teeth from the RTR gearing to the motor you want to run.
wparsons is online now Find More Posts by wparsons
For Sale Feigao motor,Cobri and Himax gear boxes,spur and pinion gears rick88ss Aircraft - Electric - Power Systems (FS/W) 1 Jan 27, 2011 12:41 AM
Discussion pinion gears spur gears? what's what? Stuart Linfoot Power Systems 7 Aug 20, 2008 01:46 PM
Help! Different Pinion and Spur Gear combos that result in the Same Gear ratio! e-flythis! Power Systems 6 Aug 01, 2007 09:19 PM
spur gears and pinion gears NoS Off-road Cars 5 Dec 19, 2004 08:24 PM
