Old Jan 20, 2013, 07:49 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Need a Bad A$$ Engine set up for Ultra Stck 40
So there seems to be a who has the fastest 40 Ultra Stick at my Field. I'm thinking of picking up a Hangar 9 and putting a OS 55AX on it with a nice pipe. I understand a specific kind of Muffler can make a BIG difference. Any other ideas of a power choice or Tune Pipe would be appreciated. Thanks
Dale 813 is offline Find More Posts by Dale 813
Old Jan 20, 2013, 07:53 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
A Jett .50 or a Jett SJ .60 LX if you want it so no one will ever be faster than your plane.
Also build a new wing with more thin in height wing ribs so the wing is thinner too.
earlwb is offline Find More Posts by earlwb
Old Jan 20, 2013, 11:38 PM
datsunguy is online now
Find More Posts by datsunguy
Joined Jun 2011
I don't think any company makes "bad a$$" engines
datsunguy is online now Find More Posts by datsunguy
Old Jan 21, 2013, 05:10 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Dale,
Your Ultra Stick is not designed to be a fast plane!
Merely flying at full-throttle and full speed can get the control surfaces into a flutter.
Even your OS.55AX is overpowering. A normal .46 engine can get it to climb vertically.
The Jett engines that Earl suggested belong in a GP Patriot, in a Jackal, or in another fast model; and will bring them over 125 mph.
In your Ultra Stick you will probably not see more than 80.
Going fast not only means a 'bad a$$' engine; it also means a suitably streamlined plane.
Or it is just a 'turtle race', with ailerons/elevators/flaps/rudders flying off...
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 21, 2013, 09:35 AM
Mike1484 is offline
Find More Posts by Mike1484
Elyria, Ohio
Joined Sep 2004
I use the Rossi .45 on my Midwest stick. Also the Mac's Header and pipe. ACP props like 10/7 or 11/6 work good for speed and vertical flight. Watch out for flutter on those down wind dives.If you can find a Quickie 500 they fly great and are a lot faster than the stick.
Mike1484
Mike1484 is offline Find More Posts by Mike1484
Old Jan 21, 2013, 10:40 AM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
To me, a BADA$$ engine will go from just over stall speed to unlimited vertical W/a pull on the right stick while pushing the left stick all the way forward.
Power, not speed.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Jan 21, 2013, 09:10 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Would this muffler give more performance than the stock muff on a 55ax ? http://www.ebay.com/itm/Macs-Product...item53f15f1ea8
Old Jan 22, 2013, 02:40 AM
DarZeelon's Avatar
Joined Nov 2003
Dale,
It will give you a small power gain. This item will give you a much greater gain (1,000-2,000 RPM on most props)...
But since I have already established that your plane has enough power as it is, both would be a waste of your hard-earned cash...
Old Jan 22, 2013, 08:46 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
It is only money, you can always get more of that?. It is pretty expensive, as much as some motors, but it won't wear out I guess.
aspeed is offline Find More Posts by aspeed
Old Jan 22, 2013, 09:38 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
He could also go for an Evolution .60NX engine and use the Evolution tuned muffler for it (Dar Zeelon's link referenced it) and that would be getting some good performance for the plane then. That is the same combination they suggest for the Hangar 9 Jackal Speed plane too.
The OS 55AXC is a nice engine, but it isn't really a performance engine. OS has tuned it more for turning bigger props more quietly. But it does run OK and there is some performance gain with other mufflers or tuned pipes that one can get out of it. But some other engines perform much better though.
Old Jan 23, 2013, 06:04 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
There's a guy at the field that scratch builds Planes similar to the Ultra stik but built a lot stronger and the wing is thinner. Most of his have 55's on them I'm trying to talk him into building one for me.
Old Jan 23, 2013, 06:47 AM
DarZeelon's Avatar
Joined Nov 2003
Going fast...
Dale,
If you're serious about going fast, with something that resembles your Ultra Stick, Get yourself a Viper 500.
Than, you can put a bad a$$ engine in it too...
Old Jan 23, 2013, 03:41 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Originally Posted by DarZeelon View Post
Dale,
Do they make one with a normal tail as where I can put a tail wheel on it ? I like the Pylon racer style. I just don't like the dinky wheels and the tail skid. I would put normal wheels on it and a tail wheel. .
Old Jan 23, 2013, 05:15 PM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
get a 60 motor (fsr is a good one) mouse can muffler and fly the snot out of the thing
scrub monkey is offline Find More Posts by scrub monkey
Old Jan 23, 2013, 09:23 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yes you can put a tail wheel on it, but it doesn't use a rudder servo though. The wheels and skid reduce aerodynamic drag. You could put on bigger wheels if you like too. Actually the racing wheels are about 2.25 inches in diameter and very thin. But thin works good off of thick grass runways too.
Since you glue the tail on, you could put on a conventional tail if you like. The V-tail was another way to reduce drag too.
Actually they do sell some Quickie 500 planes with conventional tails on them.
Help! Need to know the set up for a Hydro Plane Foamie. SHoffman1971 Power Systems 13 Jan 15, 2013 07:25 PM
Discussion Need Advise on what C rating for this system set up! chopper52 Electric Ducted Fan Jet Talk 1 Jan 12, 2013 01:09 PM
Discussion Need help setting up Devo 10 w gimbal and f450! floete Multirotor Talk 4 Jan 07, 2013 03:27 PM
Help! Need help setting up Walkera V120D02S... LucidSoul Micro Helis 6 Jan 04, 2013 10:46 AM
Discussion engine set up for a .40 trainer_24 Australia 2 Apr 03, 2007 08:40 PM
